Old 10-27-2021, 01:26 AM   #15
Ultramaroon
not playing cards
Ultramaroon's Avatar
He would have no oil pressure if that was the case. Rods would start making noise. In neutral my car made it all of less then 100 yards before throwing a rod when it lost a rocker.
Still waiting on results from first morning cold start.
Old 10-27-2021, 03:54 AM   #16
SammyXNA
Drives: 2013
Car starts up fine during cold start nothing knocks no noise, car idles fine. Bear in mind that it's running a stage 2+ oft tune with that cold start delete though..
SammyXNA is offline   Reply With Quote
The Following User Says Thank You to SammyXNA For This Useful Post:
Ultramaroon (10-27-2021)
Old 10-27-2021, 02:24 PM   #17
Ultramaroon
not playing cards
Rules out rod knock. In any case, extremely unhealthy to continue running it. Pull engine, remove valve covers to inspect there first. My $0.02.
Old 11-06-2021, 01:49 PM   #18
Rabrooks
Rabrooks's Avatar
Drives: 2020 Subaru BRZ
it could be a bad cam gear. They are known to go bad and sound like a rod knock. Also, check for an ejected rocker. Sometimes this causes an oil leak because it will crack the valve cover.
Rabrooks is offline   Reply With Quote
The Following User Says Thank You to Rabrooks For This Useful Post:
Ultramaroon (11-06-2021)
Old 11-07-2021, 09:49 AM   #19
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Mine didn't lose oil pressure. The pivots were still in place when I pulled the valve cover.
The Following User Says Thank You to blsfrs For This Useful Post:
NoHaveMSG (11-07-2021)
Old 11-07-2021, 09:30 PM   #20
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Interesting. Did yours pop at low rpm? My pivots where mangled and the bores messed up when they got whacked by the cam lobe on the way out.
Old 11-08-2021, 08:52 AM   #21
blsfrs
blsfrs's Avatar
I think it was low speed after something got sucked into #3. First I was low on power. Pulled into paddock, checked things over, it began missing and clacking on restart. Left it at the track and when I went to get it, things went from bad to worse with broken timing chain. I had normal oil pressure the whole time. Was the hole in your valve cover big enough to dump out a bunch of oil in a short time?
Old 11-08-2021, 10:16 AM   #22
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
No. I had a crack and very little oil actually came out.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
blsfrs (11-09-2021)
Engine over revs randomly w/ no throttle response disruptorbeam Issues | Warranty | Recalls / TSB 14 02-12-2021 01:27 AM
Knocking in my Engine? SamtheKorean Software Tuning 5 10-22-2020 12:51 PM
Is my engine knocking? SamtheKorean Engine, Exhaust, Transmission 25 10-20-2020 07:20 PM
Boost vs Revs: Comparing Internal Engine Stresses Williampreza Engine, Exhaust, Transmission 15 04-10-2018 08:41 PM
2.5L with lower revs/more torque, or 2.0L with higher revs? Superhatch Engine, Exhaust, Transmission 124 08-28-2013 12:20 PM
