#15 |
Drives: Crapcan
I've never messed up a stock stud either but I always run them on gently.
Highly advise against anti seize or any type of thread lubricant. Has a drastic effect on torque.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#16 |
To be clear, I'm on my original wheel studs/nuts. I only became curious after reading all the horror stories. Wheels are removed a few times annually.
The stock acorn nuts are pretty sloppy but, handled accordingly...
| The Following User Says Thank You to Ultramaroon For This Useful Post: | gen3v8 (05-24-2024) |
#17 | |
30 minute maintenance
Drives: My18 wrxsti
.Yes I use some copper grease . Makes me wonder what level of destruction others have applied for a failure. I start by hand, use a rattle gun, then finish on the ground with a torque wrench. I do use aftermarket steel wheel nuts that show no signs of failure nor do the wheel studs. I have aluminium nuts that are also fine but not for track use IMO.
| The Following 2 Users Say Thank You to gen3v8 For This Useful Post: | autoracer86 (05-26-2024), NoHaveMSG (05-24-2024) |
#18 | |
Drives: Crapcan
I think the biggest issue with the stock studs is poor tolerances on the studs and lugs combined with speed from an impact. I run my down on a super low hand tight setting then give it a few whacks when snug then hand torque. They always seem to fail from galling.
#19 | |
Drives: My18 wrxsti
#20 |
No extra points for speed. I do it all by hand.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (05-26-2024) |
#21 |
Yep, this tool, applied with "two squeaks and a grunt" has served me well for the past 75 years.
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Stephen W. (05-27-2024), Ultramaroon (05-26-2024) |
#22 | |
#23 |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
I've converted one rear wheel to ARP studs and plan to do the rest as I get to it. In the meantime I have ARP studs in the car with instructions to anyone who I might have do tire work to replace the entire wheel if one stud breaks.
#24 |
Drives: 2015 Scion FR-S
I never had an issue with the stock lug nuts, however the Toyota dealer that would rotate my tires when i first got it had a hell of a time with them and wound up crossthreading 2 of them leading to breaking 2 of the studs. Stopped taking it to Toyota after that and never had another problem.
I have been running stock studs and aftermarket lugs for about 7 years with zero issues. I also run a small dab of pressure lube on the studs and have never had a torque issue (YMMV). |
#25 | |
Drives: 22 BRZ limited
| The Following 4 Users Say Thank You to dragoontwo For This Useful Post: |
#26 |
Drives: Crapcan
They do a lot of cool videos. It’s nice seeing some of the stuff old timers taught me to be true when he did his mythbusting videos.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | bcj (06-02-2024) |
#27 |
Drives: 2013 frs base
A buddy of mine used Neverseize on everything from steak to seafood. When he was installing brakes, he put it on the lugs of his Ford Exploder. After about a month, it developed a vibration. He took it to a shop to have his tires rebalanced and guess what.
A. The tires needed balancing. B. You never use neverseize with seafood. C. Loose nuts |
| The Following 3 Users Say Thank You to blsfrs For This Useful Post: |
#28 |
Drives: My18 wrxsti
| Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 10:12 PM |
| BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 03:44 PM |
| Cleaning the red threads on the steering wheel. | Frishkorn | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 9 | 07-28-2014 01:59 PM |
| why are there individual threads for every single wheel size and make? | VENOM~ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 09-02-2012 01:32 PM |
| Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 09:21 PM |
