#15 |
Drives: 2013 Subaru BRZ
i haven't tried that, i didn't even know that existed lol. how do u do that? is there a guide or do u literally just unplug the battery completely and step on the brake a few times? no voltage has always stay steady at 12.9 which i know is a little high.
| The Following User Says Thank You to Jynx For This Useful Post: | Ultramaroon (05-13-2022) |
#16 |
if you mean just unplugging the battery yes, i have to anyways to get rid of the engine light/limp mode but i dont get what u mean by the brake.
#17 | |
not playing cards
I just looked at the wiring diagram and I see that the only way for the purge valve to be stuck open is for a short in the wire between it and the ecu, the ecu to be telling it to open for some reason, or for that control transistor (mosfet, whatever) to be shorted.
#18 | |
#19 |
not playing cards
It's possible. I wouldn't start with that unless I had money to blow. Even then, I think there's a whole thing to pairing the ecu to the car. Are you up for that?
#20 |
#21 |
do u think if there wasn't enough pressure in the lines that the ecu would keep the valve open until there was and then it would tell it to close? i wonder if there isn't enough and the computer doesn't like that and it tries to keep it open. is that possible or is that a dumb thought?
#22 | |
not playing cards
#23 | |
so it wouldn't be possible or would it and it's just timing out? ive had a lot of people say it could be the gas pump rubber seal Sent from my iPhone using Tapatalk |
#24 |
not playing cards
That's the first thing to rule out. I think you know what needs to happen. Just have to start testing.
#25 |
#26 |
not playing cards
There's a link to the service manuals in my sig line.
#27 |
yes. i also had a shop smoke test it for leaks and nothing was leaking. only thing that was weird was when they hooked it up to obd2 reader the shop got a christmas tree so maybe ecu issue?
| Help diagnosing P0441 code | 1Saucyyy_brz | Issues | Warranty | Recalls / TSB | 3 | 09-18-2022 06:45 PM |
| Engine code p0171 and p0441 | frscory | Issues | Warranty | Recalls / TSB | 6 | 02-20-2022 07:06 PM |
| Having trouble with code p0441 | Jynx | Issues | Warranty | Recalls / TSB | 5 | 02-19-2022 06:17 PM |
| p0441 cel code | bryan.catano93 | Engine, Exhaust, Transmission | 5 | 03-12-2018 12:38 PM |
| Check engine code P0441 | Gibson | Engine, Exhaust, Transmission | 0 | 11-23-2016 06:39 PM |
