Old 11-02-2011, 03:20 PM   #15
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
12.5:1 static CR with good DI is not a real problem if you want light boost. A quick calculation tells me that with 93 octane, 10PSIg boost would be plausible for a tuned-to-the-edge-but-still-reliable setup, assuming IAT's are kept rational and the knock control as as good as anything from the past 10 model years.
That said, just because the combustion chamber might be able to handle the BMEP, doesn't meant the piston lands, wrist pins, con-rods, crank, bearings, block, head gasket, or cylinder head can handle the increase in BMEP. There is always a fuse, a weak-link, and it'll take testing, measurement, and trial-and-error to determine what's the weak links are to reliably achieve the power level you're interested in.
Since most tuners have minimal real experience with DI tuning, there will either be an influx of amateur engineering experiments flooding the market, or there will be a slow ramp-up by competent tuners that take the time to do things right [which is rare, especially with an affordable car]. By all means, buyer beware!
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 11-02-2011, 03:21 PM   #16
fred_boosted
fred_boosted's Avatar
Drives: 2008 EVO X GSR (Sold)
Originally Posted by RRnold View Post
Just a thought Fred...maybe this might not be the car for you! How about drive it first before deciding if it needs more power. My .02
Thanks for advice.
I owned a 08 EVO X GSR with all bolt ons tunned with 337 AWHP 338 AWTQ.
Stupid people like me think more HP is better, I know that FT-86 is 1000 lb lighter than EVO. But I love turbo... I want put turbo on everything...
That just my plan, I guess lots people want do turbo buld...
I could get Maserati Quattroporte or BMW M3/M6.
But I gived up.
Why? Because thats just not my style.
fred_boosted is offline   Reply With Quote
Old 11-02-2011, 03:24 PM   #17
ryridesmotox
Drives: 2010 Chevy Cobalt SS, 59 Ford F100
what you might be looking at is a flat or even reverse domed piston depending on what they have in there stock.
Honestly if you are going to do a lower end on this thing, a better option would be to..
a) leaving compression alone and upgrading head gaskets and piston rings... that will allow you to run higher cylinder pressure... oh yea and heavier valve springs...
or----
b) aftermarket subaru sti motor with every option you want, and swap ecu and such.
Treadstone Performance Stage 3 kit: CAI, Charge Pipes, TR8 intercooler, Maf Relocate, 52MM Turbosmart BOV, 3 inch catless downpipe, 3 inch catback, borla XR1 muffler, Exedy Hypersingle, TWM short throw shifter, 24PSI HPtuned by Terminator2 on E85/91
ryridesmotox is offline   Reply With Quote
Old 11-02-2011, 03:29 PM   #18
Toyota fr-s
Yes, Toyota fr-s
Drives: 1991 MR2 Turbo T-Top, Gen3 3SGTE
Is the 12.5:1 CR a fact? I read through the entire post and they were just guessing that was it... Then people took off with that idea. just my 5 cents.
Toyota fr-s is offline   Reply With Quote
Old 11-02-2011, 03:30 PM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
No one translated it.. but it's in the engine specs.. not sure what else it would be honestly.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-02-2011, 03:39 PM   #20
fred_boosted
It is CR... I can type japanese and chinese ... 压縮比
But I gived up.
Old 11-02-2011, 04:11 PM   #21
Allch Chcar
Drives: N/A
Originally Posted by fred_boosted View Post
Yes I'm not, just want begin to talk this topic.
And listen to adivces.
Why can't you just say why I'm wrong and tell us how to do thing right?
I am very sorry for offending you. I am not very good at disagreeing.
Logically what you said didn't make sense because a thinner headgasket increases compression ratio.
Others could misunderstand what you said and then believe it to be a fact.
^This +1.
Wonderful! It can always come in handy to have someone with your skills! Like today, Aki and Ichitaka were very busy with work.
Personally, I am very happy that the compression is 12.5:1. It is high enough to be even more efficient with E85 yet still be safe for low boost with pump Gasoline. For turbocharging, a lower compression is usually more inline with most tuner's/builder's goals and safer and more reliable. In this case, I think high compression fits better with 90% of the car's purpose otherwise they would have used one of Subaru's turbo motors
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 11-02-2011, 04:41 PM   #22
madfast
Drives: 2010 Evo X MR-T
12.5 CR means a factory FI option is likely out of the question.
madfast is offline   Reply With Quote
Old 11-02-2011, 05:42 PM   #23
fred_boosted
Never mind, I was so excited about the news so...
Glad that I can do some simple translate work for people.
But I gived up.
Old 11-02-2011, 05:56 PM   #24
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Translate the rest of those tech info scans
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-02-2011, 06:04 PM   #25
Allch Chcar
Drives: N/A
Yes, please! If you would be so kind Fred_boost.
-Allch Chcar
Old 11-02-2011, 06:45 PM   #26
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Ditto
Also when did S2k owner stopped them from SC or TC their S2k. Yes, US had 11.7:1 (vs JP was 12 iirc), that's still high comp for boosted car.
Old 11-02-2011, 06:49 PM   #27
70NYD
70NYD's Avatar
Drives: RX8 S1
diesels are what 17:1? MOST of them are boosted LOL
with petrol, and 12.5:1 you will get low boost but LOTS of power. energy is extracted MORE at a higher comp ratio, so a 10:1 running 10PSI will get more power than a 8:1 running 10PSI
70NYD is offline   Reply With Quote
Old 11-02-2011, 06:54 PM   #28
serialk11r
Drives: '06 AM V8V Coupe
Diesels operate pretty differently, they cannot knock by design as the fuel is injected and burns slowly, instead of all at once (for this reason the diesel cycle is actually less efficient than Otto; effective compression ratio is much worse than the geometric compression because the fuel burns too slow, but since they don't need to worry about knock they just make the CR crazy high to compensate).
New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 584 08-28-2023 08:53 PM
Engine build Maxim Engine, Exhaust, Transmission 41 10-03-2011 09:22 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
Super Bowl! Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 13 01-29-2010 04:02 PM
Super Lap Battle S2KtoFT86 Other Vehicles & General Automotive Discussions 0 12-10-2009 09:46 PM
