Old 10-15-2011, 05:25 AM   #15
Farred
Farred's Avatar
Drives: my wife crazy
this has been my idea on slotted and cross drilled rotors for years.
http://www.rx7club.com/showthread.php?t=480082
"More facts about rotors. May the great myth of drilling rotors for improved cooling finally die...
Darrick Dong; Director of Motorsports at Performance Friction.
"In the days of asbestos pads there was a gas boundary layer that appeared at the interface area of the pad and rotor. Although that gas boundary layer still occurs it is much less of a problem with modern friction materials. Slots are more than adequate to carry that gas away. Years ago that gas boundary, along with reducing weight, led to the popularity of drilled rotors. However, in the intervening period, the myth has persisted that cooling is the main reason for drilled rotors. Anyone that tells you that drilling makes the disc run cooler is smoking crack."
Why is Dong so adamant? Because he works with racing brake systems for a living and it isn't too hard to take two identical rotors, drill one of them and slot the other, put them on a brake dyno and measure temps and life.
Darrick Dong; Director of Motorsports at Performance Friction."
also doesnt cross drilled reduce the amount of surface area for the rotor?
Farred is offline   Reply With Quote
Old 10-15-2011, 07:36 AM   #16
Matador
hashiryu
Drives: Mk4 Supra
All the arguing over something Trivial, and nobofy notices those MAD coilovers or the brake cooling ducting.... smh @ u guys.
Welcome to FT86club.com
The 'FT' stands for 'forgot topic'.
Matador is offline   Reply With Quote
Old 10-15-2011, 07:54 AM   #17
Nurburgring
Drives: S2000, AE86, RSV10000R, 911, EP91
Matador, it is unfortunate but we should actually expect the "FT86 scene" to be full of hellaflush/stance/jdm retards and posers. Nothing new there.
Drilled rotors for a race car? you guys have certainly swallowed the marketing bullshit all the way through. They belong to show and drift cars, real racing cars will always use plain or slotted; drilled tends to fracture in the area surrounding the holes.
This in an actual Toyota F1 car brakes:
This is the Audi R10 LeMans winner brakes:
These are NASCAR brakes:
And this is what happens to your typical aftermarket drilled rotor in a race enviroment:
Nurburgring is offline   Reply With Quote
Old 10-15-2011, 08:10 AM   #18
Farred
Farred's Avatar
ed zachary
Old 10-15-2011, 11:24 AM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Slide View Post
Lol this from a guy who has a race preped car... Says slotted/drilled discs are for show wow...
Its really hard to find road race cars with drilled rotors and it's for good reason. Slotted and drilling (on the road, slotted does have some benefits off road) fixes a problem that hasnt existed in what 40-50 years now? Pad off-gassing is no longer an issue with modern brake pads. Drilling rotors makes them weaker. Rotors cast with the holes are stronger but all suffer from having less mass. Less mass means less heat holding capabilities. That in turn means less heat is taken out of the cars braking system (pads, calipers and fluid). You also have less friction area as the pad doesn't create friction against air.
To make a modern analogy take a computer CPU and think of it as the caliper assembly and think of the heat sink as the rotor. Do you want a small heatsink with an uneven mating surface (slotted/drilled) or a nice large smooth surface?
On a street car you are less likely to see any problems (the worst I've seen is extensive cracking) but on the track you'll see them break sometimes (not often but I've seen it twice in person, one of which resulted in a NSX slamming into a wall at Sebring).
On the show side people think they look cool so they end up on expensive street cars because most people who buy those cars want that. Every Porsche race car (factory and independant) that I've seen in person have blank rotors yet every (or most?) street p-cars come with drilled.... (cast that way)
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-15-2011, 11:32 AM   #20
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Lol yesterday I tried to zoom and read the numbers on the spring to figure out the rate but I failed. I like the ducts (and did see them) but they must have another piece to bring the air closer to th caliper or center of the rotor.
Beyond them looking pretty they don't help any if us much
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-15-2011, 11:35 AM   #21
70NYD
70NYD's Avatar
Drives: RX8 S1
Slotting it reduces the surface area as well. Drilling it leads to a weaker rotor than a slotted, but in reality, ideally, drilled rotors should be done so in a certain manner, for best gas extraction I won't go in to it cus there is no point, but on paper, drilled removes brake gas buildup faster.
70NYD is offline   Reply With Quote
Old 10-15-2011, 11:55 AM   #22
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
Nurburgring and Dave - thank you for taking the time to explain that so I didn't have to. I don't know how many times I've advocated for blank rotors and everyone tries to argue. We don't have to worry, though. Toyota won't put anything other than blanks on the FT.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 10-15-2011, 11:57 AM   #23
NESW20
2.1L 3SGTE
I wonder if they'll offer the air jack setup as an option..........
2008 Civic Si Sedan
Old 10-15-2011, 12:04 PM   #24
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'd buy that option in a heartbeat!!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-15-2011, 04:26 PM   #25
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
yeh porsche must be doing it wrong with the best braking car in the world hey? factory "drilled" rotors arent actually drilled, they are cast like that. its not for better cooling its for weight reduction.
czar07 is offline   Reply With Quote
Old 10-15-2011, 05:02 PM   #26
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
pretty sure it is fixed... definitely funky looking though
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 10-15-2011, 05:44 PM   #27
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I already addressed why porsche sells "drilled" (and mentioned rotors cast with holes) and pointed out that they RACE with blanks.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-15-2011, 06:31 PM   #28
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Supra (MkIV) had shortest braking for longer time than Porsche (til '04) and Supra had a plain rotor
Inside Line's Predictions (Subie Version) GT Engine, Exhaust, Transmission 13 05-23-2014 09:32 AM
PTuning Spec RS *pics inside* Dragonitti Other Vehicles & General Automotive Discussions 121 11-19-2011 11:52 PM
Heritage....inside? Maxim Scion FR-S / Toyota 86 GT86 General Forum 10 01-03-2011 08:17 PM
FT86 concept with a guy inside 4agze Scion FR-S / Toyota 86 GT86 General Forum 2 11-12-2010 03:16 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
