Old 07-08-2021, 09:56 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
lol...
you totally win
My response was slow. 3/10, would not bang.
Is it really winning in banter
Old 07-08-2021, 10:08 PM   #16
Ultramaroon
not playing cards
Ultramaroon's Avatar
it's win/win winning
Old 07-09-2021, 08:28 AM   #17
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
A drill wire brush goes a long way cleaning that up.
I periodically hit flanges and pipes to clean up the metal a bit.
Old 07-09-2021, 09:52 PM   #18
soundman98
ProCrastinationConsultant
soundman98's Avatar
that method also continually exposes a fresh layer of metal to the same demise...
Old 07-10-2021, 03:25 AM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You can wet it with nitric acid, then neutralize and clean. It will delay the corrosion by dissolving the free irons in the surface of the material. That’s a lot of work for a part that is still going to last another 20 years with no additional work.
Old 07-10-2021, 03:22 PM   #20
ghostzfh
Drives: 2016 Scion FRS Halo
That's true. I could wipe it down with some citric acid and sand it all down, and then hit it with some anti rust spray or something, but it's probably not worth worrying too much about.
ghostzfh is offline   Reply With Quote
Old 07-10-2021, 03:28 PM   #21
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
So at home passivating? I don’t think that works on aluminized steels
Old 07-10-2021, 05:17 PM   #22
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, for the mid pipe. Nothing you can do for the muffler but paint it.
Old 07-10-2021, 05:23 PM   #23
Yoshoobaroo
TRACKBREAD
Do we know what’s made of what? I didn’t think OEMs used stainless in exhausts at all.
Old 07-10-2021, 06:17 PM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It’s stainless until the rear muffler. Dunno what
grade.
Old 07-11-2021, 07:50 PM   #25
RickBH
Drives: 2020 Brz Sport-Tech Auto
Muffler Stainless Steel
"It’s stainless until the rear muffler. Dunno what
grade."
Mufflers and pipes are often made of 409 stainless steel by manufacturers. it has a lot less nickel so it is much cheaper. It does surface rust and will flake off but does not often get holes like carbon steel pipes.
The first uses of 409 in exhaust systems was probably on industrial exhaust systems like for industrial gas turbines. Silencers for gas turbines is where I first saw it.
RickBH is offline   Reply With Quote
exhaust, rust
Using a muffler as a helmholtz resonator Ashikabi Engine, Exhaust, Transmission 10 07-16-2020 02:24 PM
Resonator or muffler delete? Gatoortiz86 Engine, Exhaust, Transmission 10 01-02-2019 03:55 AM
Berk Muffler Delete with Resonator BigTuna Engine, Exhaust, Bolt-Ons 9 12-05-2017 03:19 PM
Resonator delete? Sound with stock muffler? Nate219BRZ Engine, Exhaust, Transmission 23 09-05-2012 06:42 PM
