Old 05-08-2021, 03:17 PM   #15
marco_mc22
Drives: Toyota 86
Originally Posted by Pat View Post
Thanks, Marco. Great info! The top of the plate clearly goes all the way in. If this is indeed the problem would that still be possible?
Well I don’t know...
Personally I’d try using lower hole camber bolts + upper factory crash bolts, from my experience lower camber bolts (spc or powerflex) give you a bit more camber.
If you don’t want two thinner bolts holding your strut to the knuckle I think you should make a custom upper spring perch but you will loose some bump travel to have enough clearance and it’s not the best idea with those monotube dampers.
marco_mc22 is offline   Reply With Quote
Old 05-12-2021, 10:52 AM   #16
wparsons
wparsons's Avatar
Don't run double lobed bolts, just get the SPC lobed bolts for the lower hole and put the stock lower bolt in the upper hole. I have that combination with KW V3's (slotted upper hole) and was able to get to -3.8* with stock upper mounts (not offset like pedders or whiteline).
Are you positive the lobed bolt is adjusted correctly?
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Pat (05-12-2021)
Old 05-12-2021, 10:56 AM   #17
Pat
Pat's Avatar
Drives: 2023 BRZ
If I remember correctly I have SPC bolts up top and stock ones below. Will swapping them get me more camber?
I've had two different shops align it and they came up with the same result. The last guy that worked on it specifically said regardless of which direction he turned the bolt it gave him less camber. This was while I was sitting in the driver's seat up on the rack. He even went to his so-called "plan B" and removed the wheel in an effort to do something different.
Old 05-12-2021, 04:55 PM   #18
strat61caster
strat61caster's Avatar
Upper bolt per the correct part is too big to fit in the bottom hole. Unless you got lucky and accidentally bought the smaller bolt for the lower hole and put it in the top hole.
I don't think you'll hit -4 with that arrangement since bilstein doesn't have the enlarged upper hole like Koni, KW or all the other toner struts.
ineedyourdiddly
Pat (05-12-2021)
Old 05-12-2021, 07:19 PM   #19
cueball89
Drives: 15 Impreza
Are the SPC camber bolts installed with the washer tab in the maximum camber position?
cueball89 is offline   Reply With Quote
The Following User Says Thank You to cueball89 For This Useful Post:
Pat (05-12-2021)
Old 05-12-2021, 11:15 PM   #20
Pat
Pat's Avatar
Drives: 2023 BRZ
I don't know. I'll ask.
Old 05-13-2021, 01:15 PM   #21
Pat
Pat's Avatar
Drives: 2023 BRZ
I just spoke with the guy that did my last alignment. He said he tried it with the washer tab both ways and got the same result.
Old 05-13-2021, 06:57 PM   #22
dasting
Drives: 2013 BRZ Limited
How much did you drop the car from stock? This will change what you're able to achieve in camber.
I would put the stock bottom bolt into the top hole and use a crash bolt on the bottom hole. Which eccentric bolts are you using? I have a 14mm SPC cammed bolt in the bottom hole, and moved the bottom hole to the top, and was able to achieve -3.2 with just .8" drop and pedders top hats (which got me the advertised additional -.75).
When you have the wheel off and the bolts out, it becomes very obvious what bolt usage gets you the most camber. You can rotate the eccentric bolt and see which one allows the top of the knuckle to move farthest inward on the car.
2013 BRZ Limited, NASA Instructor, ex-spec miata racer
dasting is offline   Reply With Quote
Old 05-14-2021, 03:38 PM   #23
Pat
Pat's Avatar
Drives: 2023 BRZ
More than one inch. SPC.
Old 05-18-2021, 06:23 AM   #24
Bach415
Bach415's Avatar
Drives: Whiteout FRS
That doesn't sound right. With the washer tab in the specific direction (IIRC, the larger tab on the upper slot should be on the inside whereas the bottom camber bolt if you do get one, should have the larger tab on the outside), you should get maximum negative camber. You can literally see the knuckle moving inwards/outwards as you turn the bolt. Did the tech at least loosen the bottom bolt when he/she did the alignment? If the bottom bolt is still torque down, turning the top camber bolt will not have much of an effect and can possibly ruin the bolt/slot.
Bach415 is offline   Reply With Quote
The Following User Says Thank You to Bach415 For This Useful Post:
Pat (05-18-2021)
Old 05-18-2021, 11:11 AM   #25
Pat
Pat's Avatar
Drives: 2023 BRZ
Good to know. I'm going back there in two days with new OEM control arms. Hopefully that will eliminate the possibility of bent control arms and incorrectly installed poly bushings.
I do remember him saying he could, "...see the knuckle moving inwards/outwards as you turn the bolt," though.
I don't know if he loosened the bottom bolt, but expect he did. Everything I've questioned him on so far has been correct. But I'll verify next time.
Old 05-18-2021, 06:27 PM   #26
Bach415
Bach415's Avatar
Hopefully it goes well. When I installed mine, I did notice the difference with the tabs put in different locations (for both bolts). My friend who was doing my alignment wasn't sure why I wasn't getting the enough camber (he had the larger tabs moving) until I told him that the tabs have to stay in a specific spot for maximum negative camber (which at the end netted me to -2.6 on fresh tires, currently at -2.4 after the wear). It was also close to -3 IIRC before the RCK install. Also, if you want more camber, you can also get the powerflex front lower control arm camber bushings for more adjustments.
Pat (05-18-2021)
Eccentric for RLCA camber adjustment ? Danny318 Tracking / Autocross / HPDE / Drifting 0 09-07-2020 01:37 AM
Eccentric camber bushings for lower control arms - anyone tried them? Alignment? Nickmann Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 12-20-2018 03:21 PM
FS: Raceseng Cascam Camber Plates bombardius Brakes, Suspension, Chassis 0 04-12-2016 07:55 PM
WTB Raceseng Cascam camber ft86me Want-To-Buy Requests 0 09-22-2015 06:22 AM
Help with 16mm eccentric camber bolt drift86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 09-11-2014 01:09 PM
