Old 11-01-2012, 12:27 PM   #15
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
Originally Posted by celica73 View Post
The last I heard, for just shocks, Koni will start with an insert (you will have to gut the stock housings), then bring a full replacement to market after all the tooling gets ramped up. I've done inserts before, and they aren't too bad.
I had inserts on my 2006 WRX wagon, they work well, the whole process of using a pipe cutter to do it was a PITA
Spartan65 is offline   Reply With Quote
Old 11-01-2012, 12:28 PM   #16
Spartan65
Spartan65's Avatar
Originally Posted by Circuit Motorsports View Post
Yup, not bad if you dont ever want to re-use your stock fronts again.....kind of a pain though.
I already bought a set of fronts from a coil over installer so I could have a set to put the pipe cutter to.
Old 11-01-2012, 12:30 PM   #17
gmookher
Originally Posted by GC_Adam View Post
In talking with Koni, they have told us that Koni engineers in holland only want to do a "cut n gut" style damper on the front because of all the brackets on the factory damper. No talks on doing a 100% straight replacement. The rear should a direct bolt in.
the GC kit I PM'd you on, using koni race shocks is an altogether different setup right? no cut n gut there right, or is THAT what we are talking about?
gmookher is offline   Reply With Quote
Old 11-01-2012, 12:55 PM   #18
GC_Adam
GC_Adam's Avatar
Drives: '08 Impreza, 03 SV1000S
No Cut N Gut, In fact your stock Strut and shock assemblies will not even be disassembled
GC_Adam is offline   Reply With Quote
Old 11-01-2012, 01:14 PM   #19
gmookher
awesome...and on board!
Old 11-01-2012, 01:29 PM   #20
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Spoke with Koni at SEMA.
They confirmed this will NOT be an insert but a full dampener replacement.
FT-86 SpeedFactory is offline   Reply With Quote
The Following 8 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
2fast4you (11-01-2012), dale.m (11-01-2012), Grimlock (11-19-2012), JoeBoxer (11-01-2012), karma003 (11-23-2012), RYU (11-01-2012), Spartan65 (11-01-2012), zoomzoomers (11-01-2012)
Old 11-01-2012, 02:41 PM   #21
2fast4you
2fast4you's Avatar
Drives: 2006 Scion tC RS 2.0
Brake. Turn. Accelerate. Repeat as necessary.
2fast4you is offline   Reply With Quote
Old 11-01-2012, 02:47 PM   #22
Racecomp Engineering
That's awesome news!
- drew
Old 11-01-2012, 02:58 PM   #23
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
I've been working with Koni on this... Koni Holland and Koni NA tend to go back and forth a bit. Koni NA wants a full strut, Holland wanted an insert because making all the brackets can be a big of a problem at times. I've been through this a lot with the Mustang stuff and issues with outsourced brackets being hard for Koni Holland to get.
I haven't spoken to Lee for a few weeks, it seems someone saw him @ SEMA. I hope it is a complete strut, but whatever it is I'm sure the valving will be on the money as it usually is.
Koni has my OEM stuff there in Kentucky to use to compare things. Koni NA knew I had them off the car (I saw Lee Grimes @ SCCA Solo Nationals) and he asked if they could borrow them for measurements, fitting, etc. Being that I'm a big Koni fan myself, I was happy to do it to help the process.
Anyway, when they're ready I'm sure you'll sell lots and lots of spam about it, and I'll have to advertise it too. In the end I can offer two things that most can't. Experience with Autocross (winning experience) and with Koni's (since almost all my National Championships have been on their dampers).
Sam Strano is offline   Reply With Quote
Old 11-01-2012, 05:14 PM   #24
Turn in Concepts
Turn in Concepts's Avatar
What do we have here. . . .
Koni is working with us on getting out some BRZ/FRS stuff. . . .
The initial run of dampers from Koni will be inserts. They expect to have full replacements available late second quarter. The rear is a complete replacement.
Turn in Concepts is offline   Reply With Quote
Old 11-01-2012, 05:50 PM   #25
Koni Yellows with RCE Yellow springs looks good.
Myles is totally a Bilstein guy but I really like the Konis on my Mini.
TIC, are you able to get at the adjustment for the rears without removing the shocks?
- Andrew
Old 11-01-2012, 05:51 PM   #26
RYU
RYU's Avatar
Drives: really slow...
That's fantastic that you're also testing with the RCE Yellows.
Any word on additional perch (height) adjustment and/or rebound adjustment like they have on the S2000 damper replacements?
RYU is offline   Reply With Quote
Old 11-01-2012, 05:52 PM   #27
RYU
RYU's Avatar
- Andrew
Oh SNAP! So you're confirming there is adjustment?
Old 11-01-2012, 06:02 PM   #28
RandyP
Drives: Asphalt FRS
Are they supporting on car adjustment for the rears? The take shock off car and remove spring to adjust concept doesn't work for me.
RandyP is offline   Reply With Quote
Performance Brake Components from ECS Motorsports Hawk | StopTech | DBA & More! AJ@ECSMotorsports Brakes, Suspension, Chassis 32 03-09-2014 12:18 PM
86Drift Exhaust Systems and Components 86drift Engine, Exhaust, Bolt-Ons 11 10-09-2012 05:58 PM
2 way possible in BRZ?? - JBL MS-62C 2 way components stevan Electronics | Audio | NAV | Infotainment 0 09-27-2012 06:35 AM
Components to upgrade for forced induction wbradley Forced Induction 12 09-24-2012 02:11 AM
Boston Motorsports: >>>Whiteline Suspension Components! Boston Motorsports Brakes, Suspension, Chassis 6 07-24-2012 02:07 PM
