| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
#15 |
Drives: 2022 GR86
#16 |
Drives: '22 WRB
I feel the opposite, like the throttle is bottom heavy. I remember Mike saying the same thing.
| The Following 2 Users Say Thank You to trippinbillies40 For This Useful Post: | CaptainFenderbaum (12-11-2022), tenderization (11-29-2021) |
#17 |
Drives: Scion FR-S
#18 |
Drives: '22 WRB
Meaning a little bit of throttle movement in the pedal gives a lot of throttle response. Kind of like Sport # SI Drive mode in an STI. As opposed to a linear response where 25% pedal means 25% throttle, it's more like 25% pedal is 50% throttle and the last 25% of pedal is all technically full throttle. That's not exact, but you get the idea.
| The Following User Says Thank You to trippinbillies40 For This Useful Post: | Dylans47 (11-29-2021) |
#19 | |
ProCrastinationConsultant
#20 |
Drives: '22 WRB
It's actually *really* good in low RPM compared to the old car.
#21 |
Drives: 2022 Subaru BRZ 6MT IR
Does anyone think they can feel a difference in throttle response when in Track vs. Normal mode? I've been swapping back and forth, and I don't think there is one. At least not near the bottom of the rev range. I'm only halfway through the break in, and keeping it below 4000(ish)rpm, so perhaps higher up its different.
Thoughts?
2022 BRZed, Red, Base, Manual, Simple
#22 |
Drives: Subaru BRZ ZD8
I can chime in on this. Went to hoon around in the wet there other night. It is really mixed signals at low RPM.
The tip in response from stabs of the throttle at low RPM (<2500) is terrible. I was trying to use the torque to keep wheel speed up but the lack motor response to generate torque ("pick up") was so bad it would kill wheel speed. It was fairly disappointing. Otherwise the motor is great and quite powerful and happy to rev, once it's in the happy place, it has no issues smashing the limiter. And the motor is very responsive to changes in throttle input. |
| The Following User Says Thank You to jrblaze For This Useful Post: | PBR (12-10-2022) |
| Very sluggish throttle response at 3k rpm | Hayer_86 | Issues | Warranty | Recalls / TSB | 10 | 01-15-2021 02:21 PM |
| OFT v4.03 throttle response | Tristor | Software Tuning | 29 | 09-22-2019 05:51 PM |
| OFT throttle response | MyGT86Yas | Software Tuning | 6 | 02-26-2018 06:44 AM |
| Throttle Response | CamryDS | Northern California | 27 | 03-31-2015 04:35 AM |
| How's the throttle response? | SFTiofoso | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 08-14-2012 12:50 PM |
