Old 12-02-2022, 06:31 AM   #15
tomm.brz
Drives: brz 2017 hksv2
Ops sorry, while typing i forgot OP is boosted, was thinking somehow he was NA still
anyway still not enough from him to enjoy 5th gear, apparently that is his goal
So would benefit with a 4.56 fd
Old 12-02-2022, 09:44 AM   #16
ZDan
ZDan's Avatar
Drives: '23 BRZ
Still gonna have the same gap between 4th and 5th ratios even with 4.56 diff, you'll just experience it at a lower road speed for a given shift point.
Too bad the AT has such a wide 4-5 gap, should be more like the MT where you keep 5th gear closer to 4th and then have a wider gap 5th to 6th gear for lower-rpm and higher-mpg for highway cruise.
Only solution is to hold it in 4th longer before upshifting. Upshifting at redline you'll land at 5276 rpm in 5th, shouldn't be a problem with TORBO!
Old 12-02-2022, 12:31 PM   #17
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by Lucky21 View Post
Hmmm if you drive mt try to imagine going from 4th straight to sixth gear, that what I meant by 5th gear being sluggish and almost unusable even if i'm boosted. It's like for example I can reach 130mph in 4th gear that probably as high as i'm going to get as the moment I shift into 5th it just bogs down due to the long gears. So I just thought maybe a higher final drive would act like a shorter 5th gear or it would be better to go lower so I can make the most out of 4th gear totally disregarding 5th.
I know most people here don't really care about top speed but I was just genuinely curious if you could adjust that as I live in an area where such speeds are achievable legally (for the most part) Hope my post doesn't confuse others sorry.
Then based on that statement, you definitely want a higher FD, like 4.56 or more. You're talking about acceleration then, not a top speed. A higher FD will give all your gears more torque and make gears like 5th and 6th shorter, so they feel quicker.
Dzmitry is offline   Reply With Quote
Old 12-02-2022, 12:33 PM   #18
Dzmitry
Dzmitry's Avatar
Yeah, in the end, the guy clearly likes power and the sensation of acceleration. Because I'm plenty satisfied with my 5th gear on headers+E85 on a tune. I could only imagine the massive difference on 300whp lol.
Old 12-04-2022, 11:05 PM   #19
Lucky21
vroooooooom
Lucky21's Avatar
Drives: 86
Found this on youtube. It seems the higher fd does give 5th more acceleration
Lucky21 is offline   Reply With Quote
Old 12-05-2022, 02:27 PM   #20
Dzmitry
Dzmitry's Avatar
Right, it absolutely does, as there is more torque to the individual gears with a higher FD ratio. Math will dictate this. The losses you will have is more shifting in the same period of time, higher RPM in cruising gear, and lower mpg. You can see in this comparison video, as well as others out there, that there is little to no difference of actual results in terms of how much faster you get up to a certain speed. This is mostly attributed to the fact that you have more shifts involved. But purely in terms of acceleration PER gear and FEEL, each gear will be and will feel faster with a higher FD.
Higher final drive ratio and increased engine braking Purist Engine, Exhaust, Transmission 11 06-16-2019 12:25 AM
4.556 Final Drive with a Turbo Setup Sh1FTy Forced Induction 9 04-19-2018 06:13 PM
Final Drive Gearing, Auto vs Manual KoolBRZ Engine, Exhaust, Transmission 9 09-11-2017 09:50 PM
4.56 final drive with 6th gear from an auto?? fr-s6MT Engine, Exhaust, Transmission 3 12-17-2016 11:47 AM
Any interest in 4.5 final drive from Auto Factory? mike_ekim1024 Engine, Exhaust, Transmission 12 09-12-2013 08:41 PM
