#15 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
Nice progress so far, definitely following!
On the gen1 cars they also painted a crush washer to the drain bolt, so be sure to check next oil change to see if it is the same for the gen2 cars. |
| The Following User Says Thank You to villainous_frx For This Useful Post: | X25 (08-06-2022) |
#17 |
Sr. Spiritual Advisor
Drives: 2023 BRZ Premium
Got the first alignment done (@200 miles)
Finally got the first alignment done. Rear UCAs complicate the alignment a little bit due to clearance issues, but it's not too bad. At stock height, this is all we could get. Since the track I'll be at is CCW, I suppose -2.5 will be put to use : P Front pads look nice and thick. The bite does not feel high at all, but I have not bedded in pads anyway, so it might improve at the track. How -2.5 camber looks like. Looking forward to what we can do with the coilovers and camber plates...
'23 Subaru BRZ Premium Manual (Track Build Thread)
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4 '21 Tesla Y Long Range AWD '19 Corvette Z06 Z07 (Track Build Thread) |
| The Following User Says Thank You to X25 For This Useful Post: | villainous_frx (08-03-2022) |
#18 |
I had my first outing at the track, but it was very short.
2 laps in, the pedal went to the floor, and I cut the day short for safety. I for possible leaks, etc., but all was good. Looks like there was still a bit of air trapped in the new calipers. I re-bled all calipers with plenty of fluid, and tested the brakes by doing back to back stops on a freeway close to home to see if the brakes would still act up. They performed well, so hopefully this issue is resolved. I will be at another track next Friday, and hoping to test the car out more : ) Until I receive the harness bar, I thought this location would work, but it seems to be too far back. Following @glamcem's advice, I ordered seat headrest post mount (link). Back home, I realized one of the rear UCAs' adjustment has moved. I really don't like the luck nuts' design on this, since they are too close and thin, and make it hard to get them really tight. I think these flat(thin) wrenches would help. Really impressed by the design of OEM 17" wheels; very stylish and they provide ample clearance. I'll try out the car next on Aug 12th, and will likely start installing the race seats and coilovers in September. There's a time attack event on Sep 24, but I'm sure I'd rather want to use the Corvette for it : )
| The Following 3 Users Say Thank You to X25 For This Useful Post: |
#19 |
I think it's the same. Didn't look carefully, but it certainly didn't leak and sealed well...
| The Following User Says Thank You to X25 For This Useful Post: | villainous_frx (08-06-2022) |
#20 |
Drives: 22 Raven 86, 19 STI, 15MK7 SE daily
So unfortunate you had break issues. Looking forward to the progress! I'm also thinking about getting Azenis rt615k+ for my OEM base wheels. Nice job!
| The Following User Says Thank You to autosenses For This Useful Post: | X25 (08-07-2022) |
#21 |
Ready for ORP (Oregon Raceway Park)!! Unlike the other events, I will be attending an ORP club day, which allows me to use the open track for as long as I want except for the lunch break. I'm hoping this would be a great opportunity to get used to the clutch, etc. as well, since I need to learn how much I should blip in downshifts on this car. During my play at the street (which is hard to do without heavy braking), it gets oddly satisfying when the blip is just right, and shift happens with zero resistance. Anyway..
Forgot these in the trunk... 2.7 lbs for compressor 6.1 lbs for prehistoric tire tools 1.3 lbs for the case. I like it, so I decided to keep this one.. Also, just realized I needed a tow hook to winch the car onto the trailer. OEM unit is actually not very heavy. Nevertheless, I ordered Perrin's tow hook in black color. I'd really want to have cloth, but have not found something good for front fitment. This thing is so tiny! Corvette has about an inch of clearance on both sides when loaded. Until I figure out the roll/harness bar issue, I'll use this mount. This is how it will hopefully look like. I will need to play with smoothness and EV settings since I just switched to GoPro 10, and not sure about optimal settings, yet. One bummer is that the spot metering (Exposure control) can only be done from the camera's screen, which is not easy to access from the mount's location. Besides these, I'll also be camping in my hybrid truck, which I'll keep running (it provides HVAC and 7200 Watts of max power, and only runs the engine for a minute every 20+ minutes or so; amazing perks). Looking forward to watching videos/movies with 10+ speakers of the truck; better than my lviing room for sure : P
| The Following User Says Thank You to X25 For This Useful Post: | villainous_frx (08-12-2022) |
#22 | |
Drives: GR86
My issue with the Hero10, is it would like to freeze when charging while the camera is 'off' and would refuse to turn on unless I pulled the battery. |
#23 |
My other cam is DJI Action cam, which works great actually, but its app, which I need for spot metering, needs to be side loaded on Android. Since it forces you to skip app store, it could have a malware, and you'd never know. This is even a violation of my company policies, since I'm not supposed to side load stuff on a phone where I have Corp access as well, so I removed it.
