#15 |
Drives: 17 Asphalt 86
Look into pedders top mounts. They can get you over -3° with your current setup.
They're hard to get a hold of lately due to backorder but will add roughly .75° additional over just running bolts. |
#16 | |
Drives: '23 BRZ
| The Following User Says Thank You to ZDan For This Useful Post: | Petah78 (07-13-2021) |
#17 |
Drives: 2016 Scion FRS
Since we got that out of the way, driver inputs are probably a huge factor. I know the OP mentioned adding steering angle and snapping off throttle to rotate the car. You are probably going to burn down your tires regardless of camber if you do that much at all.
#18 | |
Drives: 2022 BRZ sport-tech
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
#19 |
Drives: 2022 GR86
Interesting data about adding front ARB adding front grip by optimizing dynamic camber.
To folks who experienced that first hand, what camber did you have where this helped? Does it help primarily if you have insufficient camber to begin with (e.g. -1.7º), or does it help even if you have 3–4º of camber in the front? What is the typical º of roll a car with say 6 kg/mm springs has with stock ARBs and 200–260 TW tires? |
#20 | |
TRACKBREAD
It would depend on tire grip level as well I think. |
#21 |
Drives: 15 Impreza
There is some really good information on swaybars in this thread. https://forums.nasioc.com/forums/sho...d.php?t=879235
Attached is a suspension calculation spreadsheet that was posted on NASIOC back in the day. I don't see why it can't be adapted to the BRZ/FRS by changing some of the parameters. |
#22 | |
Drives: 2022 GR86
#23 | |
| The Following User Says Thank You to steverife For This Useful Post: | timurrrr (07-14-2021) |
#24 | |
Drives: 2016 Scion FRS Release Series 2#439
My alignment guru found he could get maximum -3.5 front camber although we settled at -2.75 for my combination of 99% DD (commuting) and 1% lapping. I’ve yet to track this set-up due to COVID closures and moving across the province recently but hope to bolt on the new A052’s and get at it soon. Perhaps Friday. |
| The Following User Says Thank You to Muskoka800 For This Useful Post: | RToyo86 (07-14-2021) |
#25 |
Yup, at -4 with a 6k front spring super 200tw tires and I wouldn't go back to a stock front bar, just keeps the front end planted through sweepers and makes the car mega responsive through slaloms.
Again I think they under spec the front bar because 95% of these will never ever be driven at the limit. Just because the factory sticks it on doesn't mean it's good for track/autox, car probably would've been a little better with a 21-22mm tubular or 19-20mm solid |
#26 | |
Drives: 2022 GR86
Eyeballing at photos of my car at the track, the dynamic camber at steady state cornering looks pretty decent even with stock ARBs. |
#27 | |
I don't track my car, but a lot of those folks do track their cars and even do time trials with minimal to no changes to set up. |
#28 | |
closes laptop, goes for a walk. - andrew |
| The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post: |
| How does my tire wear look? | R_E_L | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 09-08-2018 07:34 AM |
| tire wear | oppiee | Tracking / Autocross / HPDE / Drifting | 9 | 08-29-2017 12:55 PM |
| Tire Wear? | Flo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 01-10-2017 03:19 PM |
| Tire Wear Help | babykwiss | Tracking / Autocross / HPDE / Drifting | 10 | 07-14-2014 11:31 AM |
