Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 11-14-2012, 04:19 PM   #15
BoostedWrbBrz
Drives: 2014 Wrb Brz limited 6m
My parts are on back order.
BoostedWrbBrz is offline   Reply With Quote
Old 11-14-2012, 10:43 PM   #16
xpicer
xpicer's Avatar
Drives: 2013 frs white out
im goona re name her " the chirper"
" Knowledge is nothing with out execution"
xpicer is offline   Reply With Quote
The Following User Says Thank You to xpicer For This Useful Post:
dori. (11-15-2012)
Old 11-15-2012, 07:02 AM   #17
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
Smile
Ill rename mine Jimminy :-D
DanoFA20 is offline   Reply With Quote
Old 11-15-2012, 07:33 AM   #18
killa.sushi.robot
Drives: 12 Sienna Se, FR-S Asphalt 6MT
Originally Posted by Concept-Three-LED's View Post
I had mine fixed about 2 months ago...then had the ECU replaced about 2 weeks ago for the CEL/SCL issue. Right after receiving my FR-S back from the dealership, as soon as I got home (about 10 miles away) the chirping came back...now mind you this is after they already replaced the fuel pump once. I have a sneaking suspicion it's not just due to the fuel pump.
I had mine replaced about 2 weeks ago, was fine for 2 days, chirp came back. I hear it more now, came back stronger.. So sad.
killa.sushi.robot is offline   Reply With Quote
Old 11-15-2012, 04:40 PM   #19
Shagaliscious
Drives: Firestorm FR-S (MT)
This is why I am reluctant. My chirp is not bad at all. The last thing I want is for it to get louder from a "fix".
Old 11-19-2012, 08:32 PM   #20
DanoFA20
Shift Down
DanoFA20's Avatar
Originally Posted by ottopilot View Post
It's never going to be a recall sadly, no safety issue, just noise... :S
i dont know it might be it is a mechanical issue for sure. so my best guess is if you get the chirp and they come out with the final fix, they will most likely contact you if they are a decent dealership. my dealer told me if there are any issues on the TSB list that need to be fixed they will contact every owner that they have sold a car too. they just practice excellent customer satisfaction and great business
Johnston's Toyota of middle town NY gotta say im quite impressed.
the reason it could very well be a recall is because it is the Plunger on the pump that is not seated properly. my guess is that it may not be the exact perfect size or good material that it causes a squeak. since it is a mechanical thing, it will break or wear out over time, that being said it could cause a HPFP failure. but so far the highest milage to date that i know of is somehwhere around 10,000 miles. not enough in my experience as a mech to wear it out all the way. since it is being sort of lubricated by fuel and ethanol. some have thought it is caused by Ethanol but im not too sure thats the case. only time will tell i really hope it can be fixed cause its sort of annoying to me hearing a chirping sound in a brand new car.
Old 09-30-2013, 11:03 AM   #21
JohnnyBeagle
Drives: Scion FR-S
I brought mine in last week and they told me they would order a new part. Then they called the next day and said that I already had the new part and it was "Performing to manufacturer's specifications". I asked them, "If the old one was recalled because of noise, and the replacement part makes the same noise....it seems that your "fix" is simply re-defining the specification, no?"
Dead silence on their end....
JohnnyBeagle is offline   Reply With Quote
Old 09-30-2013, 11:12 AM   #22
sklimo
Fuel pump and speed sensor Tt3Sheppard Issues | Warranty | Recalls / TSB 28 04-20-2017 01:54 PM
Max NA HP on pump gas as of now? jadewbj Engine, Exhaust, Transmission 128 02-17-2016 09:28 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
Dynosty Pushing the Limits... Fuel Pump and Clutch Dustin@Dynosty Engine, Exhaust, Transmission 29 08-15-2012 06:53 PM
Be careful at the pump with E15 Thunderchicken Scion FR-S / Toyota 86 GT86 General Forum 9 08-10-2012 10:33 PM
