Tracking / Autocross / HPDE / Drifting What these cars were built for! |
07-28-2021, 11:58 AM | #15 | |
Drives: Crapcan
I am having issues with my logging setup right now. It isn't showing my oil pressure/temp in my device management and tach signal is registering about a 1/3 the rpm it should. Haven't had time to figure that out yet
The Following User Says Thank You to NoHaveMSG For This Useful Post: | ZDan (07-28-2021) |
07-28-2021, 01:02 PM | #16 | |
chicken tonight
Consider the aftermarket oil/water systems - no, not the dinky forester thing. No problem shedding all that combined heat as long as there's adequate air flow through the rad.
The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
07-28-2021, 01:51 PM | #17 | |
NoHaveMSG’s comment about significantly improving the efficiency of the 613 by mounting it on the crash bar seems worth pursuing as well. I may try to raise mine up on spacers or hang it off the crash bar, but good to know it shouldn’t raise water temps much either way. I’d love to drop my peak oil temps into the 220’s and use a 0w20 or thin 30 weight oil.
2022 BRZ Build 2013 FR-S Build |
The Following User Says Thank You to DarkSunrise For This Useful Post: | Ultramaroon (07-28-2021) |
07-28-2021, 02:40 PM | #18 | |
chicken tonight
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | DarkSunrise (07-28-2021), NoHaveMSG (07-28-2021) |
07-28-2021, 06:05 PM | #19 | |
Are ***all*** factory shrouding pieces present? Age of the car? |
07-28-2021, 06:30 PM | #20 | |
Drives: Crapcan
2013 The shrouding around the radiator is in place. The top piece above the crash bar, and both of the fin pieces in front of the radiator on each side. I believe that is all of them. Sent from my iPhone using Tapatalk
07-28-2021, 06:40 PM | #21 |
Water pump and fans fully functional? You should be nearly sitting on thermostat permanently with an NA car at your ambients and elevation!
07-28-2021, 06:47 PM | #22 | |
Drives: Crapcan
Fans work. I actually have a switch to cycle them on and off fully if I want, but they so come on normally. The water pumps seems to be working normally. I could try a new one as I don’t have a good way to test it. Sent from my iPhone using Tapatalk
07-28-2021, 09:12 PM | #23 |
Drives: 2013 frs base
Bad thermostat?
The Following 2 Users Say Thank You to blsfrs For This Useful Post: | NoHaveMSG (07-29-2021), Ultramaroon (07-29-2021) |
07-29-2021, 02:03 AM | #24 |
chicken tonight
OMG, I'm going to shit myself if it's the thermostat.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Wally86 (07-29-2021) |
07-29-2021, 07:28 AM | #25 | |
Drives: '23 BRZ
The Following User Says Thank You to ZDan For This Useful Post: | timurrrr (07-29-2021) |
07-29-2021, 10:40 AM | #26 | |
Drives: Crapcan
That was the plan originally. Just having issues getting it to log.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (07-29-2021) |
07-29-2021, 12:37 PM | #27 |
Drives: Crapcan
LOL right? Ordering a WP and thermostat now.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | blsfrs (07-30-2021), Ultramaroon (07-29-2021) |
07-29-2021, 03:35 PM | #28 |
chicken tonight
I like to boil mine on the stove to test both old and new. Can't believe that flew right past us. Duh!
The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (07-29-2021) |
Similar Threads | ||||
Engine Management | Q2 | Forced Induction | 9 | 12-04-2017 05:37 PM |
heat management, CF hood alternative | Reaper | Forced Induction | 70 | 07-05-2017 01:22 AM |
Rotrex vs Turbo (AVO) for Track use (transient response, IATs, heat management, etc) | glamcem | Forced Induction | 56 | 08-25-2014 06:07 PM |
Top half car covers for cabin heat management on track | dp1 | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-26-2014 11:08 AM |
Avo turbo heat management on track | ICantAffordAnLFA | Forced Induction | 18 | 09-09-2013 11:00 AM |
