Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 09-04-2012, 02:49 AM   #15
Skorov
Skorov's Avatar
Drives: 86 GTS White
Some extra reading if you'd like:
http://www.mototuneusa.com/break_in_secrets.htm
It's just another point of view. I, personally, am not saying it is right or wrong. I simply don't have the experience.
It also says that before doing anything you should warm up your car for about 5 minutes. I think this is the only thing that everyone agrees on. =P
Skorov is offline   Reply With Quote
Old 09-04-2012, 02:55 AM   #16
davey90
Akina Speed Stars
davey90's Avatar
Drives: White 86 GTS Auto [CID- ***]
Send a message via Yahoo to davey90
oh crap... in that case i've been doing it slightly wrong. I just wait until the rev drops then i slowly take off, not revving pass 2.5k through some small streets, my car warms up by the time i hit the main roads.
davey90 is offline   Reply With Quote
Old 09-04-2012, 03:07 AM   #17
proficience
proficience's Avatar
Drives: Velocity Orange 86 GTS M/T
Yep thats exactly what ive been doing. 5 minutes seems like aaggeess... but its probably better during the break-in period Won't make a massive diff though, as long as you don't fang it when its cold lol
proficience is offline   Reply With Quote
Old 09-04-2012, 03:24 AM   #18
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
That should be fine. Just don't get on it till it's warmed up. The 5min mark is arbitrary. Obviously it the time required to warm everything up will be different depending on the ambient air temp. At 20F outside it will take much longer than 115F.
TheRipler is offline   Reply With Quote
The Following User Says Thank You to TheRipler For This Useful Post:
davey90 (09-04-2012)
Old 09-04-2012, 03:30 AM   #19
Skorov
Skorov's Avatar
That's about -6C and 45C for everyone playing at home.
Old 09-04-2012, 03:49 AM   #20
TheRipler
Reap the BReeZe
My apologies, and thanks. Sometimes I don't recognize where I wander in here. :happy0180:
Old 09-04-2012, 05:49 AM   #21
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
i had quite a blast in the hills on the weekend while keeping it under 4k rpm. Its WOT all the way till 4k, change gear, WOT till 4k etc etc. On 500ish now, another 1000 to go :/
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 09-04-2012, 05:58 AM   #22
Bauer
Drives: Black 86 GT
Originally Posted by Nardi330 View Post
at cold start up, i always like the car idle drops back to the usual <1000rpm before driving off. the car would idle high for a while then blip the throttle itself and drops back to normal rpm.
thats what I do
Bauer is offline   Reply With Quote
Old 09-04-2012, 06:45 AM   #23
kiks
Drives: V12
Just drive it normally, get up it, drive it normally. However you normally drive any other car.
kiks is offline   Reply With Quote
Old 09-04-2012, 06:49 AM   #24
000 Racing
000 Racing's Avatar
Drives: 2012 86GTS Race Car #86
The Porsche Boxster manual said not to warm it for 5 mins but rather drive it straight off.. obviously gently until up to temp ... could this be a boxer motor thing??
000 Racing is offline   Reply With Quote
Old 09-04-2012, 07:10 AM   #25
SYC086
Drives: JDM MA70 beater & 86 GTS on order
I've had a bunch of people tell me the same thing. My guess is it's to do with oil pressure and providing maximum lubrication - especially during warmup.
I'm actually curious about a technique I read about years ago which was basically getting the engine up to running temp then booting it. If I find it again I'll post up some links.
Edit: Here's the link http://www.mototuneusa.com/break_in_secrets.htm . Maybe it's a load of garbage like intake vortex generators and fuel line magnets etc. ... or not
SYC086 is offline   Reply With Quote
Old 09-04-2012, 07:22 AM   #26
os86
Drives: 2jz
Just follow the book if you are not able to decide. You will get 100 different opinions on the web and they all are probably right in their own way. Below is one I prefer
The first 100kms of any new engine is the most important stage of it's life, they way you use the rev range and load the engine will determine how good the piston & cylinders seal forever.The better the cylinders seal the more compression, therefore more power...
Here is a example,
Have you ever driven a very similar car, eg typical Holden Commodore that has been a one owner can in the family from brand new, always service & looked after but has ONLY been driven by an elderly driver, compared to the same model car from the rental or ex-police department and the drive completely different. (grandma never revved the engine over 2500rpm), but rentals or persuite cars get thrashed from day one. They go much better!!!!
Never baby the engine & stay at the same rpm for long periods,
always try to use the full rev range, & try not to red line or over-rev engine.
They say it is very important to change the engine oil after 100kms or so to get any metal particles or shavings out of engine, and replace with the same grade and viscosity oil that was originally in the engine. Do not use synthetic oils just yet.
os86 is offline   Reply With Quote
The Following User Says Thank You to os86 For This Useful Post:
eckoflyte (09-04-2012)
Old 09-04-2012, 07:47 AM   #27
whyreeto
whyreeto's Avatar
Drives: GT86
Originally Posted by proficience View Post
Yep, I do the same. Natural warm up period. I also try to keep it <2.5k until it has reached full temperature on the oiltemp gauge
hey guys, long time reader about this, but never expressed my question at all.
firstly, i do the same, i wait until the needle is below 1k before moving the car and I've never waited more than 3 minutes, minimum 1-2 mins...
my question is:
proficience, do you mean you put ur foot down on the accelerator on neutral? and hold it on 2.5k? until the engine is warmer sign returns to the middle? usually how long does it take? cuz I've never heard anyone doing this....in your view is this better? I'm asking why is it better because ........... - >
IM GETTING REALLY REALLY rough 2nd gear changes like going from 1st gear to 2nd gear during my first 5-10km or 10-15mins is really bad.....does your way in making the engine warmer correlate with heating up the gear box? because i find that after 5-10km, the longer you drive it, the easier it is to PUT 2nd gear into place...considering that i go from eastern suburbs to *** nearly everyday, i only enjoy like 5mins of fun time with the car, the first 10-15mins is hell lol...
whyreeto is offline   Reply With Quote
Old 09-04-2012, 07:59 AM   #28
proficience
No, I don't mean to hold your revs up in neutral, that's ridiculous and probably worse for the engine. I mean, until the needle in the oil temp guage reaches its 'normal' position, I try to keep it under 2.5k rpm max when driving. This reduces stress in the engine while its still not at 'warm' temp.
Do you have an auto box? I find the first 5 minutes are sometimes rougher as well (only sometimes ), but then it settles down nicely.
rev the engine to 5000 rpm before break in period midnitz Scion FR-S / Toyota 86 GT86 General Forum 48 11-03-2013 10:24 AM
Within break-in period, but long road trip? Rossman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 07-20-2012 02:09 PM
Break-in Period and Octane level MattM232 Scion FR-S / Toyota 86 GT86 General Forum 10 06-05-2012 11:00 PM
Engine break in period - how necessary is this? WhippleDip Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 05-16-2012 03:38 PM
Break-In Period UriarteMD Scion FR-S / Toyota 86 GT86 General Forum 10 03-29-2012 03:26 AM
