Old 10-22-2021, 12:50 PM   #15
mayoboost
Drives: boosted white FRS
OR ............
Hahahaha i'm trying not to butcher the hood. A replacement hood and paint is about $1k+ from what I found.
With the hacksaw I can clip off the hood hook and weld it back on I'm thinking, though not sure that is the best idea, either, frankly.
mayoboost is offline   Reply With Quote
The Following User Says Thank You to mayoboost For This Useful Post:
humfrz (10-22-2021)
Old 10-22-2021, 01:28 PM   #16
humfrz
Is there anyway you can go up through the grill -
Old 10-22-2021, 01:30 PM   #17
pope
has a funny hat
Drives: 2014 BRZ Limited
Can you get access to the bolts that hold the latch to the radiator support?
If you can unbolt it you can open the hood to work on unhooking it from the hood. The loop on the hood unbolts, but is not removable; it’s sandwiched between the layers of the hood.
pope is offline   Reply With Quote
Old 10-22-2021, 03:43 PM   #18
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Wow, I've been watching this thread for the past few days. It's ashame that someone would have to hack up their hood and do all that damage to the radiator support just to try to get it open in the event of a cable break. What do you think could have caused this problem in the first place? Corrosion?
Here's my advice: get a can of WD-40 or your favorite penetrant and using the straw, spray all inside the area underneath into and all around the locking mechanism, then wait a few hours for it to soak in, then go inside and try to pull on the cable using some vise-grip pliers with a helper gently but firmly pushing down and/or pulling up on the hood.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
humfrz (10-23-2021)
Old 10-22-2021, 05:18 PM   #19
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I just looked at the latch system on my FRS. As @pope suggested. if you can get to them, removing the 3 bolts from the radiator bracket is your best bet. I don't see any way to work a wire hook into the latch.
Old 11-04-2021, 09:36 PM   #20
mayoboost
Update: I fkn did it!
I managed to remove the intake from underneath and get better access to the latch. Made a makeshift hook with a wire hanger and slid it into the latch lever to pull it open.
Want to thank everyone for their help!!
The Following 8 Users Say Thank You to mayoboost For This Useful Post:
bcj (11-05-2021), blsfrs (11-05-2021), Boomerang (11-05-2021), humfrz (11-04-2021), pope (11-05-2021), soundman98 (11-04-2021), Ultramaroon (11-05-2021), x808drifter (11-05-2021)
SOLD: Seibon VS-Style Carbon Fiber Hood w/ Quik Latch Hood Pins sixthspeed Exterior Parts (Aero, Lighting, Etc.) 16 02-07-2021 08:49 PM
Trunk latch broken B 86 Issues | Warranty | Recalls / TSB 12 01-18-2021 02:28 PM
WTB Hood pin/latch msaikhan Want-To-Buy Requests 0 07-19-2020 11:50 AM
Hood Latch Dilemma Mr Nerd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 02-04-2017 05:06 PM
WTB: HOOD LATCH AND DRIVER SEAT BELT ASSEMBLY 555 Want-To-Buy Requests 5 08-24-2015 04:57 PM
