Old 03-05-2022, 09:49 PM   #15
Sam86
Drives: Toyota 86 GTS
Originally Posted by ItsReiko View Post
I have in the past also noticed that e85 doesn't give that sudden punch in acceleration once I hit 4.5k rpm. When on the stock tune, it almost feels like vtec kicks in at that point lol.
E85 probably does pull harder at lower rpms, but for some reason gas feels like it has more grunt from a stop to me. Could be because E85 tune is smoother giving me the impression that it is not pulling as hard. Going to test it again on my next tank.
I'm also assuming OFT tunes are geared towards UEL headers, which could explain what I feel since I have Tomei EL headers. Might consider ecutek if it wasn't for California's new law that requires stock tune for SMOG.
Don’t know if it’s the same for you, but gas might feel like it has more grunt due to the change in exhaust tone.
For me after switching to e85 I noticed my exhaust was a lot more subdue. Sounded smoother compared to gas which would burble and sound louder.
I’m fully catless at the moment yet I still remember being more cautious of how loud my car was (when avoiding police) when I was on gas with my stock front pipe. Even if I rev up to 5k and let off I get no burbles
Sam86 is offline   Reply With Quote
Old 03-06-2022, 06:25 PM   #16
ItsReiko
ItsReiko's Avatar
Drives: 2017 subaru brz
Agree 100%. I just switched back to the Oft e85 tune yesterday and was surprised at how much smoother the exhaust note is compared to gasoline tune and revving it in my garage is noticeably quieter.
ItsReiko is offline   Reply With Quote
Old 03-07-2022, 04:15 AM   #17
tomm.brz
Drives: brz 2017 hksv2
it s mostly cause of more advanced ignition timing
it tames the deepening of the sound while increasing power
For any of you that is using OTS E85 tunes... You still have a lot of headroom everywhere if you only were using custom refined tune
The Following User Says Thank You to tomm.brz For This Useful Post:
Dzmitry (03-07-2022)
Old 03-07-2022, 12:12 PM   #18
Celica00
Celica00's Avatar
Drives: 86
So there's still potential for OTS users to get more out of the tune? Is that something a local shop could do? Or should we reach out to Openflash directly?
Celica00 is offline   Reply With Quote
Old 03-07-2022, 01:15 PM   #19
tomm.brz
yes, but don t waste time with Shiv, steve99 or Wayne are better
i can also modify it for you, up to you
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
Celica00 (03-07-2022), Dzmitry (03-10-2022)
Old 03-07-2022, 04:52 PM   #20
JSIdriver51
Drives: 2014 Subaru BRZ WRB
Hello everyone,
I’m the second owner of the 2014 BRZ and bought it at 70k. Before me it was only run on 91; however, I switched to corn at 72k and ran it exclusively on the OFT Stage2+e85 map (no flex fuel). I did not notice any power losses and was able to take the car to official drag races down at Race Legal in Qualcomm Stadium; although I can’t remember my specific time, I did win 1st place street stock (I beat a V6 mustang by the smallest margin possible). At roughly 87k I added a sprintex supercharger and went with an ecutek flex tune from Mike over at Moto-East/Xero Limit; I still haven’t ran 91 as I’ve only been on e85 and I am now at 118k and going. If it helps, I change my oil (Schaffers) every 3k and switch between 0w20 in the winter/colder months and 0w40 in the summer/hotter months; I occasionally (like once a month if I remember) run a serving of the lucas oil e85 conditioner/stabilizer to hopefully prevent the fuel system from being gummed up as some people claim may happen. The vehicle is used for everything if anyone is curious (daily, track, autocross)
To summarize:
72k on 91
15k on e85 NA
31K on e85 boosted
Total: 118k on stock block with 72k on 91 and 46k on e85
I have attached the link for the product I use
https://www.autozone.com/fuel-and-en...E&gclsrc=aw.ds
JSIdriver51 is offline   Reply With Quote
The Following User Says Thank You to JSIdriver51 For This Useful Post:
ItsReiko (03-08-2022)
Old 03-13-2022, 05:14 PM   #21
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
Drives: 2014 BRZ Premium, WRB
Just curious, has anyone running flex fuel with forced induction in a CARB-compliant state successfully passed emissions?
vfrqqq is offline   Reply With Quote
Old 03-20-2022, 07:26 PM   #22
jflogerzi
jflogerzi's Avatar
Not gonna happen ever
2013 Series 10 FRS #553
Old 04-21-2022, 07:07 PM   #23
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
So why not? Is it because a tuned, forced induction FA20 will produce more emissions and therefore it would exceed allowable amounts or because the emissions would be so much lower than the test would "expect" to see and fails because the assumption is that something else must be wrong to result in lower numbers. I'm not trying to be argumentative, I literally just don't know. I'm going on the high-level assumption that using flex fuel = lower emissions, but I have no idea how forced induction affects that assumption in practice.
Old 04-21-2022, 07:36 PM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Carb only applies to CA. CARB=California Air Resource Board. I do our emissions certifications at work. For carb it would have to be a carb certified setup. So unless the manufacturer is going to pay for the testing($$$) and apply for the cert there isn't such a thing. It would also be a locked tune due to that.
The only way to know in your area is to run the car at an emission test facility and see if it passes.
Old 04-22-2022, 12:17 PM   #25
FrickingReallySlow
Drives: 2015 FR-S
Wink
hypothetically doable if you have "a guy" and $$$ to potentially spend
FrickingReallySlow is offline   Reply With Quote
Old 04-25-2022, 05:59 PM   #26
Grady
Grady's Avatar
I think you will need to add some more $ to that to get done.
The Following User Says Thank You to Grady For This Useful Post:
Dzmitry (04-27-2022)
Old 05-06-2022, 04:05 PM   #27
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
2014. 55,000 miles. About 15,000 on E85. Borla header, Berk free-flow cat front pipe, Phantom electric supercharger (Switched off right now till I can find the boost leak.) Strong, linear pull through the full torque range. Significant improvement over stock.
Qwimby1 is offline   Reply With Quote
The Following User Says Thank You to Qwimby1 For This Useful Post:
ItsReiko (05-10-2022)
Potential buyer looking for stats on range of manual Trans cars jimmy2shoes Scion FR-S / Toyota 86 GT86 General Forum 56 03-18-2017 04:38 PM
FR-S / BRZ reliability stats mkaresh Scion FR-S / Toyota 86 GT86 General Forum 82 03-12-2017 02:40 PM
Just some fun stats on boxer motors bluesblue AFRICA 17 10-16-2016 05:13 AM
Stats project ric342 Off-Topic Lounge [WARNING: NO POLITICS] 25 11-02-2014 12:11 PM
Interesting Fuelly Stats MannyO Engine, Exhaust, Transmission 6 08-25-2012 02:05 PM
