Old 10-17-2012, 09:28 AM   #1
dale.m
Captain Slow
dale.m's Avatar
Drives: 2013 Firestorm FR-S
Koni Suspension Components
I got antsy waiting for Koni coilovers, so I decided to email Koni personally. For those of you waiting on Koni products like me, this is great news.
We currently have had a Subaru BRZ on our shop lift for the past 3 days, and the R&D is taking place right now. I am unsure when the components will be available to the public, but we are currently developing these applications. Thank you for you continued support.
Koni North America
Paul Mclaughlin
Technical Sales Representative
1961A International Way
Hebron, Ky. 41048
800-922-2616x504
paul@koni-na.com
I've always run Koni products on my car, whether it's on the track or on the road. I can't wait to see what they will be coming out with!
Dale
Flying and Driving.
dale.m is offline   Reply With Quote
The Following 6 Users Say Thank You to dale.m For This Useful Post:
brz7400 (10-17-2012), Guff (10-17-2012), MattR (10-17-2012), MVJ1975 (11-01-2012), raz0rbladez909 (10-17-2012), Superhatch (11-01-2012)
Old 10-17-2012, 09:35 AM   #2
celica73
The last I heard, for just shocks, Koni will start with an insert (you will have to gut the stock housings), then bring a full replacement to market after all the tooling gets ramped up. I've done inserts before, and they aren't too bad.
The Following User Says Thank You to celica73 For This Useful Post:
No Limit Motorsport (10-17-2012)
Old 10-17-2012, 10:08 AM   #3
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I personally hate inserts, but Koni makes some great dampers. Konis (or Bilstein Sports) with Ground Controls should be a great setup once they are all available.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
GC_Adam (10-17-2012)
Old 10-17-2012, 10:11 AM   #4
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
I bet it is going to be an insert for the front, and a bolt in for the rear.
No Limit Motorsport is offline   Reply With Quote
The Following User Says Thank You to No Limit Motorsport For This Useful Post:
AZP Installs (11-12-2012)
Old 10-17-2012, 10:15 AM   #5
dale.m
Captain Slow
dale.m's Avatar
I ran this exact setup on my D Street Prepared 2002 VW GTI and won just about every autocross I entered by a good second or two. I'm considering a similar setup for this car as the control arms look like they could take a 20mm-30mm drop.
Flying and Driving.
Old 10-17-2012, 11:35 AM   #6
D1cker
Drives: B9 S4/ND2
Ground Control has a kit almost ready to go using Koni Race shocks. Once I have it, I'll post info and pictures
D1cker is offline   Reply With Quote
The Following 4 Users Say Thank You to D1cker For This Useful Post:
dale.m (10-17-2012), GC_Adam (10-17-2012), JoeBoxer (10-17-2012), MattR (10-17-2012)
Old 10-17-2012, 02:09 PM   #7
xwd
Yeah the GC setup uses an insert into their own strut housing for the front. Koni hasn't made a true strut replacement for Subarus for a long time since the volume wasn't there but lots of folks use their inserts and they aren't hard to install. Maybe with Toyota on board they will make a true front strut replacement. Finding some takeoff struts isn't too hard but an added expense.
Old 10-17-2012, 02:22 PM   #8
Racecomp Engineering
Turn In Concepts will be testing these soon with our RCE Yellow springs. Very excited.
I run Koni Yellows on my MINI and love them.
- Andrew
MattR (10-30-2012), siXXtoes (12-14-2012)
Old 10-17-2012, 03:03 PM   #9
GC_Adam
GC_Adam's Avatar
Drives: '08 Impreza, 03 SV1000S
In talking with Koni, they have told us that Koni engineers in holland only want to do a "cut n gut" style damper on the front because of all the brackets on the factory damper. No talks on doing a 100% straight replacement. The rear should a direct bolt in.
GC_Adam is offline   Reply With Quote
Old 10-17-2012, 03:59 PM   #10
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Hopefully they play well with stock springrates for us RTR/CS guys
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 10-17-2012, 04:08 PM   #11
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Yup, not bad if you dont ever want to re-use your stock fronts again.....kind of a pain though.
Circuit Motorsports is offline   Reply With Quote
Old 10-17-2012, 07:18 PM   #12
simpleisbest
Senior Citizen
Drives: Scion FR-S
Lame! You would like to think that with the potential numbers from the FR-S alone, they would be more forward thinking than that....
simpleisbest is offline   Reply With Quote
Old 10-17-2012, 07:21 PM   #13
xwd
They are generally built and valved for the stock springs since they assume that's what you'll be using. Getting them revalved is not all that expensive either if you want something custom. I know a number of vendors are working with Koni on setups including Sam Strano who has CS/RTR in mind.
Old 10-17-2012, 09:13 PM   #14
ModBargains
ModBargains's Avatar
Drives: FRS, M3
Whatever KONI comes out with for the FRZ / BRZ will be top notch as they always are.
ModBargains is offline   Reply With Quote
Performance Brake Components from ECS Motorsports Hawk | StopTech | DBA & More! AJ@ECSMotorsports Brakes, Suspension, Chassis 32 03-09-2014 11:18 AM
86Drift Exhaust Systems and Components 86drift Engine, Exhaust, Bolt-Ons 11 10-09-2012 04:58 PM
2 way possible in BRZ?? - JBL MS-62C 2 way components stevan Electronics | Audio | NAV | Infotainment 0 09-27-2012 05:35 AM
Components to upgrade for forced induction wbradley Forced Induction 12 09-24-2012 01:11 AM
Boston Motorsports: >>>Whiteline Suspension Components! Boston Motorsports Brakes, Suspension, Chassis 6 07-24-2012 01:07 PM
