Old 01-18-2022, 08:45 AM   #15
grumpysnapper
grumpysnapper's Avatar
Originally Posted by blsfrs View Post
Do you run a rear diffuser?
No I dont (and cant, as i do a lot of dirt roads), but I think it could be a benefit... it could possibly mean you could run a larger core and also perhaps use it to direct flow into the radiator.
grumpysnapper is offline   Reply With Quote
The Following User Says Thank You to grumpysnapper For This Useful Post:
blsfrs (01-18-2022)
Old 01-18-2022, 09:03 AM   #16
Ashikabi
Ashikabi's Avatar
Diffuser technically shouldn't have any flow over the top
The Following User Says Thank You to Ashikabi For This Useful Post:
blsfrs (01-18-2022)
Old 01-18-2022, 09:14 AM   #17
grumpysnapper
lol that reverse light is awesome.
Have you ducted your radiator? The front one I mean.
No I haven't , my thinking is that because
I dont want to run bonnet louvres, and I have a large alloy sump guard fitted I simply can't get the air out of the engine bay.
It's interesting when I have the car jacked up and running, how much better the flow is when the fans kick in when the sump guard is off...and how when it's bolted back on, you can hear the fans working harder, with much reduced flow past the guard.
Originally Posted by Turdinator View Post
Where in the cooling circuit are you pulling from and returning to?
I'm running a 16mm "T" connector immediately at the start of the heater inlet pipe at the top of the engine, which runs down to the pump, then on the return leg runs into another "T" just before the heater pipe return hits the water pump.
So effictively its a circut that bypasses the heater unit (but the heater can still operate if needed)
Originally Posted by 86TOYO2k17 View Post
This is pretty sweet setup.
You could also replace sections of the lines to/from the rear rad with something like this
CK100-8 Single 16 Inch Pass Heat Sink Super Flow Fluid Cooler.
Also if you don’t have already a radiator mister helps a lot. A lot of rally guys use this.
Yeah those heat sink coolers could be good, but its a super tight squeeze to even get 5/8" hose to the rear and back, and tucked in so it wont get hit by rocks etc.
I think you're right about the water mister, that could be my final play if I still have dramas.
Old 01-18-2022, 10:53 AM   #18
Ashikabi
Ashikabi's Avatar
Ducting is still important. As you want the air coming through the grill to actually go through the radiator instead of around it. As I'm sure you can imagine, radiators are an air RESTRICTION and it would much rather go around then through.
Depending on your usage of the vehicle, you might be about to modify your cowl(windshield wiper surround) to allow air to escape up the windshield without modifying the hood itself. I'm not sure what affect that opening might have during daily driving. Cause your climate control air to be hot? The OEMs seal it up for a reason, but I couldn't tell you what it is. It's not uncommon for people to put risers under the back of the hood to achieve that gap. They seem to do ok. Modifying the cowl would be nearly invisible from the outside
Old 01-18-2022, 11:37 AM   #19
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Making a gap at the back of the hood might be counter productive as there is high pressure air in front of the windshield (when the car is moving at speed) that would limit the air flow from under the hood. I fabbed up some garnish vents. That area seem to have relatively low air pressure.
Old 01-18-2022, 11:55 AM   #20
Ashikabi
Ashikabi's Avatar
But is the pressure higher than in the engine bay
Old 01-18-2022, 12:32 PM   #21
blsfrs
blsfrs's Avatar
Good question. It is my understanding that both areas have high pressure. That's why hood vents are placed closer to the front and/or sides of the hood where the relative pressure is lower.
Old 01-18-2022, 04:18 PM   #22
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you put a gurney flap at the front of the opening it helps suck air out by creating a low pressure void. My Driveway Labs duct is designed that way and it moves quite a bit of air. I believe the gurney is also on the Verus ducts.
Old 01-18-2022, 04:45 PM   #23
blsfrs
blsfrs's Avatar
I can't visualize where the Gurney flaps you describe are located. I've seen them on rear spoiler and wings but not on the front of a car. Any Pictures?
Old 01-18-2022, 04:58 PM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
This is from Verus's webpage, but you can see the little flaps at the front of the ducts. This is also how splitter endplates help, they pull the air from the wheel wells.
I am not sure how having the windshield behind would affect things. Sounds like some string testing would be in order if someone where to try this
Old 01-18-2022, 08:48 PM   #25
cactus
cactus's Avatar
Drives: 13 SWP BRZ
How are the lines protected under the car? I'd be concerned with losing coolant for how little extra surface area you added. Interesting idea though.
cactus is offline   Reply With Quote
Old 01-19-2022, 06:33 AM   #26
grumpysnapper
For sure I agree, but my cooling issues are specific to a low speeds and high revs combination, when the fans are doing the heavy lifting (which is also why I added the second oil cooler with fans). I dont really have any cooling issues in other circumstances.
In reality it adds an extra %20 surface area, and as it is a %30 thicker core, probably a little more.
The lines run protected along side the brake lines (under the underbody cover), then skirt around the bottom of the wheel well, but behind the damper, then into the rear cover.
I will be making a small alloy shield for the small portion where they enter the under body cover along side the brake lines.
soundman98 (01-19-2022)
Old 01-28-2022, 10:42 AM   #27
grumpysnapper
Decided to give the setup a proper check after a week of hard use, so took off the rear bumper.
Its working really well, temps appreciably lower in areas/uses that used to concern me, and cool down after a hard run is noticeably quicker.
It's venting very well, and appears to be drawing a reasonable air flow through when the car is at speed, and the fans are not operating... the negative pressure at the rear might actually be working to some degree.
So far, a success. (touch wood!)
The Following 3 Users Say Thank You to grumpysnapper For This Useful Post:
blsfrs (01-28-2022), jrhudson (02-01-2022), NoHaveMSG (01-28-2022)
Old 08-23-2025, 12:08 PM   #28
B T
Great design, I think you've inspired me to move my air to water intercooler to the rear
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
SuperTom (08-31-2025)
FS: TRD "D oval" exhaust, OEM engine mounts, "STi" Radiator Cap cover Dave-ROR Engine, Exhaust, Bolt-Ons 1 05-18-2020 04:34 PM
FS: New H&R TC112 Rear Camber Bolts, PAC 2.5" Helper Springs customfab87 Brakes, Suspension, Chassis 0 02-08-2016 11:41 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 03:30 PM
Something new for us, mounted up a set of 19" wheels on the FRS - NOT BAD! WheelDude.com FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 44 10-01-2013 11:42 AM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 07:34 PM
