#15 |
Drives: Miatas of Various Kinds
Thanks. Sounds like you are the right guy to talk to. Is camber loss an issue then?
DD & STR: 2009 Miata. DD & HPDE: 1995 Miata. Sold: 2004 Mazdaspeed Miata, 1991 CRX, 1977 280Z.
#16 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
As a Subaru guy who has done pretty much everything with his car suspension wise (bushigns, coilovers, whatever, even lifting the car for off-road purposes) I'll chime in...
You can easily get -2.5-3 front camber with camber plates and the stock camber bolts. The stock bolts are good for just over -1.5 as Racecomp mentioned (great guys BTW, they know far more than I do, LOL!). If this is indeed just a take-off suspension from an Impreza, then STI aluminum control arms are an option up front as well, and I'm not 100% on this but they might also modify the suspension angles a bit (more caster too). There are also kits out there for adjusting suspension angles when the car is lowered, at least in terms of the control arm location and tie rods. There are also LOTS of bushing upgrades and other such bits available that you can use in Street Touring classes, and those work wonders. Working with the front suspension is VERY easy on these cars. I can have the front struts off and back on in under an hour with hand tools. Although I haven't worked with the rear multi-link yet... |
#17 |
Hot Dog
Drives: quicker than arghx7
Camber loss on struts is always the problem. It's a dichotomy; run lots of static camber to achieve good contact patch at peak cornering, or zero static camber to get peak grip and stability at WOT and full-brake. You can't have both. This is why some tires are especially designed for strut cars; their carcasses are flexible to stay reasonably stable in a straight line with high static camber.
However, if the car has good roll stiffness, the amount of camber loss up front won't be a big deal, or perhaps even a real problem. With enough roll-stiffness, even -1.5° static will be an acceptable compromise between straightline stability and using maximum tire shoulder in corners.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#18 | ||
- Andrew |
#19 | |
- Andrew |
#20 |
Drives: N/A
Wow. Thanks so much for sharing guys! I thought the number I found was fishy but it sounds like it's normal for Macpherson struts.
#21 | |
Wasn't that hard to do either, just get some weight off suspension and pull it back into place. 15 minute job at most. |
#22 |
Drives: RX8 S1
I had macphersons in my 323, while they are challenged in the 'camber curve' I could run ~2degrees all around (macphersons all around) with the camber plate on neutral and 6 degrees (was just for test never actually drove like that) with camber adjusted to max. I did have coilovers that have a WIDER lower bolt arc slot so it allowed for a very good setup.
By maximum I mean maximum on the bottom and maximum on top combined. The top swing was 4 degrees from start to finish and the bottom swing was 2degrees from top to bottom. But what you really want with a macpherson for auto cross (for my 323 anyway) is decent static camber and as much caster as you can get to increase your dynamic camber in autocross dynamic camber is more important than static
#23 |
Hot Dog
^^Excellent point! Dynamic camber is what's relevant.
#24 |
Drives: RX8 S1
Ooh whoops there wasn't meant to be a dislike thumb there.. Was supposed to be a
![]() I never got more than 4deg positive caster, but some ppl run up to 8 I also only did a few autocross, never really had time...
#25 | |
#26 |
So, by dynamic camber, do you mean instantaneous camber as a function of static camber, compression (or rebound) travel and caster-induced camber?
#27 |
Drives: RX8 S1
Dynamic camber as in anything happening under compression/extension/steering
#28 |
Hot Dog
Exactly.
It's not a perfect system, as dynamic camber is maximum with tight-radii corners. Those that run HPDE/track-days would likely have to run more static camber, as steering angles are less on a track vs. auto-x. At this point however, we're kind of nitpicking a perceived problem that may not exist. We're not familiar with the cars' balance at the limit in various situations [street tire auto-x vs. Hoosier track-days]. The problem may end up being the rear-end camber curve, a roll-center axis issue, or a bump steer problem front or rear. Of what I've seen so far of the suspension, I may hazard a guess that the rear toe-control link might result in too much bump steer with the rear wheels. ...or the car could indeed be close to perfect; who knows at this point. Remember that Porsche's are all strut and they manage to make it work very well.
| MR2 owners - suspension experience | Abflug | Other Vehicles & General Automotive Discussions | 17 | 08-11-2011 09:35 AM |
| interior room concerns | poormans_LFA | Scion FR-S / Toyota 86 GT86 General Forum | 73 | 05-01-2011 10:33 AM |
| Lets talk suspension | Midship Runabout | Scion FR-S / Toyota 86 GT86 General Forum | 42 | 05-20-2010 12:51 AM |
| AE86 handling video... | Blokatos | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 9 | 02-07-2010 04:20 AM |
| Stock suspension adjustability? | #87 | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 01-02-2010 04:36 PM |
