Old 09-28-2012, 12:13 PM   #15
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Got Morel Elates's in the front bi-amped and it sounds wonderful. Using a DSP and it pushes the stage out very nicely. Without the DSP it still sounds very "good" to normal people. The midbass is VERY tight now that's I've matted both doors.
michaelahess is offline   Reply With Quote
Old 09-28-2012, 01:01 PM   #16
so26
Drives: Raven FR-S 6MT
Originally Posted by JoeBoxer View Post
The dash speakers are 4ohm, the only ones that are 2ohm are the ones in the doors which run off the amp in the back of the car.
Yes, both the tweeter and mid in the dash are 4ohms but connected in parallel therefore the HU sees a 2ohm load for the pair.
so26 is offline   Reply With Quote
Old 09-28-2012, 02:26 PM   #17
Z0rr0
Drives: 2013 Raven 6MT FR-S
How do you think that L6 is going to work off the factory amp which is only putting out 33w @2ohm? I'm tempted to put my Trinity's in the dash and leave the door speakers alone but i will wait on your review before i go any further.
It'll work for normal levels, but i'm not about to push it up higher in volume without better amplification.
When i talked to scott @ Hybrid Audio, he said to bandpass the L6 50hz-250, and Highpass the L3SE from 250hz - up.
should sound incerdible when all the processing is setup and properly EQ/Time ' ed..
Z0rr0 is offline   Reply With Quote
Old 09-28-2012, 02:41 PM   #18
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Oh really thats good to know so how are the frequencies broken up for the mid and tweet? is there a cap on the mid or something? I think i'm just going to leave the front stage alone until i can do it right after seeing this info.
Zorro do you think i should try the Trinity's or wait until i can get an amp and do it right?
JoeBoxer is offline   Reply With Quote
Old 09-28-2012, 03:04 PM   #19
michaelahess
Wait for an amp, the stock one is a joke.
Old 09-28-2012, 04:36 PM   #20
so26
... so how are the frequencies broken up for the mid and tweet? is there a cap on the mid or something?
Yup, there are caps on the mids and tweeters.
Old 09-28-2012, 05:38 PM   #21
JoeBoxer
JoeBoxer's Avatar
Yeah i guess i am going to just install my MSBassPro SQ and go from there, i may replace the stock 6.5's with some 2ohm JBL Power mids if i can find somebody to sell me some seperately and then just sound deaden the hell out of the car.
Old 09-28-2012, 05:52 PM   #22
JoeBoxer
JoeBoxer's Avatar
Originally Posted by Z0rr0 View Post
I have Hybrid Audio L3SE's in the dash. 3.7" Wideband driver.
I am going to put in my L6V1's in the doors this weekend.
currently running off the factory deck, plan on installing my amps/carpc setup in a few weeks.
but with the L3SE's and no tweet the sound quality and imaging is fantastic! Can't wait for amplifiers!
Did you put the cap back on the L3SE or are you running it full range?
Old 09-28-2012, 06:27 PM   #23
Z0rr0
Full Range. (I do not push them) I did not move the cap over. I took the connector off the stock speaker, and connected the 2 wires to the L3SE. the tweeter was disconnected by clipping the leads, that way i could solder them back if i went back to stock.
i'd wait until you have a decent amplifier. I was just wanting to play with my new toys.
It's kind of like masturbation when you are still a virgin, fun in it's own right, but not nearly as good as the real deal HAHAH
Old 09-28-2012, 07:31 PM   #24
JoeBoxer
JoeBoxer's Avatar
Bahaha i appreciate all the info i'm still not sure what i want to do up front the sub stage is handled though.
Old 09-28-2012, 10:10 PM   #25
michaelahess
I still have to do the rear quarters and wheel wells, but the car is twice as quite already as it was. Haven't even done the ceiling or floor yet either actually. The doors and trunk are very noisy.
Old 09-28-2012, 10:49 PM   #26
JoeBoxer
JoeBoxer's Avatar
I've added a little on the trunk lid and in spare tire well but not enough to tell a difference. I think i'm going to do the doors, the rear interior panels and do a better job in the trunk.
I've got my amp install kit ordered to hook up the JBL powered sub.
The distributor for H Audio/Audible Physics is going to put a cap on the 3" speakers i'm buying so they will be ready to drop in and i won't have to add an amp or separate crossover for now. Guess i am replacing the speakers now too and putting the Ebony 6.5's in the doors for the midbass.
Old 09-28-2012, 11:19 PM   #27
-max-
Drives: Firestorm FRS
The rear deck really sucks also when you add a little bass.
-max- is offline   Reply With Quote
Old 09-29-2012, 11:02 AM   #28
simplicityinsound
simplicityinsound's Avatar
Drives: 2010 Subaru LGT
now that i got a FR-S under my belt, i can chime in.
stock locations 2 way, 6.5" mid in door, 1" tweeter in stock 3" location, full DSP, active.
it does quite well, i playd around on the rta for about an hour and then tuned by ear for an hour. center is very solid with GREAT depth, width is pillar to pillar but not beyond, height is a few inches above dash level whcih for me is perfect.
tonality wise, obviously i need more time, but with the stock locations, i can see some small reflection issues, on the rta, most notably the spike in the upper freqs, 16k to 20k, though its doubtful you can really hear it.
there are also some valleys and dips that i was able to correct pretty quickly with the eq...
here is a shot of the curve i got while i was wokring, this is before i finalized things...then i turned off my computer without taking another screen shot.
the bump at 80hz was easily fixed, i simply had the sub at a 24 db vs 12db.
the things to note that i think were a result of the reflection and location of the tweeter:
the 16-20k bump and there are some small spikes between 5k and 16k, but most were quickly toned down. (the final curve looked a lot smoother uptop)
of course the speakers also have something to do with it.
so basically, i would say, a dash mat of some type would definetly help in this car, though off hte bad right now, it still very good.
i was also surprised that despite having a closed off trunk with no rear deck speaker, the bass came through quite well
so i would say...stock locations works well for sq
if you want to make it better, get a nice plus dash mat
if you want to really make it be the best you can get, i would recommend molding the stock location to house a 3" driver tilted back at you a bit. and if you do a 3 way, mold the tweeter into the A pillars.
thats how i would do it if i were to approach a FRS/BRZ with highest possible SQ being the goal
simplicityinsound is offline   Reply With Quote
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
Initial D Stage 5 release this year! 5hairpins Off-Topic Lounge [WARNING: NO POLITICS] 279 07-24-2014 09:41 PM
Exhaust Stage enkubus Engine, Exhaust, Transmission 3 08-14-2012 09:31 PM
Initial D stage 5 86boyAF1 Off-Topic Lounge [WARNING: NO POLITICS] 7 08-08-2012 10:00 AM
Battle Stage 2 trueno86power Other Vehicles & General Automotive Discussions 2 09-26-2011 03:04 PM
