Old 10-30-2022, 11:07 PM   #15
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by Dann_86 View Post
I guess it could be a rod starting... the oil could take up the slack and it goes away for now. if that's it, it's going to get worse and we will know soon.
I just remembered something else I read about the center locks failing on the intake camshaft phasors. If they hang up and can't park, they flop around until pressure hits them.
I suggest pulling the timing cover to check the intake vvt phasors and the preload of the timing chain tensioners.
x808drifter (10-31-2022)
Old 06-06-2023, 08:41 PM   #16
Dann_86
Drives: Toyota 86
update... I finally figured this out. It was the vvt intake cam gear. Something broke inside of it and made this sound till oil pressure increased.
I installed a new one and it's fixed. Hopefully this helps if someone finds this...
Dann_86 is offline   Reply With Quote
The Following 5 Users Say Thank You to Dann_86 For This Useful Post:
bcj (06-07-2023), blsfrs (06-06-2023), DocWalt (06-07-2023), NoHaveMSG (06-06-2023), Ultramaroon (06-06-2023)
Old 06-06-2023, 09:06 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Thank you for sharing the fix, it is not often that people do this and it is a big help to others in the future.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
blsfrs (06-06-2023), Dann_86 (06-07-2023)
Old 06-06-2023, 10:53 PM   #18
Ultramaroon
not playing cards
Thanks for confirming. It makes your recording an excellent reference.
Check engine light then a traction control light then just a check engine... and then Jstyle Issues | Warranty | Recalls / TSB 13 02-15-2021 06:10 PM
Check valve for brake booster? (Automatic) kev0 Issues | Warranty | Recalls / TSB 1 10-22-2019 01:32 AM
check valve behind pcv myioz86 Forced Induction 62 09-07-2016 06:15 PM
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 10:39 AM
FS:WA- ADD W1 Baffled catch can and Boomba Racing vacuum check valve glamcem Engine, Exhaust, Bolt-Ons 1 09-17-2015 02:24 AM
