#15 |
diagnostic trouble code. You can use ecutek software to clear or an scanner tool. Might be preventing you from going into the pedal dance mode
2013 Series 10 FRS #553
#16 |
Drives: 2015 Subaru BRZ Limited DGM
Well, I don't have any lights on the dash. But I'll plug my OBD reader in and see if there's anything stored. Failing that, I'll try to find a sympathetic Subaru/Toyota dealership to plug their fancy-schmancy computer into it.
#17 |
Yea I am not sure. I am curious on the outcome of this.
#18 |
Only users lose drugs.
Drives: All the time
Is the engine fully up to temp? That's the only thing that's kept the pd from working for me in the past..
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#19 |
Presuming there is no aftermarket tunes?
#20 |
Took the car to Toyota today to get the DTCs. Looks like I have some wheel speed sensor issues:
C1232: Left Front Wheel Speed Circuit Open or Shorted C1233: Left Front Wheel Speed Sensor Input Signal Missing C1237: Speed Wheel Rear Input Signal Missing C1464: Front Speed Sensor Right C1465: Front Speed Sensor Left C1541: Vehicle Speed Signal Malfunction Plus a bunch of airbag codes, which make sense as I've removed the side curtain airbags. So, at least I've got something to go on. I haven't started reading up on these codes, but if anyone has any suggestions I'm all ears. Thanks. |
#21 |
C1237: Speed Wheel Rear Input Signal Missing C1332: Open Circuit In Right Rear Speed Sensor Circuit C1333: Open Circuit In Left Rear Speed Sensor Circuit C1464: Front Speed Sensor Right C1465: Front Speed Sensor Left C1541: Vehicle Speed Signal Malfunction Plus a bunch of airbag codes, which make sense as I've removed the side curtain airbags. So, at least I've got something to go on. I haven't started reading up on these codes, but if anyone has any suggestions I'm all ears. Thanks. Last edited by gcranston; 04-05-2022 at 04:45 PM. Reason: fixing ODB2 codes |
#22 |
OK people, update time. I need some help with the ABS pump part numbers.
As I said in my last post, consensus is this is the ABS pump / brake actuator assembly. I actually posted the wrong code numbers before and have edited the post above. The plan is to replace the pump with one from the wrecker. When I search for it, car-part lists 5 options for this part (first photo), and two for the MT version (I have an MT). When I called the junkyard they just asked the number on the existing pump, and I gave them the number you can see in the second photo, without checking. ![]() Now, when I tried to install this pump I stupidly cross-threaded one of the hardlines (eff) so I need to get another one and do it again. Checking the numbers this time I noticed that 1) the number on the pump corresponds to one the AT part numbers on car-part, and 2) THERE'S A GIANT "A" STAMPED ON IT ![]() So I think this is a happy accident and I have the wrong part. Can anyone with a manual trans 2013 FRS with a stock ABS pump please double check for me? My hunch here is that the guy I bought the car from replaced the ABS pump at some point and didn't check. It mostly works, I just can't do the pedal dance and my trackbox doesn't enable 'track mode' either. Thanks! |
#23 | |
Drives: Nevermorange FRS
SCCA T4 - FRS
#24 |
Hmmm, the plot thickens...
#25 |
Drives: None
PM'd you
Also, ignore the A stamped on it. I have four of them here, they all have an A on them.
#26 |
#27 |
Drives: None
2020 MT Hakone Edition - 27536CA070
2017 MT Brembo - 27536CA040 2016 MT Hyperblue - 27536CA020 2015 MT - 27536CA020 Units with 27536CA030 and higher are 2017+ units with track mode and require a small repin on 2013-2014 cars. 2015 and 2016 units would also require a repin on 2013-2014 cars.
| The Following User Says Thank You to RedReplicant For This Useful Post: | gcranston (04-08-2022) |
| WTB: pedal dance box | captain awesome | Want-To-Buy Requests | 6 | 08-19-2019 01:37 AM |
| Pedal dance problem | Sapphireho | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 07-31-2017 10:25 PM |
| Pedal dance | Simqc | Issues | Warranty | Recalls / TSB | 6 | 05-22-2016 10:56 PM |
| Pedal dance not working. *issue resolved* | BDKane01 | Issues | Warranty | Recalls / TSB | 31 | 05-20-2016 10:17 PM |
| Pedal Dance Device | robot | Tracking / Autocross / HPDE / Drifting | 3 | 01-10-2014 10:26 AM |
