Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 | |
Drives: 2020 BRZ Sport Tech RS
![]() The overall diameter is 2x sidewall height + wheel diameter, so while a 235/40 has a shorter sidewall than a 225/45, you need to add in another inch for the increased wheel diameter. 235/40R-18: (235 * 0.4 * 2) + (18 * 25.4 mm per inch) (188 mm total sidewall height) + (457.2 mm wheel diameter) = 645.2 mm overall diameter 225/45R-17: (225 * 0.45 * 2) + (17 * 25.4 mm per inch) (202.5 mm total sidewall height) + (431.8 mm wheel diameter) = 634.3 mm overall diameter 645.2 / 634.3 = 1.017, therefore the 18" combo is theoretically 1.7% taller. Michelin's specs for another model of tire (Pilot Sport All Season 4) say 815 revs per mile for the 235/40R-18's and 833 revs per mile for the 225/45R-17's, which suggests a difference of slightly more than that - about 2.2%.
The Following User Says Thank You to Tatsu333 For This Useful Post: | PulsarBeeerz (06-06-2022) |
#16 | ||
30 minute maintenance
Drives: My18 wrxsti My19 brzts
Wait until my Flex capacitor hits 88
#17 |
Drives: 2013 BRZ Sport-Tech
I see OP's comment about the claimed weights for each wheel (sometimes claimed weights don't match up with actual weights), but has anyone double checked the tire weight?
Also, it's not just about unsprung weight but also moment of inertia (related but not necessarily directly to wheel and tire weights). A significant reduction of tire weight will have a bigger difference to acceleration than weight close to the hub (axis of rotation). The new wheels, though the outer band is 1/2" further from the axis of rotation, may have a lighter outer band but more weight closer to the hub (leading to the proposed increase of ~2.5 lbs). This would also reduce the moment of inertia, leading to higher acceleration. It may be that none of this has happened and there isn't actually any difference at all. I'm just thinking these are some possibilities. |
#18 |
friendly
Drives: 17' 86
Can't even find these tires in the us lol
Seek comfort in discomfort.
#19 |
Different model of Michelin (Pilot Sport All Season 4) because TireRack doesn't list the Pilot Sport 5, but in that model, a 235/40R-18 is 24 pounds vs. a 225/45R-17 at 23 pounds, so heavier tires in addition to heavier wheels likely for the OP.
#20 | |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
![]() https://www.tire-reviews.com/Article...ot-Sport-5.htm |
Michelin Pilot sport as/4 | misterfly | CANADA | 13 | 12-09-2021 02:35 PM |
215/40/r18 Pilot Sport 4s from PP/tS | Chuckls | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 10-08-2018 12:51 PM |
Michelin Pilot Sport A/S 3 | LALFAN | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 02-13-2016 02:13 PM |
Pilot Supor Sport 225/45 or Pilot Sport 3 215/45 | ChrisD | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 08-01-2015 03:04 PM |
Pilot Sport A/S 3 | PantsDants | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 08-06-2013 01:02 PM |
