Old 03-05-2022, 12:04 PM   #15
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I have one, it's not bad with it.
So the general consensus is live with the midpipe? Even with the little kink? I guess if it made that much difference, JDL and Nameless would make one.
Old 03-07-2022, 12:29 PM   #16
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
A cat back is only worth a couple HP so I don't think it's a big deal. I run the stock mid with a nameless track pipe.
Old 03-08-2022, 11:27 PM   #17
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
worth a read..
https://www.ft86club.com/forums/showthread.php?t=103125
The Following User Says Thank You to mav1178 For This Useful Post:
blsfrs (03-09-2022)
Old 03-19-2022, 05:16 PM   #18
blsfrs
blsfrs's Avatar
Went with Nameless
I went with the 2.5 catted Nameless with the resonator. I had to Google to find out what Helmsholtz resonance is and how it might work. I gather it is why there's a sound when you blow in a bottle but how it works in an exhaust system evades my brain cells.
Fitment is fairly good. The overpipe portion wasn't exactly in the center of the space. If I had used their 3" pipe, it might have rubbed the bottom of the head. The front flange could be a little thicker. It's quieter than what I took off. It did not come with new hardware. Nameless advised reusing bolts and gaskets.
And NO, that is not Tommy's blood on the sawhorse.
Old 03-19-2022, 05:40 PM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you get a chance I would replace the nuts on the header to overpipe connection with some crimped lock nuts, also called top locks, or distorted lock nuts. They like to work loose and those hold much better. You can use 3/8's there instead of 10mm as they are more commonly available if you replace the bolts too. Just don't use stainless or you will never get it off without cutting it. That connection likes to come loose on aftermarket setups for some reason.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
blsfrs (03-20-2022)
WTT Invidia catless front pipe for a resonated/catted front pipe nickmerronesucks Want-To-Buy Requests 3 05-10-2016 03:25 PM
Gains from aftermarket catted front pipe vs stock front pipe? Vmax911 Engine, Exhaust, Transmission 4 01-20-2014 02:42 PM
Group Buy: TSUDO Performance Hi-Flow catted Test Pipe/Front Pipe/ Downpipe JonMotoring Groupbuys 65 08-27-2013 01:33 PM
WTB: Perrin Over Pipe + Catted Front Pipe + Cat Back (Resonated) coolaron Engine, Exhaust, Bolt-Ons 0 07-13-2013 04:37 PM
