Old 08-25-2012, 12:11 AM   #15
Thanntos
Thanntos's Avatar
Drives: Asphalt FR-S
Have a hose and all, but could I just get a spray attachment for the soap?
Thanntos is offline   Reply With Quote
Old 08-25-2012, 09:18 AM   #16
jogooba
Drives: Scion FR-S
If you have a hose, you can purchase a foam gun attachment for about $50 from autogeek.net (or other places I'm sure). It screws on to the hose just like any other hose attachment would and will do the trick for ya.
jogooba is offline   Reply With Quote
Old 08-25-2012, 09:58 PM   #17
911fanatic
Drives: 2003 W8 Passat Wagen 4Motion
Gilmour Foam Master is what you want.
911fanatic is offline   Reply With Quote
Old 08-26-2012, 11:30 PM   #18
makalaka
makalaka's Avatar
Drives: 2013 Sonic, 2013 BRZ ltd
Originally Posted by Draco-REX View Post
Now for the first wash if you're doing it yourself there are a couple changes. Wash the car as above, but use a strong dishwashing soap to get any wax and oils off the paint.
For the first wash, do you use dishwashing soap instead of the car wash soap or in addition to the carwash soap?
Thanks!
makalaka is offline   Reply With Quote
Old 08-26-2012, 11:40 PM   #19
911fanatic
For the first wash or any wash where you will be applying a wax or sealant for protection, wash with dishwashing soap. Use a strong mixture but make sure to rinse very well to ensure all soap residue is removed.
Old 08-26-2012, 11:44 PM   #20
Perfections
Drives: Murano
Thanks!
1 oz of dawn per gallon of water, no car wash soap, pre rinse car first to remove as much grit as possible, then wash away
Perfections is offline   Reply With Quote
Old 08-28-2012, 09:07 AM   #21
David-Fermani.com
David-Fermani.com's Avatar
Drives: Dirty
I've been using a powerwasher to pre-rinse my cars for decades. My wife's BLACK minivan is still in pristine condition and lasted 3 years before showing any wash induced marring. The key to washing it reducing your touching of the surface as much as possible. And when touching it, it should be as clean as possible. Powerwashing removes all the damaging abrasives so that hand washing is not evasive.
Secondly, a leaf blower will also reduce touching too. I'll dry the entire vehicle with it and then only need to use a spritz of QD as a floow up.
Originally Posted by Ashley View Post
I didnt think there was such a process to wash ur car...
There's not actually. People go waaaay overboard with their washing etiquette. Keep is simple, not overcomplicated.
Originally Posted by 911fanatic View Post
-the MOST important part of the wash is the pre rinse. I don't care if you use 10 buckets, a $50 mitt and the worlds most expensive soap, if you don't remove all the grit from the paint before washing, you will leave swirls in the paint.
I totally agree and this is extremely valueable info.
This is why a foam gun is a great thing to have. All those tiny bubbles help lift grit off the paint so your wash mitt can pick it up easier. It's also why the lambswool wash mitt is so important.
It also lifts copious amounts of $$$$ from your wallet too. Car Care resellers love foam guns!! Remember, car wash soap is a cleaner. The more you allow it to dwell on your sealed up finish,the quicker it will stripe your wax/sealant. IMHO it is totally not needed and is more of a hinderance.
Metro Detroit's Leader in Vehicle Preservation & Perfect Paint Finishes
Official Optimum Opti-Coat PRO Application Specialist for Metro Detroit
David-Fermani.com is offline   Reply With Quote
Old 08-28-2012, 10:33 AM   #22
911fanatic
I agree that in the long run, it may cause your LSP to fail sooner ( by a very small margin ), but I'd rather use every precaution available if trying to avoid swirls. There are a lot of things we use that by themselves won't make a huge difference, but as a system, does wonders to maintain the finish we want. And if foaming your car once a week with soap is killing off your LSP too quickly, find another LSP.
Old 08-28-2012, 09:23 PM   #23
David-Fermani.com
Drives: Dirty
Do you use a powerwasher? If so, are you using heated water? Does it utilize a system that sprays soap though the wand while in use? If not, then you're leaving mitigation on the table.
My point is, to what point are all these pre-cautions overkill?
You can pre-soak with foaming soap all day long, but it isn't going to release dirt like a powerwasher blast. The only thing that should remain after doing so will mostly be road oils which isn't *that* harmful when following up by hand.
Old 08-28-2012, 11:18 PM   #24
911fanatic
I totally agree that even a small pressure washer utilizing nothing but water will do a better job prerinsing than a low pressure ( Gilmour ) foaming. No argument there. Is there a benefit to spraying soap through the wand while in use even after a thorough pre rinse or would that be one of the overkill pre cautions we are discussing? I will be having a new pressure washer built soon. Should I have it set up for hot water?
Old 08-28-2012, 11:38 PM   #25
David-Fermani.com
Drives: Dirty
Go to a coin operated / self serve car wash with a dirty car and do this test:
Wash 1/2 the car using their high pressure soap concentration through their wand.
Wash the other 1/2 using just the final rinse.
See which one comes cleaner....
The combo of heat, pressure & chemical will do wonders as a pre-rinse.
Is heat needed = NO
Is chemicals going thought the wand needed = NO
Is a pressure washed needed = HECK YEA!!
Old 08-28-2012, 11:41 PM   #26
911fanatic
Will do. Thanks for the tip.
Old 09-03-2012, 04:36 AM   #27
knaa
Drives: FRS
I'm having trouble deciding on on whether to wash my car myself or get it detailed. I found a good cheap place in my town for a basic $40 interior/exterior detail (without shampooing the interior). I've read a couple of these threads and found that the moral is "you get what you pay for," but I don't have any of the recommended items which seem a bit pricey in addition to time consuming.
Should I just go ahead and invest in doing the wash myself or go ahead and get it detailed.
knaa is offline   Reply With Quote
Old 09-03-2012, 09:13 AM   #28
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Get it detailed at least once so you know you are working from a clean slate as far as the paint goes. Once the paint has been cleaned and corrected you can work on taking care of it yourself.
2-Bucket Wash Technique imravenit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 46 01-09-2014 12:39 AM
Wash and wax, and a few bonus pics. brzzz BRZ Photos, Videos, Wallpapers, Gallery Forum 4 08-06-2012 02:16 PM
Help in wash and detailing WHITEOUT FRS.. tintumz22 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 07-16-2012 09:37 AM
How often do you wash your FR-S? terrypm Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 50 07-14-2012 03:24 AM
How Do You Wash Your Car? Xiao Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 86 06-09-2012 07:11 PM
