Old 05-24-2024, 01:53 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I've never messed up a stock stud either but I always run them on gently.
Highly advise against anti seize or any type of thread lubricant. Has a drastic effect on torque.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
gen3v8 (05-24-2024), humfrz (05-26-2024), Ultramaroon (05-24-2024)
Old 05-24-2024, 07:46 PM   #16
Ultramaroon
not playing cards
Ultramaroon's Avatar
To be clear, I'm on my original wheel studs/nuts. I only became curious after reading all the horror stories. Wheels are removed a few times annually.
The stock acorn nuts are pretty sloppy but, handled accordingly...
gen3v8 (05-24-2024)
Old 05-24-2024, 08:07 PM   #17
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Can change the torque up to 40%.Yes I use some copper grease. Makes me wonder what level of destruction others have applied for a failure. I start by hand, use a rattle gun, then finish on the ground with a torque wrench. I do use aftermarket steel wheel nuts that show no signs of failure nor do the wheel studs. I have aluminium nuts that are also fine but not for track use IMO.
gen3v8 is offline   Reply With Quote
The Following 2 Users Say Thank You to gen3v8 For This Useful Post:
autoracer86 (05-26-2024), NoHaveMSG (05-24-2024)
Old 05-24-2024, 11:45 PM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I know a lot of people who have gotten away with it for a long time so take it with a grain of salt. All the tests I have scene show a pretty drastic change in torque.
I think the biggest issue with the stock studs is poor tolerances on the studs and lugs combined with speed from an impact. I run my down on a super low hand tight setting then give it a few whacks when snug then hand torque. They always seem to fail from galling.
Old 05-26-2024, 04:54 AM   #19
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
Yes like the throttle on corner exit when you have power. Squeeze don`t squash the rattle gun trigger. Not that I`m telling you how to operate your machines be they simple or not.
Old 05-26-2024, 03:31 PM   #20
Ultramaroon
not playing cards
No extra points for speed. I do it all by hand.
humfrz (05-26-2024)
Old 05-26-2024, 05:20 PM   #21
humfrz
Yep, this tool, applied with "two squeaks and a grunt" has served me well for the past 75 years.
Stephen W. (05-27-2024), Ultramaroon (05-26-2024)
Old 05-26-2024, 05:56 PM   #22
Ultramaroon
not playing cards
Amen, my friend.
humfrz (05-26-2024), NoHaveMSG (06-02-2024)
Old 05-26-2024, 10:36 PM   #23
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
I've converted one rear wheel to ARP studs and plan to do the rest as I get to it. In the meantime I have ARP studs in the car with instructions to anyone who I might have do tire work to replace the entire wheel if one stud breaks.
Qwimby1 is offline   Reply With Quote
Old 06-01-2024, 06:18 PM   #24
e_lunatic
Drives: 2015 Scion FR-S
I never had an issue with the stock lug nuts, however the Toyota dealer that would rotate my tires when i first got it had a hell of a time with them and wound up crossthreading 2 of them leading to breaking 2 of the studs. Stopped taking it to Toyota after that and never had another problem.
I have been running stock studs and aftermarket lugs for about 7 years with zero issues. I also run a small dab of pressure lube on the studs and have never had a torque issue (YMMV).
e_lunatic is offline   Reply With Quote
Old 06-02-2024, 09:15 AM   #25
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Torque test channel recently had one that covered this.
dragoontwo is offline   Reply With Quote
The Following 4 Users Say Thank You to dragoontwo For This Useful Post:
autoracer86 (06-02-2024), blsfrs (06-02-2024), NoHaveMSG (06-02-2024), Ultramaroon (06-02-2024)
Old 06-02-2024, 01:46 PM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They do a lot of cool videos. It’s nice seeing some of the stuff old timers taught me to be true when he did his mythbusting videos.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
bcj (06-02-2024)
Old 06-02-2024, 02:36 PM   #27
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
A buddy of mine used Neverseize on everything from steak to seafood. When he was installing brakes, he put it on the lugs of his Ford Exploder. After about a month, it developed a vibration. He took it to a shop to have his tires rebalanced and guess what.
A. The tires needed balancing.
B. You never use neverseize with seafood.
C. Loose nuts
The Following 3 Users Say Thank You to blsfrs For This Useful Post:
bcj (06-02-2024), NoHaveMSG (06-03-2024), Ultramaroon (06-02-2024)
Old 06-03-2024, 03:40 PM   #28
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
I`m sure if you used a tapered seat with different metals and another product recommended for wheel nuts/studs the results would be completely different. As I have Seen.(Not scene)
Is the fad threads ruining our fad threads? Andrew025 Off-Topic Lounge [WARNING: NO POLITICS] 12 10-04-2017 10:12 PM
BRZ or FRS (yes, another one of those threads) lisaaaxo FR-S / BRZ vs.... 19 04-11-2015 03:44 PM
Cleaning the red threads on the steering wheel. Frishkorn Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 07-28-2014 01:59 PM
why are there individual threads for every single wheel size and make? VENOM~ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-02-2012 01:32 PM
Vs. threads.... TwinscrollGT35R FR-S / BRZ vs.... 34 05-22-2012 09:21 PM
