Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
09-26-2012, 12:21 PM | #15 | |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Second, changing the intake around the PRIMARY air/fuel sensor will definitely change things if you don't get a tune. Third, the ECU can only compensate for a skewed MAF while in closed loop mode. It can only GUESS when you're in open loop. And considering that the ECU enters Open Loop when being driven hard, and the higher rate of the air in the intake can change the shape of the flow around the MAF, you have no idea how an intake will effect your fueling when you're at full throttle. Intakes without tunes are never a good idea. |
The Following User Says Thank You to Draco-REX For This Useful Post: | ill86 (09-26-2012) |
09-26-2012, 12:24 PM | #16 |
VehicleDynamicsSpecialist
Drives: iG FR-S
^ what he said. Your a/f mixture is off bc of the intake. You're off throttle/back on throttle (tip in).
"The best track modification you can ever make is between the steering wheel and seat." - CSH |
09-26-2012, 12:26 PM | #17 |
Berz
Are you sure it's backfire and not pre-fire? Some intakes are known to pre-fire, and the noise is coming from the intake itself, not the exhaust.
09-26-2012, 12:26 PM | #18 |
Scrape Master
Drives: Goal: Oldest FRS State Side
i might have to buy this intake now :o
09-26-2012, 01:28 PM | #19 | |
Drives: Scion fr-s
And i know octane won't change anything on A/F but will change on timing and timing is a factor when having backfire... |
09-26-2012, 01:29 PM | #20 |
Drives: Scion fr-s
And I knew the A/F could be off a little bit, i just didn't think it could be that off.
And the fact that nobody I know with this intake as this problem, therefore i tought maybe there was something else. |
09-26-2012, 02:04 PM | #21 |
Buzz Killington
Drives: A slow truck
Not really a backfire. A backfire is when you get combustion in the intake system of the car and is a problem. What you are experiencing is most likely unburned fuel igniting in the hot exhaust system. In some vehicles, when a driver shifts up and lets off the accelerator, the engine has a moment of running rich. This causes an incomplete burn which causes the fumes to explode in the exhaust system along with an audible pop or bang sound.
09-26-2012, 03:39 PM | #22 | |
Vtec Jesus
This happens running rich or not. |
09-26-2012, 04:13 PM | #23 | |
Drives: MBC300
The Following User Says Thank You to DR1FT For This Useful Post: | 20valvewynn83 (09-26-2012) |
09-26-2012, 04:19 PM | #24 |
Buzz Killington
How is that going to hurt an engine? Provided his AFR is within spec, a little unburned fuel igniting in the exhaust system is perfectly normal.
The Following User Says Thank You to Josh B For This Useful Post: | TouchMyHonda (09-26-2012) |
09-26-2012, 04:24 PM | #25 | |
Vtec Jesus
Will that show true maximum gains and fuel efficient? No. Will it destroy your motor? No. Additionally if you were intelligent, you know know that an intake would never cause enough change to damage a motor from a car with an extremely conservative tune oem. I've driven plenty of exotic cars that do this off the dealer lot many times more often that a more standard general public automobile. All cars backfire, all the time, constantly. Some naturally, some due to bad tunes. There can be at least 1000's of reasons why a car will fart. Why don't you post up your motor builds and tuning experiences mr. drift. Lets see your impressive background. Last edited by TouchMyHonda; 09-26-2012 at 04:25 PM. Reason: SpElLiNg |
09-26-2012, 04:48 PM | #26 |
Drives: Scion FR-S
I have the same intake get a tune that won't let your rev fall below 800 and it will go away.
The Following User Says Thank You to Accurate Race Shop For This Useful Post: | DR1FT (09-26-2012) |
09-26-2012, 05:10 PM | #27 | |
Drives: Scion fr-s
I am not scared in anyway neither do i care about my mileage i track the car... The reason why most people never had backfire before is because when you are running full cat it shouldn't happen. This was the reason i was asking, and it's not a backfire that will be seen from outside you ear it pop in the exhaust. I will keep driving my car like that until i get my headers and full exhaust and tuned at the same time. I do not believe in tuning a car that is N/A after only an Intake. |
The Following User Says Thank You to canu_50 For This Useful Post: | TouchMyHonda (09-26-2012) |
09-26-2012, 05:16 PM | #28 |
Vtec Jesus
True that. Wait till you have a full exhaust and buy a tune. You will see gains with NA bolton's usually with an OEM tune. The cost of a tune simply isn't justifiable for an intake only. I fully believe with oem internals, Minus cams and maybe valve springs.... that this car NA could make 250-280 wheel.
Similar Threads | ||||
shifting from 1st to 2nd | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 05-26-2016 07:15 PM |
MT Shifting | n8dog11914 | Engine, Exhaust, Transmission | 4 | 08-28-2012 03:28 PM |
Paddle Shifting | switchkick | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 08-14-2012 03:29 PM |
shifting and down shifting feel | Lowellrenzo | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 07-08-2012 05:09 PM |
Thud/Clunk when shifting. | erom | Engine, Exhaust, Transmission | 10 | 06-17-2012 07:08 PM |
