| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
USN Retired
Drives: '13 BRZL, 05LGTL, 05LGTLSW, and +5
I would imagine that the Limited may have to have a chip of some type in the car for a remote starter to work, possible some type of modified chip where if it gets put in gear or senses movement, the car will shut off unless it "see's" the real key.
#16 |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
What would happen if I have the push button start and I go outside to start it and then come inside with the key fob? Could someone open the door and take off with the car?
#17 | |
SLO NO MO
Sent from my Nexus 7 using Tapatalk 2 |
#18 |
Drives: 2013BRZ Premium St Silver Metallic
I would expect that the doors would be locked.
#19 | |
Drives: '95 Honda Civic HB/'13 Subaru BRZ
Haven't tested with BRZ yet, but a lot of cars allow you to drive without keyfob as long as car is started. Once you shut it off, that's a different story... Won't turn back on without the keyfob. I work in a bodyshop and have seen Nissan, Toyota, and Lexus do this. Not sure if its on all models or not. Other makes I'm also not sure of since its not something we make habit of doing. One instance was when a customer had a rental Altima and left key on top of car when putting stuff in. They forgot key and drove home. Lol... Had to tow car back to us so we could get new key and get it reprogrammed. |
#20 |
Brz limited has a factory proximity sensor and yes, key is chip.
#21 | |
SLO NO MO
| The Following User Says Thank You to Foobar For This Useful Post: | sbxjap (11-23-2012) |
#22 | |
Drives: 2013 Satin White Pearl Subaru BRZ
I think what we're missing here is the consideration of a dead battery in the key fob. If they decided to implement a kill engine switch whenever the car is unable to detect the key fob, that would mean running the risk of an engine stopping dead on a freeway because of a dead key fob battery. That would be pretty scary imo. Who knows, maybe the engine DOES turn off when you try to drive it without the key. I kind of doubt it myself, but I'll try it when I get back home. |
#23 | |
Drives: nissan frontier, DGM MT BRZ
#24 | |
What's weird about keyless entry cars with start button is that even with a dead battery, as long as the keyfob is close (I mean, right next to the start button), it will usually still start. It's a safety feature... learned that hard way at my shop. Usually doesn't apply to the doors.... only ignition. The thing is, I doubt that will be any help, unless they high thee keyfob behind the start button... |
#25 | |
Shorter of breath
Drives: a soft bargain
The fob is a transmitter, and as long as the battery in it is functional, it works from a distance. The fob also contains a passive RFID component, and when the fob battery is dead, holding the fob next to wherever the reader is located serves the same purpose. On Corvettes, there's a little slot in the dash behind the glove box door - you slide the fob in that, and you're good. |
#26 |
Shorter of breath
On GM cars, it's part of the customizable features as far as what you want the car to do in that case. The default setting is as you say, keep running but don't allow restart.
#27 | |
#28 |
Shorter of breath
I think pretty much all keys have RFID elements now - GM started the idea with the PassKey systems in the late '80s, where there was a resistor embedded in the key shank. When you inserted the key into the ignition, there were terminals that 'read' the resistor, and if the value wasn't correct it shut down the fuel system for fifteen minutes.
There were something like ten different resistor values, so a potential thief might have quite a wait. Corvettes had it first, and they went from the most-stolen cars to basically dropping off the list in the space of a year. Now everybody does the same thing with RFID. It's how you can personalize by key, and it's why keys cost $50 or whatever insane amount it is.
| Keyless remote replacement | sesmls | BRZ First-Gen (2012+) — General Topics | 25 | 06-05-2014 11:23 PM |
| Remote start installer in north nj | Lee358 | NY / NJ / CT / PA | 7 | 08-22-2012 02:08 PM |
| Schematic for remote start install? | empower-auto | Electronics | Audio | NAV | Infotainment | 3 | 07-31-2012 06:13 PM |
| Compustar needs a BRZ w/PTS for remote start info. | burnt_rice | Northwest | 2 | 06-19-2012 06:31 PM |
| Car Finder feature on Remote | eriktherod | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 08:23 AM |
