Old 09-16-2021, 11:05 AM   #15
gcranston
Drives: 2015 Subaru BRZ Limited DGM
Originally Posted by Opie View Post
I'll be doing a full boot replacement and repack video next week.
Oh no, this was a fairly sketchy "just get the car back out there" kind of repair. It did what it needed to--I finished the time trial and made it ~400 miles home--but it's not what I'd call a long-term solution. As I've got spare axels, rather than replace the boot I'll just replace the axel.
gcranston is offline   Reply With Quote
Old 09-16-2021, 01:53 PM   #16
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
Can replace boots and repack the grease multiple times as long as the CVJ & DOJ are fine...and a lot cheaper than buying axles.
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 09-16-2021, 02:27 PM   #17
gcranston
Fair enough. But the spares I have are from my rebuild (I have the whole rear subframe of the "bent" car, minus the diff), so these are essentially 'free'. The new boot would be ~$30, plus grease, plus the time to repack once I've already got the axle off. I'm still interested to watch your video on how to do it incase I ever have to, but I imagine the first and last several steps are basically "take the axle out" and "put the axle back in" I figure _this time_ I'll leave out the middle bit.
Thanks,
Old 09-17-2021, 12:52 PM   #18
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Thanks,
Don't recall where I saw it (may have even been Opie) but somebody was having trouble with their axles and found the oem grease had basically turned to water in the spares he had. It may be worth it to re pack your replacement ones anyway as a precaution.
CrowsFeast is offline   Reply With Quote
Old 09-17-2021, 01:48 PM   #19
gcranston
Alright I'll check it out. @Opie, where's the video?!
Old 09-18-2021, 02:06 PM   #20
gcranston
Estimate to replace a section of exhaust pipe is $250. Ordered those beefier JDM hangers (plus spares) that @StraightOuttaCanadaEh mentioned. Fingers crossed the grease in my old axles is still greasy, and if so I should come out of this without too much hassle. Thanks all for the input.
EDIT: flattened pipe, torn boot, and sketchy repair that got me home.
Old 09-18-2021, 05:36 PM   #21
Ultramaroon
not playing cards
Ultramaroon's Avatar
10/10 git er home
Old 10-12-2021, 09:45 PM   #22
gcranston
Got 'er done. Made the last event of the year at nhms. Slew dragons. Great way to end the year.
Thanks all. Now for offseason planning...
Old 10-12-2021, 11:54 PM   #23
dreamwonder
Drives: GR86 2022
I will add a datapoint. Been running oem hangers only. 2 of the original ones torn after like 50 days, so replaced all with new ones, it's been 50 plus days, they look fine still. As for the Glen, something always breaks whenever I go there... regardless of car...lol.
dreamwonder is offline   Reply With Quote
Old 10-22-2021, 02:37 PM   #24
Four_wheel_drifts
Drives: Whiteout track car; lava donor
Haven't heard much about the Perrin hangers but they're also available[/QUOTE]
Sorry to see this so late!
Avoid the Perrin ones at all costs. They are crap and they cut loose on me between turns 15 an 16 at OR Raceway Park CCW.
For those that don't know, ORP is in the middle of nowhere. Hose clamps got me through the next two track days of that three day event.
OEM style rubber ones have worked well for me ever since.
Four_wheel_drifts is offline   Reply With Quote
Old 10-22-2021, 05:40 PM   #25
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Sometimes it seems that half of the aftermarket parts are worse than the originals.
Old 10-23-2021, 01:11 AM   #26
Ultramaroon
not playing cards
That's because they are. Caveat emptor, my friends.
Old 10-23-2021, 08:04 AM   #27
ZDan
ZDan's Avatar
Drives: '23 BRZ
Almost always. OEM parts have tons more experience, development, and testing behind them, and then millions of "beta test" miles by customers in the real world. I never replace OEM parts with custom aftermarket unless I really need to.
Old 10-23-2021, 08:17 AM   #28
soundman98
ProCrastinationConsultant
soundman98's Avatar
well yeah, precision of material 'dosing' and molding doesn't come cheap. the oem stuff isn't just expensive so they can rake in money.
there are no markets in the world where one can purchase the same product at a reduced rate from a different supplier without some corner being cut. if someone can make the same thing for cheaper without cutting corners, they're already the supplier...
Exhaust. My biggest failure. grumpysnapper Engine, Exhaust, Transmission 14 03-23-2021 07:40 AM
FS: Torque Solutions Exhaust Hanger Kit skylinekin Engine, Exhaust, Bolt-Ons 1 09-08-2018 12:34 PM
Exhaust hanger Eighty Scion FR-S / Toyota 86 GT86 General Forum 17 11-06-2015 04:19 PM
HELP: Stock Exhaust Hanger measurement LeeMaster Cosmetic Modification (Interior/Exterior/Lighting) 4 01-12-2014 02:25 PM
Know size and thread of the bolt to the exhaust hanger? JiB Engine, Exhaust, Transmission 4 06-20-2013 09:37 AM
