Old 08-21-2012, 08:33 PM   #15
goincarcrazy
Future FR-S Owner
goincarcrazy's Avatar
Drives: '05 Scion tC
MT or AT?
goincarcrazy is offline   Reply With Quote
Old 08-21-2012, 08:54 PM   #16
01s0uljah
Drives: SWP Subaru BRZ Sport-Tech 6AT
Originally Posted by goincarcrazy View Post
MT or AT?
its an AT
01s0uljah is offline   Reply With Quote
Old 08-21-2012, 09:14 PM   #17
pinoyplaya
Drives: WRB MT-BRZ LMTD
Rebuilt engine? WTF? The least they could do is give you a brand new car. You didnt pay full price for a car with a rebuilt engine!
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM
Traded for Black 2013 Camaro 2SS RS
pinoyplaya is offline   Reply With Quote
Old 08-22-2012, 12:16 AM   #18
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I think that dealership may have used their words poorly. I think "rebuilt engines" is referring to "replaced timing actuators". Having a part replaced is not he same as having a rebuilt engine.
Old 08-22-2012, 09:50 PM   #19
sofrsnsokleen
GEARS!!???
sofrsnsokleen's Avatar
Drives: raven black 2013 scion fr-s
Location: the southeast side of san antonio, where the players play!
man, this is reading like a scary campfire story to me.... so this legend of no tranny fluid, if I check the tranny stick and it shows clean fluid, it should be fine, correct? (yes i'm aware tranny fluid and tranny stick sound hilarious)
sofrsnsokleen is offline   Reply With Quote
Old 08-22-2012, 09:58 PM   #20
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
there is no stick, YOUR ON YOUR OWN MAUAHAHAHAHHAHAHA
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 08-22-2012, 10:07 PM   #21
sofrsnsokleen
GEARS!!???
what are you serious??? only glanced over the manual. got free oil changes so i was like, meh, only fools need a "manual" hahaha, jk
Old 08-22-2012, 10:19 PM   #22
carbonBLUE
Reverse Burnouts
yeah you have to uncork the drain screw and feel around, if the oil is up to the fill screw you are fine, if not then take it to the dealership
while your at it, you might aswell drain the stock transmission fluid and put redline in there, a few member have done it and a lot of the complaints have gone away
(wont forget you)
2011 Infiniti G37x
Old 09-05-2012, 04:49 PM   #23
illmatic2349
illmatic2349's Avatar
Drives: FR-S, I F**king love it
wtf i was bragging of how fine of a piece of machinery this car is.
always trying to make my car faster!!
illmatic2349 is offline   Reply With Quote
Old 11-25-2012, 05:01 PM   #24
knewsom32
knewsom32's Avatar
Drives: Scion FR-S
Send a message via AIM to knewsom32 Send a message via Yahoo to knewsom32
Driving around downtown Houston and car threw up the cel and trac light... Any word on what the issue could be? It's a manual btw.
knewsom32 is offline   Reply With Quote
Old 11-25-2012, 05:09 PM   #25
Fizzle
FizzRS
Fizzle's Avatar
Drives: Scion FR-S Asphalt
Same thing happened to my car 4 months back when i just have them for a couple of days. Took it to dealership and got em back within 2 weeks. Since then everything seems just fine Name:  ImageUploadedByTapatalk1353881329.089524.jpg
Fizzle is offline   Reply With Quote
Old 11-25-2012, 05:18 PM   #26
knewsom32
knewsom32's Avatar
Drives: Scion FR-S
Went to AutoZone & pulled the code. Code is P0011 and it means there is a timing over advance or system performance bank. The probable cause is either a blocked oil passage, mechanical timing fault, failed OCV, or VVT controller assembly fault.
Sent from my Verizon Galaxy S3 using Tapatalk
Old 10-04-2014, 11:27 PM   #27
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by QFry View Post
Sigh...so had the car for two days and 230 miles and the car throws up a CEL and Traction Light. There may have been some but nothing serious. Plan on going to get it checked tomorrow because thats the correct thing to do; however, to satiate my curiosity i connected my OBD2 scanner but it would not connect. Any ideas why or would a two year old scanner just not be supported?
Edit: I already know about the other threads addressing this problem...i was just curious about the Scanner not working with ECU and why it might not.
Did you ever find the issue sir?
Astroboy is offline   Reply With Quote
Issues - Traction control and ABS warning light on G86 Issues | Warranty | Recalls / TSB 109 10-17-2021 04:32 PM
Check engine light just came on after 2k miles. danthedirt Issues | Warranty | Recalls / TSB 604 01-31-2015 04:26 PM
Check Engine Light b.e Scion FR-S / Toyota 86 GT86 General Forum 9 06-17-2012 09:50 PM
Check Engine Light directly after pickup Stu L Tissimus BRZ First-Gen (2012+) — General Topics 27 06-15-2012 05:07 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
