Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 07-20-2022, 07:49 PM   #15
Ok, I got to ask. What EXACTLY is the issue with the turn signals? What is BMW turn signals? I've seen other threads with people complaining about them.
This sums it up
https://www.autotrader.com/car-news/...t%20originally.
No doubt you would get used to it in time but then every time you jump into another car...
Old 07-20-2022, 07:57 PM   #16
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
This sums it up
That sounds idiotic! This, from the article, is exactly how I would feel:
"But here’s my question: Turn signals have worked the same way for decades, and they’ve been totally fine. Why fix something that absolutely, certainly, unquestionably isn’t broken? And maybe more importantly, why fix it with something that’s counterintuitive?"
Old 07-20-2022, 07:59 PM   #17
CincyJohn
Drives: 2022 MT Neptune GR86 Prem.
It's a turn signal stalk that returns to center rather than staying in place when the turn signal is activated. It also can have a "three blink" lane change feature (which is active when you get the vehicle), which is indeed infuriating, but which also can be easily turned off through the head unit. Once turned off, it behaves almost identically to a "standard" turn signal.
CincyJohn is offline   Reply With Quote
Old 07-20-2022, 08:05 PM   #18
removedonut
Drives: 2022 Toyota GR86 Premium 6MT
Originally Posted by CincyJohn View Post
Whatever - just trying to figure out what was being gained.
I gained the mechanical feedback on my turn signal lever that I prefer, and lost 40 dollars and an hour of my time. The community gained the knowledge that this is something that is possible to do.
I have been doing auto electrical work for most of my adult life and spending a few minutes repinning a connector doesn’t really constitute a massive expenditure of time or effort on my part. 40 dollars is also less money than I made in the time it took to do this retrofit. That cost/benefit analysis may be different for you, but I mainly did this because I like doing things that haven’t been done before.
removedonut is offline   Reply With Quote
Old 07-20-2022, 08:12 PM   #19
CincyJohn
All good man.
As I said, you may have also solved the hyperblink problem (or not) - I honestly don't know. In fact, I am 100% sure you would be in a better position to answer that question than I would.
Old 07-20-2022, 08:13 PM   #20
Ultramaroon
not playing cards
Ultramaroon's Avatar
I would do this in a New York minute, and I love the sentiment. Why bother with the frustration of getting used to something irritating when it can simply be eliminated?
10/10, sir!
Last edited by Ultramaroon; 07-21-2022 at 01:23 PM. Reason: punctuation - question mark was a period
Old 07-20-2022, 08:37 PM   #21
BlkTrax
Drives: Car
The video is only 15 seconds
This adds actual mechanical retention to the turn signals. When you activate the turn signal, it now physically clicks into place. In stock form, the stalk would instead return to center and you would have to push it in the other direction to cancel.
So just for some mechanical clarification.
All that is needed is the Headlight switch itself from a 17-20.
But your saying no other parts are needed ; that the physical contact to trip the switch back off (neutral) still exists on the current 2022 roll connector/steering shaft?
BlkTrax is offline   Reply With Quote
Old 07-20-2022, 09:05 PM   #22
removedonut
Correct.
Old 07-20-2022, 10:04 PM   #23
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
@removedonut
Thanks for this post! If someday I've own a 2nd gen 86, this would be the first mod on the list. I've tried the 2nd gen and this BMW stalk was driving me nuts.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 07-21-2022, 10:36 AM   #24
Spektyr
Drives: GR86
I really like this idea.
I want to put the steering collar extension in my car, but it wasn't enough of an excuse to bother with pulling the whole steering wheel apart. This is a significant bump toward the "worth it" column if I'm doing both at the same time.
I'm not familiar with the specific parts so I'm not completely clear on what would be involved but this seems like it could be the sort of thing where a kit could be built for complete "plug and play" compatibility. That seems like the sort of thing that would sell pretty well (I'd be a buyer).
I don't hate the way the GR86 turn signal works. It's absolutely fine the way it is.
What I hate is that it's different than every other car I've ever owned or driven. "Hate" is probably a strong word, but...
Spektyr is offline   Reply With Quote
Old 07-21-2022, 12:32 PM   #25
removedonut
I have updated the post with some crude MS paint diagrams and some semi-vague disassembly info.
Old 07-21-2022, 12:35 PM   #26
removedonut
Maybe. Connectors and pins for engine harnesses are pretty easy to find, but i’ve struggled when trying to find the same for minor interior harnesses. But yes, if there’s a male and female 20 pin connector out there that matches these connectors then someone could for sure make a plug-in adapter for this rather than require a repin of the harness. Might look into that if I get bored.
Old 07-21-2022, 12:51 PM   #27
Sasquachulator
Pavement Grey
This sums it up
On that note, I find it is more annoying swapping back and forth between an 86 and a BMW X1 where the wiper stalks activate opposite each other. I think it might be a german car vs japanese car thing.
In our 86 mist/single wipe is up, slow/intermittent/fast is down.
In our BMW X1 mist/single wipe is down, slow/fast is up (we have auto rain sensing in the place of intermittent...and it doesnt work properly half the time...the detection sometimes doesnt wipe my windshield until it is completely full of droplets and i cant see anything)
Old 07-22-2022, 05:29 PM   #28
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Thanks for finding and documenting a way to install the gen1 turn signal stalk with mechanical retention! Some will definitely appreciate it, and I'm sure you had fun figuring this out.
Personally I've been satisfied with the gen2 stalk in my GR86, especially after I turned off the 3-blink shortcut. If anything, now I want my daily (2016 Mazda 6) to have a "joystick" stalk, without mechanical retention. Interestingly, in my Mazda I actually like the 3-blink shortcut, but find it less useful in the GR86.
Follow the build thread for my GR86!
timurrrr is offline   Reply With Quote
LED DRL and turn signals Sasquachulator Other Vehicles & General Automotive Discussions 4 10-25-2021 11:27 PM
How to take apart frs Turn Signals? Hentai Cosmetic Modification (Interior/Exterior/Lighting) 6 10-12-2016 12:49 PM
Turn signals don't always automatically turn off one2onejackpot Issues | Warranty | Recalls / TSB 6 04-18-2016 07:35 AM
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 10:40 PM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-11-2012 11:23 PM
