#15 |
Drives: 2016 Scion FRS Release Series 2#439
Amazon
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) |
| The Following User Says Thank You to Muskoka800 For This Useful Post: | chipmunk (07-14-2023) |
#16 |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Yes, replace the OEM RTV. It's overuse at the factory will drop beads into your oilpan and eventually collect at the oil inlet and block the screen and cost you an engine due to it causing low oil pressure. This is the main way these engines fail. I got 115k on mine before it did this to me.
Tuning shop installed my replacement engine in said this is common with the FRS/BRZ/86 platform. He opened pulled the pan on the replacement motor to remove the excess RTV and used less RTV putting it back together. Surgeline shop in south Portland, OR area. |
| Chasing an exhaust leak -Donut gasket or gasket exhaust came with? | xZAMx | Engine, Exhaust, Transmission | 7 | 08-28-2019 09:47 AM |
| SOLD: Brand New 2 Sets Of Gasket Ninja Tailight Gasket Kit With 3M Adhesive | el-guapin | Exterior Parts (Aero, Lighting, Etc.) | 5 | 12-27-2018 02:54 AM |
| Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 11:11 AM |
| BRZ Donut Gasket same part as WRX STi Gasket? | Zadkiel | Engine, Exhaust, Transmission | 0 | 10-06-2012 07:22 AM |
| Engine Gasket Set | Ishii Motors | Engine, Exhaust, Transmission | 4 | 06-22-2012 04:33 AM |
