Old 04-27-2022, 01:56 PM   #15
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Solostorm for AutoX.
AIM Solo 2 DL for anything else.
Not to waste your time, but is there a short version of why?
dragoontwo is offline   Reply With Quote
Old 04-27-2022, 02:29 PM   #16
They capture a lot of data that you can use to help yourself go faster.
1hz phone systems are useless, and most bluetooth adapters do not have a high enough poll rate to be truly useful beyond the most basic "this is your lap time +- 1s", and "this was roughly your speed within a 1s window". Mostly useless.
dragoontwo (04-27-2022), Kelse92 (04-27-2022)
Old 04-27-2022, 02:35 PM   #17
M0nk3y
I would recommend RaceCapture Track/MK2 (or MK3 now I suppose) but honestly the app and analysis is such trash and the owner is resistant to resolve actual bugs so I can't recommend them anymore.
It's a great recorder. Has always been within hundredths of an actual transponder but besides predicative laps you won't pull much usefulness out of it.
So, I think I'm jumping ship and going AIM Solo 2 DL.
@CSG Mike - any platform specific mounting solutions?
Kyle H. - #89 STX
Old 04-27-2022, 02:38 PM   #18
Suction cup to window. You want the unit to have a clear view of the sky to get a good GPS signal.
PM to order.
Old 04-27-2022, 02:58 PM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I've run a phone app to a 10hz GPS back to back with my Solo2 and a transponder. Negligible difference. Yes, running it off the phones 1hz base GPS is pointless but that is not what many of of are talking about doing.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
timurrrr (05-03-2022)
Old 04-27-2022, 03:07 PM   #20
RedReplicant
Drives: None
I agree that AIM is the way to go, but the annoying part about an AIM Solo 2 DL is that you can't add other sensors that aren't made available over CANBUS, you need to go up to a MXM or something to add in say, oil pressure. Obviously, if you have an aftermarket ECU you can pipe whatever you want into a DL but it is worth noting.
Also, the Smartycam 2.1 makes it easy but the video quality is garbage compared to basically everything else out. It writes the data overlay onto the video live so it needs the hardware to handle that, Smartycam 3 is coming out soon that does 1080p.
RedReplicant is offline   Reply With Quote
Old 04-27-2022, 04:24 PM   #21
That, however, doesn't change the fact that the poll rate from your CANBUS is way too low.
The GPS is only really good for seeing speeds and lap time. That's only the tip of the iceberg for data.
Old 04-27-2022, 04:26 PM   #22
Resolution is low(720p), but the actual video is quite good, and is solid state. If you chucked the Smartycam out of your car at 180mph, it would record the entire tumble.
All you need for the real-time overlay is a Solo/Solo2 DL. Of course you can use other AIM hardware as well.
Real-time overlay is THE selling point of the Smartycam. It's invaluable when you're in a time crunch, and overlays the data precisely without needing you to sync manually.
Old 04-27-2022, 05:18 PM   #23
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Which adaptor? The BLE adaptors have some trouble when querying a bunch of PID's. It is not terrible when using a good one like MXLink, some guys have logged data rates as high as 50hz logging half a dozen channels. I don't log that much stuff but they are not bad for far less then an Aim DL.
I had a sour experience with Aim so I am not really that sold on them. The DL's where not available and I bought a Solo2 and I have never been happy with it. Mine has been sitting unused and needing a battery for about 8 months.
Old 04-27-2022, 05:37 PM   #24
dragoontwo
dragoontwo's Avatar
I have the OBDLINK MX. I'll start with the racechrono this weekend.
Old 04-27-2022, 05:59 PM   #25
RedReplicant
Drives: None
I agree, I spent the money to buy it myself. I don't think the complete package can be beat.
Just saying that the video quality can be a bit of a let-down for the total price of entry and that there is an input gate on the DL itself. If you decide you want extra input you'd step up to a MXM or dash and then you realize you need a Data Hub and the expensive AIM sensors. Most people don't need it, but when you do it is kind of an annoying surprise.
The Following User Says Thank You to RedReplicant For This Useful Post:
CSG Mike (04-27-2022)
Old 04-27-2022, 06:09 PM   #26
I'm 100% sure I would have recommended a DL for you, as a Solo2 is nothing but a fancy lap timer.
Have you tried reaching out to AIM for a replacement battery?
Old 04-28-2022, 11:41 AM   #27
strat61caster
strat61caster's Avatar
Use the race capture with solostorm or circuit storm. A+ accessible data analysis instantly after your laps.
Edit: oops, didn’t see the user name, you clearly know this already and have your reasons for jumping ship. :beer:
ineedyourdiddly
Old 04-28-2022, 12:09 PM   #28
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don't think there where any available and I was impatient and got the non DL.
I sourced a battery for it but I have some weird issues with my Solo2 that were kind of annoying. Every time I start a session it would always change the timing setup between predictive and rolling randomly. I also was getting glitchy data when I would port to race studio.
Fs racecapture track data logger system -SOLD- redlined600 Audio/Visual, Electronics, Infotainment, NAV 0 07-07-2018 03:14 PM
Data acquisition system to try during track days mabviper CANADA 40 09-12-2017 03:15 PM
Track Data Logs! DarkSunrise Software Tuning 31 07-10-2017 02:56 PM
How about we make a track tire data thread? ddeflyer Tracking / Autocross / HPDE / Drifting 0 06-09-2014 01:25 PM
iPhone track data logger app? Wonderbar Tracking / Autocross / HPDE / Drifting 14 05-07-2013 03:31 PM
