Old 11-21-2012, 05:00 PM   #15
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by No Limit Motorsport View Post
Its a street car. It really isn't low compression at all, these cars just come abnormally high. It is perfect turbo engine compression for pump fuel.
Most WRX/STI guys run 8.2-8.5:1 compression.
That's cuz EJs aren't that great :P
Old 11-23-2012, 05:09 AM   #16
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Taking 20psi on stock parts, plenty enough. Gonna take a good few psi just to bring back the power loss from the compression drop, inefficiency creeping in from all directions
Toyota 86 test driver
Tradewind is offline   Reply With Quote
Old 11-23-2012, 11:54 AM   #17
rusty959
Drives: DGM BRZ limited
Don't forget that took e85. Not everyone wants to or can run e85. Some people can't even run 93.
Personally if I ever change out the engine internals, (probably will happen eventually) I'm looking to hit 10.5:1 or so. However Ill be looking out for more people doing testing before I'd be completely set on a number.
rusty959 is offline   Reply With Quote
Old 11-23-2012, 01:55 PM   #18
Calum
That Guy
Drives: 2013 asphalt FRS MT
That^^
Old 11-23-2012, 02:55 PM   #19
J_D
Chief ish disturber
Drives: undecided
I believe they make both 9 to 1 and 10 to 1 pistons.
J_D is offline   Reply With Quote
Old 11-23-2012, 04:55 PM   #20
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Price?
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 11-23-2012, 06:11 PM   #21
MANDALAY
Drives: MR2
9:1 is a great number with many builders using this c/r as a norm for building a safe engine.
MANDALAY is offline   Reply With Quote
Old 11-23-2012, 10:36 PM   #22
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
CP is very good stuff I only use there pistons
jdzumwalt is offline   Reply With Quote
Old 11-23-2012, 11:49 PM   #23
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
Originally Posted by Tansey86 View Post
With FI I would go with around 10:1, more response and power. If it wasnt DI I could see why going down so low.
wouldnt clearance between piston and head would be close at that CR with boost?
DanoFA20 is offline   Reply With Quote
Old 11-24-2012, 09:01 AM   #24
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
No, because the stock pistons have a taller dome than these, it would be more clearance.
No Limit Motorsport is offline   Reply With Quote
Old 11-24-2012, 04:31 PM   #25
MANDALAY
Drives: MR2
These would be good only IF the total squish area and volume were either improved or remain untouched. If this wasnt taken into consideration they are just shaved down pistons that are nothing special
Old 12-10-2012, 04:06 PM   #26
No Limit Motorsport
Old 12-10-2012, 04:30 PM   #27
SnapOv3st3r
Drives: 400whp Scion tC
Beef...
SnapOv3st3r is offline   Reply With Quote
Old 12-11-2012, 05:00 PM   #28
3MI Racing
Pro Subie Engine Nerd
3MI Racing's Avatar
Drives: empty spot for an FR-S/BRZ
What's the weight on those Pauters?
One thing I can say about Pauter's, having use to special order them in bulk, their tolerances are spot on!!
3MI Racing is offline   Reply With Quote
AVO turbo kit for BRZ - initial build thread AVOturboworld Forced Induction 3109 12-01-2019 03:55 PM
Stop Motion Engine Build Mishimoto Other Vehicles & General Automotive Discussions 0 08-06-2012 04:25 PM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Engine build Maxim Engine, Exhaust, Transmission 41 10-03-2011 09:22 PM
