Old 05-19-2022, 01:16 PM   #15
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
17X9 +45, 245 tire. No rubbing with coils. I have no idea why you would be rubbing.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 05-19-2022, 03:35 PM   #16
strat61caster
strat61caster's Avatar
Agree something sounds weird. I rub at full lock with 245/40/17 on 17x9+45 on the inner fender liners and tie rod but nowhere else, adding a 5 mm spacer to +40 solves it completely.
-4 ish degrees of camber (plates and bolts required) about 1.5” lower then stock.
If your gauge reads a little low 25 psi isn’t crazy. I’ve run down to 26 but usually like it higher. Haven’t used falkens in this size/wheel combo tho.
ineedyourdiddly
Old 05-19-2022, 05:37 PM   #17
Autoenthusiastasm
Drives: 2013 BRZ Limited - stock
Hopefully the pictures transferred. Rub is both forward of the coil over and behind it. The rub on the sway bar is from before I removed the camber bolts. Ride height is about 6 1/2 at the front pinch weld.
Autoenthusiastasm is offline   Reply With Quote
Old 05-19-2022, 06:02 PM   #18
deca
Drives: Halo 860
That seems really high to me, is that stock ride height? I'm around 5 inches at the pinch welds, maybe that could be it?
deca is offline   Reply With Quote
Old 05-19-2022, 06:08 PM   #19
Code Monkey
Drives: Subaru BRZ
Nope, I was at 5" pinch weld height and it rubbed.
Code Monkey is offline   Reply With Quote
Old 05-19-2022, 06:17 PM   #20
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Fallen RT 660 fitment
I have rub too, but I mostly suspect it is due to my spring rates being too soft. -3.6F( I think) ride height -1.5" from stock on 17X9 +35 with 245/40's. Mine hits everywhere. Top, inside, front. I am missing quite a bit of liner because of it.
Old 05-19-2022, 09:23 PM   #21
Autoenthusiastasm
Have to keep it high as I drive year round in snow, speed bumps, steep entrances . Spring rates 8K or 450#
Old 05-19-2022, 10:05 PM   #22
Pat
Pat's Avatar
Drives: 2023 BRZ
Are those B16s?
Old 05-20-2022, 09:22 AM   #23
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Pat View Post
Are those B16s?
They are T2’s
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Pat (05-20-2022)
Old 05-20-2022, 09:17 PM   #24
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I run RT660 245/40r17 on 17x9+40 Konig Hypergrams. I'm lowered around 1.25inches at all 4 corners and run -3f/-2.2r camber on RCE SS-1 (6k/6k rates) I don't rub at all under normal driving conditions but I can induce a tiny bit of rub while on track under trail braking on hard right hand turns under compression on the front left wheel but I'm not sure exactly where I'm contacting yet, when I looked last time, I couldn't find evidence of the rubbing on the wheel well.
Lynxis is offline   Reply With Quote
Old 05-21-2022, 08:08 PM   #25
Don't turn full lock, or use a small spacer on the front wheels.
Old 05-23-2022, 02:30 PM   #26
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by Breezio View Post
Not sure why you would be rubbing while braking.
The tire can rub into the fender above it under braking if the range of motion of the suspension is not set up correctly.
Follow the build thread for my GR86!
timurrrr is offline   Reply With Quote
Old 05-24-2022, 04:37 PM   #27
Or if the driver pitches the car too abruptly.
Or if there's a track element that causes additional compression.
It can be many things.
Old 05-26-2022, 01:03 AM   #28
Lynxis
Lynxis's Avatar
Just a follow-up to this, my wheel isn't rubbing at all, it's actually my mud flap dragging on the ground on hard right handers. They are the stiff Rokblokz plastic flaps and make quite the noise when they contact pavement which I mistook for fender rubbing. I like how they look but I don't winter drive the car anymore so I bet they will just introduce drag at this point so I might just take them off. Maybe worth seeing if I get a better top speed down the straight without them.
The Following 3 Users Say Thank You to Lynxis For This Useful Post:
CSG Mike (05-26-2022), strat61caster (05-26-2022), timurrrr (05-26-2022)
Has any FRS/BRZ fallen to LS V8 engine swap? suzuka Engine Swaps 216 09-15-2016 03:15 PM
I've fallen and I can't get up dvasqu01 Off-Topic Lounge [WARNING: NO POLITICS] 19 02-15-2016 12:39 PM
I've fallen for my FR-S.. Cyrious G FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 18 01-09-2013 04:47 PM
New Zealand Sends off A Fallen Soldier travace Off-Topic Lounge [WARNING: NO POLITICS] 3 09-05-2012 12:30 AM
Have you fallen in love with this car? Bristecom Scion FR-S / Toyota 86 GT86 General Forum 26 05-25-2012 06:39 PM
