Old 11-04-2012, 01:41 PM   #15
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Red Line 75W85 equals quiet
2271 miles
Red Line 75w85
Didn't tell my daughter, got a "did you do something to my car?, it sure is a lot quieter back there"
Thank you Red Line
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 11-04-2012, 02:11 PM   #16
gmookher
tellin ya, stock fluids in this thing are weaksauce
gmookher is offline   Reply With Quote
Old 11-04-2012, 02:53 PM   #17
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
Originally Posted by tonystewart View Post
2271 miles
Red Line 75w85
Thank you Red Line
Quieter how? My differential seems to have a resonance at around 70 MPH; I wonder if a different fluid would help.
Subie is offline   Reply With Quote
Old 11-04-2012, 03:20 PM   #18
gmookher
07+ STIs use motul 90 PA
for our car I put in Motul Gear 300 75W90, lovin it
yes quieter 100% synthetic ester based oil, good stuff
Old 11-04-2012, 04:02 PM   #19
tonystewart
Hum or resonance that you speak of was reduced.
The Following User Says Thank You to tonystewart For This Useful Post:
Subie (11-06-2012)
Old 11-04-2012, 04:21 PM   #20
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
04-06 STI = 90PA
07+ STI = Gear 300 or Gear 300 LS
No Limit Motorsport is offline   Reply With Quote
Old 11-05-2012, 05:28 PM   #21
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
We changed our diff fluid at 500 miles, and look at what came out.
Amsoil Severe Gear / Redline Gear oil / Motul Gear oil
As long as GL5 synthetic, it will work well with our Torsen rear diff.
Touge Factory is offline   Reply With Quote
Old 11-06-2012, 10:09 PM   #22
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
I switched mine out today, had alot of metal particles, used Motul oil from NoLimit...
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
The Following User Says Thank You to *KID* For This Useful Post:
No Limit Motorsport (11-08-2012)
Old 11-06-2012, 10:23 PM   #23
gmookher
Originally Posted by No Limit Motorsport View Post
04-06 STI = 90PA
my bad. thanks for fixing it.
The Following User Says Thank You to gmookher For This Useful Post:
No Limit Motorsport (11-07-2012)
What oil to use in your Engine, Trans, Diff? ArKiTeCkT CANADA 31 03-10-2018 03:23 PM
T1R Rear Diff colars ! AJ PwR Engine, Exhaust, Transmission 0 10-09-2012 10:00 PM
Cusco Rear Diff Covers!!! Cusco LSD Units! vividracing Transmission and Driveline 0 06-18-2012 03:24 PM
Cusco Rear Diff. Jewelry Blaaaack-BRZ Engine, Exhaust, Transmission 24 05-12-2012 03:28 PM