Back to GoPro, freezing is not good. Here's hoping this one doesn't do it. Did you try updating the firmware in case that fixes it for you? It also doesn't let me control the camera when I want charge using car's USB since it establishes data connection. I prefer exposure control (spot metering), but perhaps I might as well settle with EV, since it'd also make it more consistent. Another issue I've had with GoPro cameras was that the video frame pans towards the outside direction of long turns. I searched up, and they say it's a normal side effect of image stabilization, yet DJI is smart enough to not do that(!). I'm planning to play between stabilization settings as well. In the worst case, I can always stabilize it on my PC during processing.
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4 '21 Tesla Y Long Range AWD '19 Corvette Z06 Z07 (Track Build Thread) Last edited by X25; 08-11-2022 at 02:02 PM. |
#24 |
Drives: 2022 BRZ Limited
Car's looking good..you don't waste any time haha.. I've had mine for months but didn't even go to a track day or installed my coilovers yet
and now the heat here in SoCal I think it'll be best if I wait till SeptemberI wish I could go to the ORP with you again, I'll miss that
#25 | |
Made a quick test with EV settings, and well I don't think it was meaningful at all : P One thing it seems to have been useful for is how much camera pans the outer direction during a turn. I should try lesser stabilization settings, and perhaps just turn it off, and stabilize it myself. Looks like there will be only 6 or so cars tomorrow! I should have all the time I'd need to feel this new car..
#26 |
Finally had a few sessions, and got to learn about the car.MY best lap was 2:05 at 86 degrees F, and did a few more 2:05s later afternoon as well at 93+ degrees F. I'm guessing I can go lower even in this stock form, but next time I'll likely have the coilovers.
Here is the best lap of the day: A few remarks
I'll have a few weeks of hiatus while we have our overseas vacation, and will get back to installing the coilovers and seats when I'm back. I'd probably have the half roll-cage from Titan motorsports as well by then, and looking forward to seeing if it fits!
| The Following 2 Users Say Thank You to X25 For This Useful Post: | NoHaveMSG (08-14-2022), villainous_frx (08-14-2022) |
#27 |
... and here's the video comparing ReelSteady (GoPro's software that costs $99) vs. DaVinci Resolve (free for non-professionals) on post recording stabilization of the very same video:
| The Following 2 Users Say Thank You to X25 For This Useful Post: | gcmak (08-14-2022), villainous_frx (08-14-2022) |
#28 | |
Drives: Frs
I feel the steering lock up on my local canyon as well. What causes it? I’m not rubbing I’ve checked. I’m running 265 falken 615k+. I’m running kw v3.
Ridiculous!
| $5K for track build | Kulebrero1 | Tracking / Autocross / HPDE / Drifting | 27 | 05-08-2022 10:51 PM |
| GT86 CS V3 track car manual | ayau | Tracking / Autocross / HPDE / Drifting | 12 | 08-21-2013 12:03 AM |
| White GT manual Jan Build availlable | 86•BRZ | AUSTRALIA | 2 | 01-02-2013 12:45 AM |
| Black GTS Manual Nov/Dec build in ACT | FT86RR | Australia Classifieds | 1 | 08-23-2012 11:55 AM |
| 4/30 Build sheets for Manual and Auto FR-s | MrFRsLa | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 04-30-2012 06:26 PM |
