GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
08-05-2021, 05:39 PM | #15 | |
Site Moderator
Drives: ichi 86 Project
Joke a side, recommend PM the admin or Post it in Site Announcements / Questions / Issues to get both admins attention. |
The Following User Says Thank You to ichitaka05 For This Useful Post: | BrahmaBull1990 (08-18-2021) |
08-06-2021, 01:06 AM | #16 | |
Drives: 2022 GR86
08-06-2021, 01:54 AM | #17 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
Do you have any messages you'd like passed on to your loved ones, just in case? |
08-06-2021, 02:24 PM | #18 | |
Site Moderator
So keep those 2 rules, you'll be fine. |
08-10-2021, 11:24 PM | #19 |
Jedi
Drives: Pikachu BRZ
Might finally ring to 9k unless oiling becomes an issue
08-11-2021, 02:03 AM | #20 |
Drives: 2015 FRS
08-12-2021, 01:36 PM | #21 |
Seems like whenever a manufacturer makes aftermarket connecting rods for the FA20, the make them pretty robust. I wonder if Subaru took some cues from this and reinforced their rods?
The Following User Says Thank You to MJones_RB For This Useful Post: | JesseG (10-15-2021) |
08-12-2021, 02:10 PM | #22 | |
Drives: 2018 Subaru BRZ Limited with PP
EDIT: It's getting a little trickier to find. But here is one thread where it is discussed. Post #25 to be particular. https://www.ft86club.com/forums/show...=146151&page=2 Last edited by Dzmitry; 08-12-2021 at 02:21 PM. |
The Following 4 Users Say Thank You to Dzmitry For This Useful Post: |
08-12-2021, 06:56 PM | #23 |
Every Ounce Counts
Drives: 86
The Following 7 Users Say Thank You to Lightened For This Useful Post: | Alltezza (08-18-2021), BrahmaBull1990 (08-18-2021), Dzmitry (08-13-2021), JesseG (10-15-2021), MJones_RB (08-13-2021), Spankopotomous (08-13-2021), timurrrr (08-12-2021) |
08-13-2021, 01:43 AM | #24 |
Is there any info on intake manifold. I hope its the same width and size, so our FA20 superchargers can be retro fitted
Sent from my SM-G781B using Tapatalk |
08-13-2021, 09:17 AM | #25 |
08-13-2021, 09:27 AM | #26 | |
If the bore has got larger and stroke remains 86 mm. I don't see it as a physically larger block needing a larger intake? The cylinder vacuum will pull in more air. Sent from my SM-G781B using Tapatalk |
08-13-2021, 11:54 AM | #27 | |
https://motor-fan.jp/mf/article/1636/ "the intake port is made thicker and shorter. And it can be taken to the specification in the direction of sucking more air, so it is possible to increase the output in the high rpm range." |
08-17-2021, 10:47 AM | #28 |
Howdy
Drives: 2020 BRZ PP
Well there goes all my money....figuring out how to swap the new drive train into a gen 1 while keeping or replacing my Edelbrock SC smh
Calling all mad scientists
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
Similar Threads | ||||
FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 10:18 AM |
Oil Cooling - An In-Depth Look | VerusEric | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 115 | 02-20-2023 10:54 PM |
Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 10:55 AM |
FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 03:59 PM |
Depth of speed | DIG1992 | Other Vehicles & General Automotive Discussions | 6 | 05-22-2012 01:13 PM |
