Old 09-17-2012, 08:46 PM   #15
roddy
roddy's Avatar
Drives: '13 Ultramarine
I tried a couple of different 15" steelies today and they were a no-go. The caliper made contact before the wheel was seated on the flange. This was on the front, so I didn't bother trying the rears. It looks like 16" is the minimum.
Old 09-18-2012, 12:34 PM   #16
Captain Insano
Very helpful, thanks for posting as I'm also considering a smaller winter wheel and it's good to eliminate the 15 from searching if it doesn't fit. I guess I'll be looking for 16s on tire rack since that is safest from a fitment perspective....
Old 09-18-2012, 01:09 PM   #17
dsgerbc
Drives: BRZ(sold), STI
I'm gonna try to score some Impreza Premium OEM wheels.
16" and correct offset. Not 100% they'd clear the brakes though.
Originally Posted by wheelhaus View Post
With normal packed snow and snow tires, extra sufrace are (read normal/wide) helps to get more surface grip from the additional sipes and edges.
There is no extra surface to a first approximation. Especially with winter tires that have soft sidewalls. You CAN get larger surface by lowering tire pressures, but that's independent of the width.
Narrow tires will cost you lateral grip at the expense of some extra longitudal grip to help you get moving, but during winter going fast through corners should'be one's priority to be begin with.
dsgerbc is offline   Reply With Quote
Old 09-18-2012, 01:45 PM   #18
trifenix
Drives: Toyota Tacoma
Do the rotors and calipers clear with 15s? Maybe a small 5mm spacer would help?
trifenix is offline   Reply With Quote
Old 09-26-2012, 12:30 PM   #19
dsgerbc
Test-fitted some 15x6.5 +45 Braid Acropolis rims. It's a no-go, sadly. They clear the brakes all right, but the tie-rod ball joint rubs on the wheel a bit and doesn't let one put wheel weights on there.
Old 09-26-2012, 01:34 PM   #20
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Originally Posted by roddy View Post
I'm undecided if I'll go with a 16" steelie with 205/55s or 195/60s, or If I will try 15" steelies. One thing is for sure though... I'll be running WS70 Bridgestone Blizzaks. A friend owns a tire shop, and I'll be paying him a visit in a couple of weeks while I'm on holidays. I'll try both sizes of wheel before I order tires, and post up what I find out about the fitment of 15s.
You may wish to also consider the impact on your comprhension of the speed vs. speedometer readout.
According to my reference when comparing 215/45R-17 with 215/55R-17, this would mean that when the speedometer reads 100kph the car would be travelling 106.9 kph. Thats relatively quite different.
195/60R-16 gives 100 speedo = 102.4
195/55R-16 gives 100 speedo = 99.3
205/55R-16 gives 100 speedo = 101.1
Everyone I have talked to says 15" wheels are too small. Maybe there are some out there that fit, but how hard is it to find them and acquire them?
smbrm is offline   Reply With Quote
Old 09-26-2012, 07:40 PM   #21
roddy
roddy's Avatar
If you look up a few posts from this one, I did try a 15" steel wheel on the car. It was a no-go. The caliper hit the wheel before the wheel was flat against the flange. Not even close, really. I think it would be difficult to find a 15" wheel that would work. So, it looks like a 16 is the minimum. I did consider the speedo vs actual speed, and figured that a taller tire would be a worthwhile tradeoff for a speedometer that was off by a few percent. I live in the country and will take all the ground clearance I can get (I'm out before the plows and it gets drifty here on the shores of Lake Ontario). That said, I pretty much decided on a 205/55/16 once I saw that the 15 wouldn't fit.
Old 09-26-2012, 07:44 PM   #22
roddy
roddy's Avatar
I just noticed your post. That's good to know...I tried a 15" steelie, and it wouldn't go on far enough for me to see this issue. The one I tried didn't even clear the caliper.
Old 09-27-2012, 01:31 PM   #23
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
I test fitted a 15" VW Avus wheel. It fit over the calipers and did not appear to have any other clearance issues however I did not have any ball seat lug nuts so I did not take it out for a drive or anything. I will probably test those soon seeing as I have a full set of four in my shed with brand new winter tires already on them.
Flat Black VW is offline   Reply With Quote
Old 09-29-2012, 01:17 AM   #24
dietz
Drives: Raven / 6MT FR-S
Originally Posted by quik1987 View Post
What the the size of these? I can't tell from the pics. Also, did they raise this at all?
dietz is offline   Reply With Quote
Old 09-29-2012, 02:17 AM   #25
Mr. Sociable
Hombabe
Mr. Sociable's Avatar
Drives: 2014 BRZ
FWIW I've been unable to find ball seat lugs in a Subaru thread pitch. Was looking for them when I had a set of GLI wheels I wanted to put on my old WRX. Factory are 60* conical.
Mr. Sociable is offline   Reply With Quote
Old 06-15-2022, 01:06 PM   #26
oinojo
Suspension Nerd
oinojo's Avatar
Drives: 2019 Mazda MX-5
Just tested this the other day. Any race wheel with a 14.5" inside barrel will fit the tie rod just fine. So you could do a custom wheel with normal backspace/offset in 15 inch. For future reference for those who are looking to do 15s. It likely won't be an off the shelf option. Just thought I would update this thread since it peaked my interest and nobody had hard data outside of OEM type wheels.
OS Giken / Bridgestone / Lot-USA BRIDE
oinojo is offline   Reply With Quote
Old 06-16-2022, 06:49 AM   #27
churchx
churchx's Avatar
Drives: 2014 GT86
@oinojo
MR501VT 15x7+48
Team Dynamic Rally1 wheels 15x6 +25
VW AVUS Wheels 15x6.0 +38 (need ball seat lug nuts)
15x6.5 ET40 Dodge Neon wheels
Rota Slipstreams 15x7 +35
Old 06-17-2022, 01:51 PM   #28
Racecomp Engineering
How are you forgetting about me @churchx ???
https://www.ft86club.com/forums/showthread.php?t=143176
Fun for gravel and winter but no, not that light. My 16x7 RPF1s were lighter.
- Andrew
Winter Rims RandomHero Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-05-2012 08:06 PM
19 inch rims too big? Liquidcell Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 09-03-2012 01:07 PM
Winter Tires and 17" Rims?? stalon320 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-03-2012 08:33 AM
Cheap winter alloy rims Sport-Tech CANADA 52 04-18-2012 10:30 PM
Photoshop Request: FT86 with 16 inch rims? EJ20 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 18 02-25-2011 04:01 AM
