Old 07-27-2022, 07:18 PM   #15
APEX Race Parts
FT86Club Official Vendor
APEX Race Parts's Avatar
Drives: Launch-Year Whiteout FR-S
When Function Meets Form
As wheel specialists, we understand that when it comes to reducing weight and increasing stiffness in wheel spokes, there is a big difference between functional and aesthetic side milling. Instead of milling a few negligible millimeters of depth just to look cool, our engineers optimized our new motorsport blanks to create narrower yet significantly deeper spokes with deeper side milling that is nearly 50mm wide on some wheels. The result is a stiffer “I” beam-spoke shape that also showcases a stunning aesthetic, and when you compare the depth and side milling of our spokes vs. many other wheel offerings in the marketplace, there is a stark difference.
If you haven't already, we recommend you read our technical write-up on our deeper and wider side-milling.
- Ryan
APEX Race Parts is offline   Reply With Quote
Old 07-30-2022, 12:52 PM   #16
Bobharp
Bobharp's Avatar
Drives: 86 Hakone
Originally Posted by APEX Race Parts View Post
86/BRZ Specific Fitments
<<< Join the Group Buy & Save $300 off + Free Shipping* >>>
The maximum discount tier has been unlocked! The Group Buy ends August 9th at midnight PST.
We don't rely solely on computer simulations or unverifiable in-house testing. We believe independent testing is critical to protect consumers in this unregulated industry. We chose STL, an independent lab in Ohio, to test our Sprint™ wheels far above JWL standards, including increases in testing duration, impact drop height, and total load.
Learn more about our rigorous independent testing.
Questions?
Call: 925-245-0773
Email: expert@apexraceparts.com
Web: www.apexraceparts.com
Hours: M-F 9a-5p PST
[/QUOTE]
Pledged for for the group buy.
Are these still the expected shipping dates?
Are the Huff BRZ/86 TPMS units programmable? I plan on keeping my awesome stock rims and (hopefully) doing the summer/winter swap.
I've been watching this thread (https://www.ft86club.com/forums/show...27&postcount=1) and wondering what you recommend.
Thanks!
Bobharp is offline   Reply With Quote
Old 08-02-2022, 08:59 PM   #17
APEX Race Parts
Questions?
Call: 925-245-0773
Thanks![/QUOTE]
Hey Bob,
I think I emailed you earlier but the TPMS for both generations of sensors that we sell are certainly programmable. Currently, I believe those ETAs are correct, but we'll send out an update both via GangUp, email and here on the forums if anything does get pushed back.
-Tom
The Following User Says Thank You to APEX Race Parts For This Useful Post:
Bobharp (08-03-2022)
Old 08-02-2022, 09:05 PM   #18
APEX Race Parts
Learn more about our unique Wheel Replacement Program
This program has flown under the radar for quite a few years, but is something many APEX customers rave about. It can be hugely valuable for racers that make contact with another car or find themselves taking "the scenic route" off-track, and equally as valuable for enthusiasts that run out of talent leaving their local Cars and Coffee. Our goal wasn't just to make pushing your car to the limit more affordable, but also to reduce the chances of a bent wheels being sold in the second hand market.
- Ryan
Old 08-02-2022, 09:29 PM   #19
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Beautiful work guys. Absolutely drool worthy. I don’t track my care and can’t really use any more than 8” of width, but these are simply gorgeous. JP
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
APEX Race Parts (08-04-2022)
Old 08-03-2022, 03:57 AM   #20
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
These are just stunning.
Originally Posted by humfrz
I'm old and lazy
Old 08-07-2022, 03:24 AM   #21
Rcode
Rcode's Avatar
Drives: Ford Fiesta ST, 2022 Subaru BRZ
So the 17x8.5 with 235/40's work as a direct bolt on with no issues on stock suspension?
I was leaning on 17x8's since the 9's appear to have issues rubbing on the (mostly) stock suspension I plan on keeping for another year or two. However, the 8.5 wheels kind of solves my issue of buying a wider set of wheels whenever I eventually upgrade to coilovers down the road. I don't think I would miss out much from a 235mm on the 8.5 vs. 245 on the 9.
That would just leave the problem of deciding on satin bronze or anthracite as my top choice...
Rcode is offline   Reply With Quote
Old 08-07-2022, 12:40 PM   #22
billstock67
Drives: 2017 Toyota 86
My issue with 235/40 is limited selection of tires.
billstock67 is offline   Reply With Quote
The Following User Says Thank You to billstock67 For This Useful Post:
SuperTom (09-14-2025)
Old 08-07-2022, 03:51 PM   #23
Rcode
Rcode's Avatar
I definitely agree, though 245's should also fit with some camber up front reading the fitment guide. I wonder if my measly -2 degrees of camber will clear that with 8.5's.
I'm also super happy to read that the rear fenders do not have to be touched.
Old 08-07-2022, 04:41 PM   #24
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
There's no issue up front fitment wise. You can run 17x9 et 35 with 245 up front without rubbing. Why not run 245 on the 8.5" wheel?
I also ran 17x8 et48 on the stock suspension with no rubbing. Running 215 on those.
dragoontwo is offline   Reply With Quote
Old 08-08-2022, 06:54 PM   #25
Rcode
Rcode's Avatar
I was always under the impression that 245's wouldn't fit without coilivers, but if that's not the case I would be more than happy to buy a set of RS-4's in that size. Either way, I'll have time to figure it out before these ship.
Old 08-08-2022, 08:40 PM   #26
dragoontwo
dragoontwo's Avatar
There's more room up front to play with than in the rear. I ran the same wheels on my first gen with stock suspension and -1.9 deg camber. The clearance to the spring perch was close.
From the apex fitment page:
Front & Rear: 17x9" ET48
Available in: VS-5RS
Popular Fitment
These wheels require a 5mm front spacer for strut clearance on OEM Gen 2 suspension. If additional negative camber has been dialed in at the knuckle, a larger spacer may be required.
245/40-17
The Following User Says Thank You to dragoontwo For This Useful Post:
Rcode (08-08-2022)
Old 08-08-2022, 09:10 PM   #27
APEX Race Parts
Yep, we released the 17x8.5" ET44 to ensure Gen II owners have an easy bolt-on upgrade. Our wider 17x9" ET48 are for gen II track enthusiasts wanting to maximize tire sidewall support, and they work best with aftermarket coilovers and negative camber dialed in.
- Ryan
The Following 3 Users Say Thank You to APEX Race Parts For This Useful Post:
nathand (08-13-2022), PNW Shaggy (08-15-2022), Rcode (08-08-2022)
Old 08-26-2022, 01:46 PM   #28
JD001
JD001's Avatar
Drives: Subaru BRZ
- Ryan
Hi Ryan, any more images of Twins wearing the wheels?
► APEX | Introducing The All-New Forged EC-7R 5x100 86/BRZ Wheel Line APEX Race Parts Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 12-09-2022 04:14 PM
► APEX | Fully Forged Lightweight 86/BRZ Wheels APEX Race Parts Wheels and Tires 59 07-20-2022 01:20 PM
SOLD : Apex EC-7R Forged 17x9 Bronze Wheels MoarGeesPlease Wheels and Tires 5 10-04-2021 10:40 AM
► APEX | NorCal 86/BRZ Needed For Photoshoot With Our All-New Forged EC-7R Wheels APEX Race Parts Northern California 3 07-06-2020 05:05 PM
TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance Jason@DSG Wheels and Tires 37 12-17-2014 03:50 PM
