View Poll Results: Motul gear 300 or Redline MT90 for transmission & Differential?
Motul gear 300 193 71.75%
Redline MT90 76 28.25%
Voters: 269. You may not vote on this poll
Old 11-10-2012, 08:20 AM   #15
Nardi330
Nardi330's Avatar
Drives: 86
Does the change of diff oil to Motul Gear 300 make the LSD rougher than stock?
I changed to Redline 75w90NS recently and it's not as smooth as stock in low speed turns. Since Gear 300 is also without fiction modifier like the Redline 75w90NS, I wonder if its rough like Redline. If not I might replace Redline with Gear 300.
Nardi330 is offline   Reply With Quote
Old 11-10-2012, 10:36 AM   #16
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
Since the limited slip in our cars is a Torsen unit and works with gears not a clutch pack...the presence/or not of a friction modifier should not have any effect on the operation of the limited slip in the BRZ/FR-S's.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
The Following 5 Users Say Thank You to BMWDavid For This Useful Post:
AZP Installs (11-12-2012), D1cker (01-28-2015), JesseE (11-13-2012), SomeoneWhoIsntMe (07-22-2014), Tokay444 (09-29-2016)
Old 11-10-2012, 05:12 PM   #17
Nardi330
Nardi330's Avatar
Drives: 86
That's what I thought too so I bought the Redline 75w90NS (no fiction modifier) but its now rough at low speed. I'm lost....
Old 11-10-2012, 06:30 PM   #18
Guillaume
Guillaume's Avatar
Drives: Exige S 240
MT90 did wonders in my 6-speed Aisin equipped Miata.
Old 11-10-2012, 06:36 PM   #19
gmookher
go to motul 300, tracks great. quiet. ester based 100% synth
gmookher is offline   Reply With Quote
Old 11-10-2012, 07:03 PM   #20
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Red Line 75W85 in diff
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 11-10-2012, 08:53 PM   #21
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
i've got redline lightweight shockproof in my diff and transmission at the moment its working extremely well. though due to it liking metal i had my tranny flushed out and cleaned my diff out as well before adding the shockproof.
FreshFRS is offline   Reply With Quote
Old 11-10-2012, 09:24 PM   #22
Nardi330
Nardi330's Avatar
Drives: 86
That's what I have in the gearbox. Seems to be good but I need more miles to confirm.
Seriously consider doing this now but I'll give the redline a few more days and see.
Smooth?
I heard bad things about shock proof so I guess I'd try Motul first. Thanks for your comment tho.
The Following User Says Thank You to Nardi330 For This Useful Post:
TTGT (11-22-2012)
Old 11-10-2012, 09:27 PM   #23
tonystewart
Very smooth
Old 11-10-2012, 09:33 PM   #24
Nardi330
Nardi330's Avatar
Drives: 86
Very smooth
Thx. I guess maybe our diff needs fiction modifier.
Old 11-10-2012, 09:46 PM   #25
gmookher
Negative. We use a torsen. They are unaffected by FM. Thats for clutch packs.
I stopped using the redline stuff in my car after it was overheating on the track, even the MT-90 in my M3 tranny...good luck to you guys. Overheating is easy to read, increased solubles, and half the content..no thanks, but g'head in your car, not in mine.
Please remember its a racing fluid, group 3 base stock based. You know what that means.
The Following User Says Thank You to gmookher For This Useful Post:
Nardi330 (11-10-2012)
Old 11-12-2012, 09:36 PM   #26
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
As No Limit Motorsports said, the Motul Gear 300 works great in both the regular Subaru Transmissions as well as the BRZ/FRS units. We've installed quite a bit of it and it runs wonderful. We carry Redline products but over the years it has had very variable quality control. I since learned that RL doesn't produce their oils but re-brand other ones.
We also have used the Amsoil and love their gear and motor oils as well. You can't go wrong with either Motul or Amsoil in our book. We've been tracking and road racing subies for 10+ years using these fluids.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
The Following 2 Users Say Thank You to AZP Installs For This Useful Post:
flippy (01-16-2013), No Limit Motorsport (11-12-2012)
Old 11-12-2012, 10:07 PM   #27
Nardi330
Nardi330's Avatar
Drives: 86
will be picking up some Motul Gear 300 75w90 in an hour and will replace the Redline 75w90NS which was put in last Friday. the roughness hasn't gone away so the car is now in the garage until Motul goes in just to make sure i don't cause any more damage.....
Old 11-13-2012, 12:42 AM   #28
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Originally Posted by M1K3 View Post
Yes I like:
+1
shu5892001 is offline   Reply With Quote
redline kendalldwhite Scion FR-S / Toyota 86 GT86 General Forum 5 08-26-2012 03:12 PM
Reaching redline. erom Engine, Exhaust, Transmission 27 07-23-2012 07:46 PM
Fr-s vs. Saturn Sky Redline - would your rather Gabriel FR-S / BRZ vs.... 7 06-07-2012 01:57 AM
Engine 7500rpm redline KiingDavid Engine, Exhaust, Transmission 20 03-13-2011 08:04 PM
