#15 |
Drives: Some rust bucket
so this begs the question of why are people 'overtiring' their wheels with 255 on 17x8 rims? for looks, i can understand, but there are some members who track their cars and still oversize their tires. hmm....
#16 |
form follows function
Drives: RIP '13 BRZ
I autocross. People in my region have turned fast times with the setup. I knew it would be excessive, but I wanted to work my way down through the sizes so that I'd have experience with different size / width combinations. There's a saying to do your last experiment first, and 255 was the widest I'd ever try to cram on an 8", so I went for it. I'll go 245 next, and if I like the way it changes the car I'll keep going down in size until I start losing time. So I'm doing it for experience. I'm not going to be winning any events anyway, so nothing really lost.
#17 | |
#18 |
Drives: Nevermorange FRS
Very good information in this thread. Keep in mind that in most of this information be presenting it is in terms of "optimization" not "diminished results".
Example: A: I have a 225/45/15 tire so running a 15x8 or even a 15x9 will improve the way that tire performs vs running a 15x7 wheel. B: I have a 15x7 wheel. If I increase the size from 195 to 225 will I see a improvement in cornering forces. Both A and B are correct and A does not cancel B. Just because it's optimal to run a 8 or 9" wheel with my 225's does not mean that the 225's on my 15x7 won't be an improvement over my 195's or 205's. I personally have racing data that backs up this point. It makes sense to use a wheel width that is within spec of tire manufacturers recommended width. Example: Hankook Ventus RS3 in 225/45/15 Recommends a 7"-8.5" wheel. http://www.tirerack.com/tires/tires....num=245WR5Z222 If you look at that chart for that tire, Hankook doesn't recommend a 9" wheel until you reach a tire with a section width greater than 10". Interdasting! (255/40/17) So running "over-tired" is not going to decrease performance until you reach the point of diminishing return: Tire breaks the bead, Tire can't actually be mounted, not all the contact patch is being utilized, engine isn't strong enough to turn those big heavy tires etc etc etc. Conversely running tires wider than your wheels is WAY better then running tires skinnier than your wheels. Just say no to Hella Flush. Here's a picture of the 225/45/15 Toyo RA1 on my 15x7 wheels. As you can see they aren't exactly "struggling" on those wheels. (only pic I had of tire mounted on my wheels) BTW: that dent is thanks to a Spec Miata. ![]() I love testing tires. In 2011 I raced on Toyos, Goodyears, Hoosiers and Hankooks. This year just Hoosier and Hankook but next year I'm looking forward to the new Toyo RR. Tires as of mid season last year: (and those were just the Toyos!)
#19 |
I agree and to put it more succinctly go wider unless you have a tire with floppy sidewalls. The increase in ultimate grip is going to outweigh the decreased feel and turn in response. Now if you are drifting or something that's another story since you actually want less grip.
#20 |
i'm sorry, what?
Drives: Canada
Generally speaking, autocross is a very poor way to actually test tires. Too many factors that affect your consistency, the two biggest one is the fear of hitting a pylon and the long wait times between runs.
#21 |
On track, having a 255 on a 10" width wheel is only a couple tenths faster on a consistent basis. How the S2k Challenge base their point system is through the testing on Buttonwillow Raceway. There is sufficient data to support the 255 on 10" vs the 255 on 9". The difference is approximately 0.25 seconds on a 2.68 mile track, hence the 0.25 point penalty. The key is consistency at this point. Also, I'd like to point out the S2k guys run either NT01s (R-comps) or Hankook RS3s/Dunlop Z1SS. Everything else is too expensive and unproven to go faster that those setups thus far.
On a side note, autocross guys stuff a lot of tire because in the end, grip is grip, so more tire helps give you as much possible grip you can get on your car for the autocross course. The speeds are not fast enough to cause you to slow down. On large tracks, too much tire on a particular car can actually scrub off speed in your corner, reduce the speed on the straights, etc. This is why some guys running 255s on the BRZ/FRS are not running any faster than guys with the 215 size tires. Now if the car was turbo'd, then 255s are the faster way to go...:p |
#22 | |
Drives: Scion FR-S
#23 | |
Regardless, without enough camber you'll have excess front shoulder wear. I've tracked on both 215 and 235 tires on 8" wheels (i.e., slightly stretched vs. slightly pinched), and either way I wore the front shoulders @ -1.5 degrees camber. Don't worry too much about it. You can rotate the tires to even the wear (rear suspension gains significantly more negative camber on compression so wears more evenly) and your tires should last you a decent number of events. Just go have fun for now and add camber adjustment to your list of future mods.
2022 BRZ Build 2013 FR-S Build |
#24 |
Drives: '15 BRZ RA
You should not change too much the geometry of the tire. Saying that, a bit of stretch is not bad. Even factory does this. The new power package uses the same 215 tire on a +0.5'' wheel (215, 7.5'' width).
#25 |
Drives: Toyota GT86
Back home the thumb of rule is the recommended rim size and upp to widest rim size, preferably the upper half of the recommended too get some stretche on the tier as you mentioned.
Toyo R888 http://www.toyor888.net/racing/index.htm http://toyotires.com/tire/pattern/pr...petition-tires ![]() Kuhmo Ecsta V70A http://www.kumhotyre.co.uk/Motorspor...rochure01.html ![]() Yokohama A048 http://www.yokohamatire.com/tires/detail/advan_a048
#26 |
Drives: PEARL WHITE GT86 TRD
I've had some good results running the stock high spec tyre sizes (215/45/17) on 17x8 rims.
My 2c. |
#27 |
Drives: 15 BRZ LTD, 05 FXT
While I don't think anyone can just go ahead and test a tire in autox, a good driver certainly can. I've ridden with drivers that can consistently turn in runs within a 10th of each other, and with a tire change their next set of runs is just as consistent at a different time.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
#28 | |
Drives: 2014 FR-S
The bolded is why I do it. Stock/Street doesn't give you a lot of knobs to adjust, so you do what's available. Doesn't matter if it feels bad or is a bass-ackwards methodology. It absolutely might not work for some folks' driving styles. In the end, use the scoreboard as your measure. As a practical matter, it also lets me get away with some dumber/more aggressive tactics. Brake later without fear of abs intervention, get back on the gas sooner without wagging the tail so much, it's more material to heat up, so it's harder to overcook them (also harder to get heat into them...).
-Mike
#24 CS/CSR |
| Throttle slightly sticking? | Dzeremijs | Issues | Warranty | Recalls / TSB | 13 | 02-01-2013 01:27 PM |
| FS: Gramlights 57d 17x9 +38 5x114.3 w/ tires 1500 miles on tires, $1800 shipped | apexsti46 | Wheels and Tires | 6 | 09-05-2012 02:54 AM |
| What tires? | firebug451 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 04-24-2012 03:05 PM |
| 2014 Cars slightly more expensive? | Buggy51 | Other Vehicles & General Automotive Discussions | 10 | 02-29-2012 09:24 PM |
| Stretched FT-86 chassis to spawn next generation Lexus IS | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 12-02-2010 02:27 PM |
