Old 11-30-2012, 06:57 PM   #15
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
MODS PLEASE STICKY THIS!!
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 11-30-2012, 07:34 PM   #16
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
BTW Essex Sprint needs at least a 10MM spacer to clear the OEM wheel.
Will sticky this for now, if it doesn't get updated more often there's not much reason to leave it as a sticky though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-30-2012, 07:40 PM   #17
Hanakuso
Are you sure? I was almost certain 7-8mm would be good enough.
Hanakuso is offline   Reply With Quote
Old 11-30-2012, 08:05 PM   #18
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You need some space for the expansion of the calipers and other components as they get hot. With a 10mm spacer it appears to have maybe 2mm of clearance.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-11-2012, 12:18 AM   #19
RavenFR-S
I have a request.
Will someone do these patterns, please?
Brembo GT Front 345x28mm (Use for Front and back)
http://www.carid.com/images/brembo/p...-1b1.8002a.pdf
Brembo GT 2-Piston Rear 316x20mm
http://www.carid.com/images/brembo/p...-1b1.7017a.pdf
RavenFR-S is offline   Reply With Quote
Old 01-09-2013, 03:49 PM   #20
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Some confirmed wheel fitments without spacers on our Essex Sprint and Endurance Systems:
Sprint
Enkie RPF1 17x8 45
Wedsport TC105n 17x9 35
Mach V Motorsports "Awesome" wheel 17x9 42
Work Ultimates 18x8.5 47
Sparco (designed by OZ) Assetto Gara 17x7.5 48
Endurance
Enkie RPF1 17x8 45
BBS CH-R 18x8 38
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
The Following User Says Thank You to JRitt For This Useful Post:
shaunsweeney (12-19-2013)
Old 01-31-2013, 09:03 AM   #21
ICantAffordAnLFA
ICantAffordAnLFA's Avatar
Drives: Brz, Legacy
Just tried a few templates on my Rays CE28 18x7.5 47 offset wheels
The following were ok.
Essex AP Sprint , Essex AP Endurance, AP 4 pot formula bbk and interestingly the endurance had more caliper space than the sprint on these wheels.
The following didn't fit
AP 6 pot formula bbk ( calipers caught on spoke )
4 pot AP FBBK
Sprint
Endurance
Trackday ride with built motor
Mods: Going, Stopping, Handling
Parts: CP, Pauter, Sprintex, Ecutek, Milltek, STI, Rays, Defi, Essex AP Racing, Bilstein, Whiteline, Perrin, RacerX
ICantAffordAnLFA is offline   Reply With Quote
Old 01-31-2013, 10:02 AM   #22
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You can add my WedsSport TC105N 18x8 +42 and 08-12 OEM Subaru STI Brembo brakes.
The Following User Says Thank You to King Tut For This Useful Post:
SkAsphalt (11-28-2013)
Old 02-04-2013, 11:40 AM   #23
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Hi guys, need advice on whether the essex sprint bbk will clear Work kiwami 18x7.5 +38?
Fizz is offline   Reply With Quote
Old 02-20-2013, 03:13 PM   #24
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Can anyone chime in and say they have used the OEM wheels with the Sprint Kit with 10mm spacer or whatever they are using? I read that if I run a spacer larger than 5mm that I will need new/longer lug bolts. Is that also true? I'd rather not spend extra $ on new wheels if I don't need to. I run the OEM wheels with winter tires and 18" Neuspeed RS10 with RE11s so I'd rather not buy more wheels.
stockysnail is offline   Reply With Quote
Old 02-20-2013, 03:33 PM   #25
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I would suggest longer studs for sure. They are pretty cheap and easy to install or you could go with a 15mm spacer that includes them on the spacer itself, then it's real quick.
They need 10mm spacers. I haven't driven the car with them but I use an OEM wheel/tire as my spare tire so I carry the 10mm spacers just for that. I am running ARP extended studs in my car.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-01-2013, 08:07 PM   #26
Delsy
Delsy's Avatar
Drives: Gt86
Hi, I installed 18 x 8.5 w/ 45 offset, would brembo 4 & 6 piston BBK will fit? Thanks
Delsy is offline   Reply With Quote
Old 03-01-2013, 08:22 PM   #27
Gambit
Gambit's Avatar
Drives: Subaru
Ask for an installation cutout diagram that you can test fit to the wheel in order to check clearance
Gambit is offline   Reply With Quote
Old 03-13-2013, 01:36 AM   #28
mike@vossen
Drives: GS F-sport | LS F-Sport
I wish there were pics installed with wheels to see.
mike@vossen is offline   Reply With Quote
big brake kit, brembo, essex, stoptech, template
Dyno Database E92M3Guy Engine, Exhaust, Transmission 33 04-17-2013 11:20 AM
The *Official* BRZ Pre-Ordered Database Thread Zaku BRZ First-Gen (2012+) — General Topics 727 03-17-2013 08:29 AM
We should start a dealer BRZ order database eikond BRZ First-Gen (2012+) — General Topics 13 03-01-2012 01:56 PM
