#15 |
Drives: 2020 Toyota GT86
I've had my 86 since the end of March 2021, have worked remotely 100% of the time since buying it and still have less than 3.5K miles on it. Yet I run winter tires. So my opinion should be quite clear
If you can swing it, I would suggest putting them on their own set of wheels. You will save money in the long run versus paying twice a year to have the tires swapped over on the same wheels.
This post sent using 100% recycled electrons.
#16 |
Drives: 2014 GT86
If one gets another set of wheels, advise to get smaller size for winter. Tires will cost less and extra sidewall size will help with bad roads. Used subbie 16" should be reasonably cheap & common.
#17 |
Drives: 2020 BRZ Sport Tech RS
As everyone else here has said, get some winter tires!
On my Sport Tech RS (AKA "Performance Pack" in the US) with the factory Brembo brakes, the smallest size wheel I can run are 17's, so I have my snows on the OEM Performance Pack 17x7.5" ET48 wheels and some lighter weight 17x8" ET35 wheels for the UHP all-seasons I run the rest of the year. With my lowered ride height (about 30mm / 1.25" drop all around), I don't venture out when the snow is more than a couple of inches deep, so I don't really need the "pizza cutters" to get through the deep stuff. That made me settle on the same 225/45R17 size I run for my all seasons instead of the other option of 205/50R17's I was considering. I ended up getting Michelin X-Ice Snow 225/45R17's, and have previously run Blizzak WS90's in the same size on my last car. Both were MILES better for starting / stopping traction than any all-season with snow or ice on the ground, and both feel pretty squishy (both tread and sidewalls) on bare pavement (wet or dry). The Blizzaks' sidewalls actually felt a *little* better than the Michelins in that regard, if I remember correctly, but again - it was on a different vehicle. Between the winter tire traction, the overall balance of the car, and the traction / stability control systems helping keep things pointing the right direction, the car has been surprisingly capable in the snow / icy conditions as long as I drive with a little restraint.
| The Following 2 Users Say Thank You to Tatsu333 For This Useful Post: | DarkPira7e (12-28-2022), Jdmjunkie (12-28-2022) |
#18 |
Drives: '23 BRZ
I run Pirelli Sottozero III 225/45-17 on factory 17x7.5s. Maybe remove rear sway bar...
#19 | |
Drives: 22 BRZ
If it's real cold (under 30 degrees F) and or there's snow/ice on the ground, they're very good and you'll be glad you have them. Any other scenario or conditions - they're not good. |
#20 | |
Drives: 2014 GT86
.. Unless where one lives/drives winter has too little actual "winter in it". |
#21 | |
Drives: 22 BRZ
I live outside Chicago which does get real winter. It was just -10 degrees last week. Today it was 60. It cannot be overstated just how bad the braking is whenever it's not freezing cold outside. Not even panic braking- just driving in standard suburban traffic, it's noticeable just how much further you have to get into the brake pedal to make the car stop. I'm considering taking a loss and going to 'performance winters' next season. |
#22 |
Drives: 2014 GT86
Sounds weird. Never had any problems with braking/cornering/accelerating on clean public tarmac roads on nordic winter tires (even studded at that) with driving normally, within legal limits. Worse then on all season? Probably. But good enough with some safety margin left. But i had been stuck in deep snow in unplowed yard, i had my share of scare moments of 'almost' crashing or not stopping in time on ice when in past drove on crappy winter tires in my very first winter in twin (probably made more grave then in "normal cars" due it's RWD layout & light weight & maybe reliance of high grip in summer), so now choosing to maximize what i can for "worst case scenarios". But not suggesting this as right choice for everybody, especially for ones living in warmer climate places.
#23 | ||
I like my General Altimax Arctics a lot more in non-snowy less-cold conditions. They still suck but it's not "holy crap this is bad" levels of suck. They are still good in the snow...though hard to compare directly since I haven't seen the same conditions I put the Blizzaks through. - Andrew |
#24 | |
Custom Switch Panels!
Drives: 2015 Subaru BRZ Series.Blue
You aren't wrong, BUT I look at it slightly differently. Yes, true studless winter tires suck when it's warm, and aren't THAT great on dry pavement... but they are so much better than anything else in snow and ice that I still think they're worthwhile. THOSE are the times when you want maximum traction, not only for yourself, but to avoid all the other idiots on the road. It's easier enough to adapt on the random warm days an increase following distance (because as you said, panic braking on studless winters on a 60 degree day is an exercise in futility), but what I refuse to sacrifice is the added traction when I hit a patch of ice on the road, or when I need to swerve around some idiot sliding into my lane in the snow. I used General Altimax Arctics for basically 7 of those 8 winters, but last winter I decided to try something a bit higher-tier (also because the Generals aren't that much less than the class-leading tires anymore) so I went with the Continental VikingContact7, which was trading blows with the Blizzaks and the Hakkepeliittas.
| The Following 4 Users Say Thank You to RACECAR go brrr! For This Useful Post: |
#25 |
Drives: 2014 Subaru BRZ DGM Limited
This is my 3rd season on the Michelin X-ICE 245/45/17. They've been great under Chicago and South Bend snowy conditions.
Only time that I lost traction was a few weeks ago, we had a freezing rain/sleet condition followed by a snow storm. I didn't pay attention and thought it was fresh snow. Then my rear lost traction a bit after moderately accelerating from a stop sign, and the car's rear end kicked out to the opposite lane. Luckily my front tires still had grip and the speed was low. The tires saved me from spinning or going into the woods. Remember, putting winter tires on doesn't mean you can drive the car like you can during summer. Slow acceleration and paying attention to the road conditions are important as well .
| Herrafrush winter setup | Atomic Rooster | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 10-31-2017 10:54 PM |
| WTB: Winter Setup | slim | Canada Classifieds | 3 | 10-01-2016 10:05 PM |
| Question: 195/60 R16 for Winter Setup | ivtaku7 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 11-30-2015 12:23 PM |
| Winter suspension setup | R2 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 11-02-2013 03:20 PM |
| Winter setup | cnk | NY / NJ / CT / PA | 72 | 12-13-2012 09:48 PM |
