Old 09-14-2012, 08:13 PM   #15
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by jarviz View Post
How much should I Expect to be charged to have a remote start installed. I'm guessing this is a generic or simple device 'cause I'm asking Toyota to give me quote. Just looking to see what's the ballpark for this kinda job. Thanks.
Depends on how complex a system you get. Most chains will probably charge you around $150-200 for a basic installation unless you bought it from them and got some kind of package deal. You could install a basic system yourself if you're handy with tools and auto wiring.
A more complicated system with multiple options, additional security features, sensors, etc, will add to the price.
Old 09-14-2012, 09:17 PM   #16
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by ngabdala View Post
It will be fine. You don't leave the car in gear with remote starters on manual trannys
This is pretty funny if you pretend the picture in your signature is part of the post.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following User Says Thank You to Laika For This Useful Post:
ngabdala (09-14-2012)
Old 09-14-2012, 11:45 PM   #17
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
Having a remote start on a manual car will not cause issues to the trans. I do installs with Viper/Python quite a bit and theres a specific manual mode for it.
This is if you park your car and you know will be remote starting it
Park car
Leave in neutral
foot Brake down
E-Brake up
Let go of foot brake
hit remote start button on remote (parking lights then flash)
take key out of cylinder (car will still stay running)
open door leave the car
close the door and lock (car will then shut down)
If the car was in gear when leaving it wouldve already stalled leaving the car. If the door is open or alarm goes off at any point after leaving it in manual mode you will be unable to remote start the car. If you get either Python/Viper unit with a screen it will have a small stick shift icon on it to allow you to know the car is in remote start mode. Safest way to do it.
Older cars you were able to start without the clutch depressed, newer ones have a switch at the pedal that usually either needs a ground to one wire or both wires at the switch that are continuous. You use a relay with a diode on the negative start output of the remote starter to activate it and bypass the clutch input.
PrimeMotoring is offline   Reply With Quote
The Following User Says Thank You to PrimeMotoring For This Useful Post:
Lee358 (09-15-2012)
Delete driver01 Electronics | Audio | NAV | Infotainment 20 01-31-2013 02:02 AM
RCE YELLOW Performance Lowering springs intro buy! RCE Suspension Starter Pack! Racecomp Engineering Brakes, Suspension, Chassis 141 10-07-2012 08:12 PM
Starter Tool Kit Advice Erroneous Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 07-20-2012 03:11 PM
