Old 03-11-2024, 02:20 AM   #15
tomm.brz
Drives: brz 2017 hksv2
how does it drains back to PCV? the car when driving in vacuum, will PULL air through PCV , sourcing it through the CCV side which take atmosphere pressure air from intake side pre throttle pre forced induction. Air will end up into intake manifold post throttle, possibly cleaned by the AOS
Then when in Boost, ideally the PCV closes and any excess in the crankcase should be getting into CCV side so into intake side pre throttle pre forced induction
Is this AOS relying on a weak oem PCV that leaks under boost and so hoping the vapours will end back back into crankcase and stay there?
Also, are the 2 collecting chambers inside the AOS somehow connected to each other so that all the oil collected by both PCV side when in vacuum, and ccv side when in boost, is going to router back together into crankcase through the PCV as said here in this thread?
if yes i see many criticality in this
something isn t right to me
Old 03-11-2024, 02:38 AM   #16
Diddy Kong Had A Dong
Diddy Kong Had A Dong's Avatar
Drives: 2018 Subaru BRZ Ts
Originally Posted by tomm.brz View Post
how does it drains back to PCV? the car when driving un vacuum, will PULL air through PCV , sourcing it through the CCV side which take atmosphere pressure air from intake side pre throttle. Air will end up into intake manifold post throttle, possibly cleaned by the AOS
Then when in Boost, ideally the PCV closes and any excess should be getting into CCV side so into intake side pre throttle.
I’m still very new to catch cans/AOS’s, but following the install guide on DT’s website, the top most port goes to intake pre turbo, the 2nd to top goes to crank case behind the AC compressor, then below that it goes to the intake manifold, and bottom most port is the one that goes to the PCV valve. I was also wondering how it can drain back through the PCV since that’s what it looks like (unless I’m wrong then I apologize) but I haven’t seen any oil in my charge pipes yet after a few days of spirited driving
2018 BRZ tS WRB 493/500 | JDL UEL kit w/ gtx2860rs gen2
Diddy Kong Had A Dong is offline   Reply With Quote
Old 03-11-2024, 10:18 AM   #17
tomm.brz
would be interesting to understand how is it routed inside, how you said is how you install 2 separate catch cans in our car
But having those 2 chambers linked inside would be very wrong, so still something isn t clear on Delicious's description
Old 03-11-2024, 02:57 PM   #18
Grady
Grady's Avatar
On a Turbo set up the PCV valve needs to be between the intake manifold and the catch can to keep boost pressure from getting to the AOS can and pressurizing the crankcase. My turbo kit got rid of the factory PCV valve and installed an inline valve at the hose to the intake manifold.
The Following User Says Thank You to Grady For This Useful Post:
tomm.brz (03-11-2024)
Old 03-11-2024, 04:20 PM   #19
Grady
Grady's Avatar
Double post
Old 03-11-2024, 07:15 PM   #20
I see. With my JDL kit, there was nothing really happening to the PCV system but one install guide I followed said to replace the PCV valve with an STI valve so I went ahead and did that. But then I started doing some supporting mods/track prep to the car and wanted an AOS and saw that this DT system is new and it’s a pretty trusted company for this platform so I went ahead and got theirs. Looking at the system it does seem like instead of pulling vacuum through the PCV it might be sending boost to/through it so I hope DT can let us know some more information on this AOS and how it works!
Old 04-26-2024, 05:57 PM   #21
bad82
Drives: 17 BRZ PP,14 Juke Nismo RS AWD
Got mine installed today, currently running the stock PCV. I am doing this in preparation for a JDL turbo kit I will be installing later this year. I left the hoses with a little extra length to make it easier to adjust as needed when the turbo setup goes on.
I am also wondering about how it functions, I guess it would make sense that it drains through the PCV when the engine is not under load and the crankcase is in vacuum condition. I am planning on swapping to the STI spec PCV when the turbo goes on.
@DT please let us know if this is the intended install method for NA soon to be boosted setups.
Here are a few pics from my install, pretty straight forward aside from a missing union 1/2" that I easily picked up at O'Reilles around the corner. I think it looks great in black!
https://imgur.com/Ng2WpFO
https://imgur.com/5o7IZGs
You can see all the extra hose I left looped in this pic
bad82 is offline   Reply With Quote
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 05:02 PM
PTUNING Plug and Play WMI (Water/Methanol Injection) System and ECUTek Tuning ptuning Forced Induction 71 02-27-2019 08:55 AM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 04:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 11:53 AM
