#15 |
Re-member
Drives: Toyota camry
Those of you with difficulty shifting, check the transmission fluid level. I have seen cars (and there are threads here) that are low from the factory. Modern transmissions can be very picky with fluid level.
Nothing decays like progress, and nothing preserves like neglect.
#16 |
Drives: 00 Honda S2000
My S2000 does the same thing, I need to regrease the shifter which will help smooth it out but it's pretty much a cold transmission issue. Also syncros don't work as quick as you can actually shift, try holding 1-2sec more before you try to force it in gear as it could simply be trying to rev match.
#17 |
Drives: Nevermorange FRS
I changed my Transmission fluid at 1.5k miles. All is good now.
#18 |
#19 | |
The 2nd reason I used the yellow bottle... The OEM stuff isn't available in the states yet AND I wanted to change my tranny fluid sooner than later for the same reason I wanted to change my engine oil. Get the break-in oil out of there. I've stated this in a few threads now but the OEM stuff, looks, smells and feels identical to Honda Manual Transmission Lubricant.....identical. And I don't like using the Honda MTL in my transmissions, even my Honda boxes. I've been using the Yellow bottle in my S2000, my Prelude, my CRX race car and now my FRS (since it's an Aisin tranny like the s2k). |
| No more 1st gear thump or 2nd gear notchiness | kc4mne | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 09-06-2012 08:39 PM |
| Top Gear | blackfireball5 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 08-17-2012 01:58 PM |
| 5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? | kharn83 | Issues | Warranty | Recalls / TSB | 9 | 08-06-2012 07:44 PM |
| 86/BRZ/FRS on Top Gear: When??? | FT-86GOD | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 07-04-2012 12:08 AM |
| Reverse gear on the first and second gear side | randytindoggy | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 01-29-2012 01:21 PM |
