Old 01-12-2018, 01:47 PM   #15
churchx
churchx's Avatar
Drives: 2014 GT86
Is body roll really the one that limits your speed in curves? Or it's just your confidence doesn't allow to push more due subjective feels from roll?
On what tires you are driving on track?
The Following User Says Thank You to churchx For This Useful Post:
strat61caster (01-12-2018)
Old 01-12-2018, 04:54 PM   #16
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
It's my understanding that too much body roll makes quicker transitions/weight transfer more difficult, but not enough body roll with cause you to have less grip because there is less weight transfer.
imho, tires play a bigger roll (if not the biggest) in determining how much grip your car has.
it's tough to determine what one element is the limiting factor in maximum cornering speed.
if you have two vehicles with the same suspension setups, but different tires, than sure you can say the tire's grip is the limiting factor.
once you start altering a cars suspension/alignment setup, there are too many variables to pinpoint what is holding you back from achieving your maximum corner speed.
ideally, if you're running time attack, and your car has the correct wheel/tire setup (slicks or competition slicks depending on class) the corner speed factor then shifts from your tire to whatever your suspension setup is.
this is why so many people try different setups, alignments, tires, ultimately trying to find what works best for them and the way they drive.
it's all very speculative and a lot of it is driver preference.
i hope this helps. I am by no means an expert so please correct anything I may have gotten wrong.
JeremyR is offline   Reply With Quote
Old 01-12-2018, 06:17 PM   #17
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by mannjf View Post
Decrease body roll, and keep the rear end more firm around tight curves
If you're trying to "keep the rear end more firm around tight curves", then it sounds like you're already unhappy with the car's tail-happy tendencies? If that's the case, then going to a bigger rear bar is just going to amplify that behavior, not reduce it.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following 5 Users Say Thank You to venturaII For This Useful Post:
Capt Spaulding (01-13-2018), Captain Snooze (01-13-2018), cjd (01-12-2018), FirstWinter (01-12-2018), Icecreamtruk (01-13-2018)
Old 07-26-2018, 06:15 PM   #18
Thaeyo
Thaeyo's Avatar
So I'm using the Perrin rear endlinks on stock away bar. The diagrams that Perrin supply shows flexing/tension on the endlinks with the different spacer combinations.
On my setup, the natural position without flexing is end link towards the front, then 3 spacers to the rear. Correct me if I'm wrong, I wouldn't want flexing right unless I'm looking for a stiffer setup?
Thaeyo is offline   Reply With Quote
endlinks, perrin, polyurethane, rear swaybar
BRZ Polyurethane STI style front lip Spaceywilly Cosmetic Modification (Interior/Exterior/Lighting) 217 10-16-2014 11:34 AM
Strano Performance Parts 22mm Tubular front swaybar Sam Strano Tracking / Autocross / HPDE / Drifting 276 05-20-2014 02:54 PM
FS: Perrin Rear Shifter Bushing green_comet Australia Classifieds 2 11-07-2012 02:04 AM
WTB: Stock WRX 16mm Rear Sway Bar NYC BRZ Cars for Sale/Trade 3 09-01-2012 06:36 PM
