CANADA Canada
Old 10-27-2012, 03:10 PM   #15
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Originally Posted by wbradley View Post
Funny, a guy from northern Cali recommending Canadian Tire.
Don't Judge! Maybe he likes our Crappy Tire selections...
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 10-27-2012, 04:47 PM   #16
einzlr
Drives: several
People have been known to relocate in the course of a lifetime you know :P I just said Canadian Tire because they carry pretty much everything.
Asphalt FR-S MT (future)
'05 Hyundai Accent; '01 BMW M Coupe; '01 BMW M Roadster (for sale); '99 BMW Z3 Coupe 2.8l (for sale)
"Simplicate and add lightness." - Gordon Hooton
einzlr is offline   Reply With Quote
Old 10-31-2012, 11:10 AM   #17
Pforwell
Drives: Raven FR-S 6MT
The thought I had was maybe investing in the rain guards that go along the outside of the window. I'm thinking it might help keep the snow off the edge of the window's at the top.
Thoughts?
Pforwell is offline   Reply With Quote
Old 10-31-2012, 11:55 PM   #18
notFRS
Drives: BRZ Sport-tech
The issue, atleast in my case, hasn't been the door rubber seals at the top of the glass. Its the window track getting frozen against the top of the door when the window is all the way up. If you stick a thin card down you can feel that the window clamps are right at the top of the door when closed. Most other cars I've owned there is actually 3inches or so of glass inside the door at all times,this car seems to maybe have an inch tops.
Will probably try a couple drops of lock deicer/methanol down the window where the clamps are before trying to open the door.
notFRS is offline   Reply With Quote
Old 11-01-2012, 12:14 AM   #19
i_4got
i_4got's Avatar
Drives: Whiteout FR-S
So when the windows get frozen to the rubber seals, how did you get your door to open? Did you just scrape the ice off and then tug hard on the door? Or is that bad for the windows?
i_4got is offline   Reply With Quote
Old 11-01-2012, 12:23 AM   #20
notFRS
my windows havent frozen to my rubber seals once.
its been -20 here with freeze/thaw as well, the door opens fine, just the window doesnt drop down its normal 1/2 inch into the door. There really arent any clearance issues with that not happening, I just dont close my door hard not close it by pushing on the glass.
Old 11-05-2012, 06:20 PM   #21
RoryTate
Drives: 2013 Subaru BRZ
This morning it was only -1 and dry, I had difficulty opening the driver's door, and I experienced the same issue with the windows. I got back to my car after work (0 degrees) and the same thing: two window buttons flashing on the driver's side, the windows would not auto-up when the doors closed, and you can't make the passenger window go up or down from the drivers side (you have to use the passenger side switch). I can't wait to see what real winter weather will do.
I picked up some Kleen-Flo Rubber Care at Crappy Tire. There wasn't much to choose from in this category, but it is silicone (and petroleum) free, so hopefully it will do no harm.
I guess I'll find out in the morning if it works or not. My last car had frameless windows as well (Genesis coupe), but I only had issues with the windows once, and that was forgiveable as it was during an ice storm.
RoryTate is offline   Reply With Quote
Old 11-06-2012, 08:12 AM   #22
Wellington
Drives: Scion FR-S
Same as RoryTate here: no ice at all at the bottom of the window nor around the rubber seals and the window jammed while auto-lowering. Later up, when the driver side window eventually agreed to go fully down (and then fully up), it looked like the problem was around the rolls guiding the window inside the door. I could physically feel that there was some ice deposit on them (they spinned irregularly) and there were two large watery prints on the glass, with bits of ice in them. It looks like the occurrence of the problem will be quite unpredictable and difficult to relate to weather.
Wellington 151 Li 196
Wellington is offline   Reply With Quote
Old 11-06-2012, 01:47 PM   #23
wparsons
wparsons's Avatar
Is there any pro or con to having tinted windows? The tint film might prevent a bit of freezing/stiction?
flickr
Old 11-06-2012, 03:18 PM   #24
RoryTate
I recall seeing the moisture on the glass as well. I'm hoping that the trigger was moisture freezing on the weather seal around the top of the window, but only time will tell.
FWIW, I didn't have the issue today after applying the product to the weather seal last night, but it didn't snow or rain in the meantime either.
Old 11-06-2012, 03:44 PM   #25
Wellington
Drives: Scion FR-S
The most annoying thing for me was that water and ice came from the inside of the door and not from any part of the outside window frame. My feeling is that in addition to an eventual accumulation of ice between the window and the seals, there is a good chance that water freezes in the area of the mechanism itself, with no obvious possibility to get access to it.
Old 11-28-2012, 09:20 AM   #26
Captain Insano
Ughhh... Hope mine doesn't do this in the cold now that winter weather has arrived.
Old 11-28-2012, 10:38 AM   #27
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
is there any solution to switch OFF this "auto -up-down for an inch " window feature?
when the doors are covered with ice, sure they need time to melt it, while you are heating the cabin... so why harsh them with forcing the window to "comfortly"scroll up&down automatically when you open and close the door to start the car?
to keep the windows away from sticking to the cabin rubbers I always used silicone spray and it solved any frameless doors problems in the winter
but in BRZ the windows live their own lifes, scrolling when you havent asked them to
this feature should be ON\OFF-able imho
MSTiFK8R is offline   Reply With Quote
Old 11-28-2012, 11:28 AM   #28
Wellington
Drives: Scion FR-S
I have had two new occurrences of windows not going down during the last week and fortunately the glass does not scrape the rubber of the frame of the door. I think that next time I will leave them stuck in that position for the whole winter and not bother with that issue any more.
I would like to point out that every time the window refused to move, it was because of a problem inside the door (probably around the components of the mechanism), never because of glass sticking to rubber. I spent the last five winters with a NC MX-5 and never did the window stick to rubber so I do not expect anything different with the FR-S.
Window tint issues... Normal? Moshpit37 Cosmetic Modification (Interior/Exterior/Lighting) 35 09-11-2013 06:51 AM
What do you look at out your window? nzer Off-Topic Lounge [WARNING: NO POLITICS] 8 10-07-2012 01:59 AM
Auto up and down window Issues? CzRceCar Issues | Warranty | Recalls / TSB 3 08-07-2012 07:44 PM
Pop out window brett_g Cosmetic Modification (Interior/Exterior/Lighting) 10 07-22-2012 10:42 AM
Window Tint Before and After Suiris FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-24-2012 10:37 PM
