Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
03-09-2013, 04:25 PM | #15 |
Drives: WRB JR BRZED
I installed mine today and none of the filter sticks out.
03-09-2013, 05:05 PM | #16 |
Drives: "I drives like a Porsche"
For the K&N which side face the cabin? The flat side or the puffy part that sticks out?
03-09-2013, 05:14 PM | #17 |
Someone correct if I'm wrong. On the factory and K&N filters one of the corners is a squared and all of the rest are rounded. With that squared side it will only go on one way to seal and allow the air box to shut correctly. That squared side should go down and to the passenger side if I remember correctly.
The Following User Says Thank You to UltraFRS For This Useful Post: | WillRacer1jz (03-09-2013) |
03-09-2013, 06:40 PM | #18 | |
03-09-2013, 07:16 PM | #19 |
Drives: Raven FR-S 6MT
Damn I think I installed it wrong ... going to have to check it now.
03-09-2013, 07:33 PM | #20 |
But does the puffy padding go towards the cabin? Or facing the bumper?
03-09-2013, 08:36 PM | #22 | |
Drives: Skoda Yeti DSG diesel 4x4
I just checked mine to confirm you have fitted it alright. The other point, that's really the most important one, is that it filters so well. I don't know how long you had the OEM filter in before the Perrin but mine went in almost straight away and it's spotless after the filter. Wipe it with a white tissue and it's still clean spotless. |
03-09-2013, 08:38 PM | #23 |
Yup had it on wrong ... this is why Perrin should've included some type of instructions (yes I'm serious ). I was thinking the mesh was to prevent debris damage to the form but what sierra mentioned above makes sense.
03-09-2013, 08:39 PM | #24 |
Thanks man.
03-09-2013, 09:47 PM | #25 |
I agree with you. All the drop in filters should have it clearly explained which way it fits. Once you know, it's obvious but I thought the same as you, with the mesh, at first and felt a dill when the penny dropped.
Similar Threads | ||||
Complete noob under-the-hood question! | Scik | Engine, Exhaust, Transmission | 12 | 06-21-2012 10:07 PM |
Noob lowering question. | bazguitarman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-21-2012 03:53 PM |
Noob question | fitcious | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 05-02-2012 11:18 PM |
Total noob tire-change question | Sport-Tech | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 38 | 04-17-2012 07:15 PM |
[Noob Question]Will you be able to swap BRZ and 86 headlights? | Slide | Cosmetic Modification (Interior/Exterior/Lighting) | 41 | 02-18-2012 01:26 AM |
